01-25-2006 06:51 PM - edited 07-04-2021 11:33 AM
I like to AP's admin authentication by RADIUS. The authentication is ok by console connection. but telnet or http authentication is fail cause limiting level_15_access. Is there any misconfiguration? Check this out please.Thaks 🙂
ap#show run
Building configuration...
Current configuration : 2845 bytes
version 12.3
no service pad
service password-encryption
hostname ap
ip subnet-zero
aaa new-model
aaa group server radius rad_admin
server *.*.*.* auth-port 1645 acct-port 1646
cache expiry 1
cache authorization profile admin_cache
cache authentication profile admin_cache
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server tacacs+ tac_admin
cache expiry 1
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default cache rad_admin group rad_admin
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default cache rad_admin group rad_admin
aaa authorization network default group radius
aaa accounting network acct_methods start-stop group rad_acct
aaa cache profile admin_cache
all
aaa session-id common
power inline negotiation prestandard source
username Cisco password xxxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address x.x.x.x 255.255.255.192
no ip route-cache
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host x.x.x.x auth-port 1645 acct-port 1646 key 7 091D1C5A4D
radius-server vsa send accounting
control-plane
bridge 1 route ip
line con 0
transport preferred all
transport output all
line vty 0 4
authorization commands 15 radius
transport input all
line vty 5 15
transport input all
end
01-30-2006 07:55 PM
just try this first
aaa authentication login vty group rad_admin
aaa authentication login http group rad_admin
line vty 0 4
login authentication vty
ip http authentication aaa login-authentication http
02-02-2006 06:56 AM
i was having the same problem. (except i use MS IAS for radius). i pasted in your command list, now instead of getting a weird ppp negotiate error, i get user authorization failed. but i looked in the IAS logs, and i'm actually getting authenticated, it's just not making it back to my ap..
any advice?
