AP reboots when connection to WLC is lost
Geert Reijnders
Hi all,
We have a mixed environment of the following AP's connected to a Catalyst 9800-40 controller:
  • C9120AXI-E
  • AIR-CAP2702I-E-K9
  • AIR-AP2802I-E-K9
  • AIR-AP1542I-E-K9
  • AIR-AP1852I-E-K9
At most of the sites we use a mixed type of AP's because we are migrating old type AP's to the new ones (C9120AXI).
Last night the connection to the WLC was lost. I noticed that most of the AP's, rebooted after their connection to the WLC was lost. Except for the C9120-AXI-E types. Is this normal behavior? The AP's are configured as flexconnect. I thought that the AP's should stay up.
The software version we are running is: 17.03.03.
Or is it due to the timer configuration? If capwap is lost, and after the timeout the WLC is still not reachable, the AP reboots? But why doesn't this happen to all AP's?
I hope that some one can help me out.
thanks!
Which version? Sounds like a bug.
 Not a normal behavior in flexconnect for sure. The bahavior expected is the opposite, stay up.
Hi Flavio,
The version is 17.3.3.26 on the AP's. I will contact TAC.
Mark Elsen
 - For next time event (if any) enable global and or syslogfrom the access points (too) : https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/wireless/controller/9800/16-12/config-guide/b_wl_16_12_cg/enabling-syslog-messages-in-access-points-and-controller-for-syslog-server.html.xml
  then check if anything useful comes up when these access point reboot. For the rest review the current controller configuration with show tech wireless  , and have the output processed by https://cway.cisco.com/tools/WirelessAnalyzer/
                             (do not use simple show tech-support for the above tool)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
