AP randomly disconnects clients
Stevencisco
When I connect to my Cisco Aironet 1815i mobility express network sometimes my clients get randomly disconnected and it takes a while before they can connect back to the network.
How can I solve this?
6 Replies 6
Scott Fella
You need to provide a lot more information than that.
-Scott
What information do you need? I can give you
What firmware, what devices and nic and firmware, what authentication method, have you tried open SSID, has this worked before, how many ap's, any logs?
-Scott
All my Aironet 1815i mobility express are running on 8.10.121.0
As authentication method I'm using Personal(WPA2+WPA3). I tried WPA2 only and WPA3 only but didn't work, even open netwerk is not working properly.
It worked before, but we change our firewall/router from a cisco device to a fortigate d60. After that only the wireless network got problemens. I think the DHCP could be the problem, but on the wired network it works fine. Any way how to debug this?
 - Have a debug session for a particular client-mac, which you can have analyzed with :
                   https://cway.cisco.com/tools/WirelessDebugAnalyzer/
 M.
Hold up… if there was a change somewhere in the infrastructure and things started to break, then that is where your problem is. If you have not changed anything on the wireless, I would not touch it or try to fix something that was caused by a new implementation. Notify the team of the issue and have them start looking at what they forgot to implement.
-Scott
