ap power
muhsi_2015
Level 3
Level 3
Suppose a client  receving a good rssi from the  ap  (-45dBm) and another worst client  is getting -80 dBm.
and ap power  max is 17dBm
What will happen when the worst client talking to the ap ?
Is this because of bad deployment ?
Rasika Nayanajith
Since client is far from the AP, it has to use lower data rates to communicate back to AP. This mean frames will take more airtime and other clients has to wait longer to access the medium.
This could also leads to something called "hiden node issue". If two clients can't hear each other (in this case far apart), then both can attempt to trasmit thinking medium is ideal. That will cause collisions and more re-transmissions.
Usually you do not want client with that low RSSI hang on to a given AP. Ideally client should have another AP with better RSSI and need to roam to that AP.
Since roaming decision taken by client, sometime you do not have that much control on this type of situations.
RX-SOP is a feature cisco introduced to control cell size in HD deployments. Refer below to understand how it works and implement with care if you do it in production networks.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-0/hdx_final/b_hdx_dg_final/high_density_experience_features_added_in_release_8_0.html
Rasika
*** Pls rate all useful responses ***
My issue is  the another giving  -45 dBm but some phone shows -80 dBm.
what I mean by worst client means client with a bad nic ( not 802.11 b) .
A nic like proxim reporting -45 dBm and a phone reporting  -75 dBm.
if a phone need a good signal we need to add an additional ap?
thanks
