AP's losing connection to WLC
deyster94
Level 5
Level 5
I am trying to troubleshoot an issue with 3700i AP's joining a WLC and then losing their connection to the WLC.  I noticed yesterday two AP's were not joined to the WLC and this afternoon, it went to 8.  Originally, all 11 AP's were connected to the WLC.  The first two lost connection this past Saturday.  I tried to shut/no shut the ports and that didn't help.  I did a debug capwap events and it looks like the AP is sending a join request and then WLC receives the request and replies:
*spamApTask7: Jul 23 12:14:46.846: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =9
*spamApTask7: Jul 23 12:14:46.846: apModel: AIR-CAP3702I-A-K9
*spamApTask7: Jul 23 12:14:46.846: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask7: Jul 23 12:14:46.847: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53803
*spamApTask7: Jul 23 12:14:46.847: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53803
*spamApTask7: Jul 23 12:14:46.848: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53803
*spamApTask7: Jul 23 12:14:46.848: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =9
*spamApTask7: Jul 23 12:14:46.848: apModel: AIR-CAP3702I-A-K9
*spamApTask7: Jul 23 12:14:46.848: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask7: Jul 23 12:14:46.848: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53803
*spamApTask7: Jul 23 12:14:46.849: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53803
*spamApTask2: Jul 23 12:14:46.977: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36893
*spamApTask2: Jul 23 12:14:46.977: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =9
*spamApTask2: Jul 23 12:14:46.977: apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 12:14:46.977: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 12:14:46.978: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36893
*spamApTask2: Jul 23 12:14:46.978: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36893
*spamApTask2: Jul 23 12:14:46.979: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36893
I see this over and over for each AP, so it seems like they are stuck in a loop.  I do not have console access to any of the AP's since I am not onsite.  There are still three AP's still joined to the WLC (for now) and I allowed SSH access to them.
Here is the information on the WLC:
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.120.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.95.16
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
System Name...................................... PP-SCHOOL-WLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 172.16.250.2
Last Reset....................................... Software reset
System Up Time................................... 21 days 5 hrs 5 mins 57 secs
System Timezone Location......................... (GMT -5:00) Eastern Time (US and Canada)
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +44 C
External Temperature............................. +32 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 1
Burned-in MAC Address............................ 18:E7:28:C0:30:A0
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 250
TIA for any help.
17 Replies 17
Stephen Rodriguez
couple of things you can do.
1.) check that you don't have an IP conflict with the mgmt address.
2.) run the following debug concurrently:
debug capwap events enable
debug capwap errors enable
debug pm pki enable
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
The network for the AP's and WLC (which is the same) is brand new, so nothing else should have the WLC mgmt IP address.  However, I am going to check the server the client created the DHCP scope on and the DNS record for the WLC.
I will post the other information shortly.
Here is the output from the debug commands:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.07.23 14:21:15 =~=~=~=~=~=~=~=~=~=~=~=
(Cisco Controller) >
(Cisco Controller) >debug capwap errors enable
(Cisco Controller) >debug pm pki enable
(Cisco Controller) >*spamApTask1: Jul 23 12:18:05.910: f4:0f:1b:6a:cd:40 WTP Event Response sent to 172.16.250.23:54122
*spamApTask6: Jul 23 14:21:23.336: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:21:23.336: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:21:23.336: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:21:23.336: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:21:23.336: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:21:23.336: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:21:23.336: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:21:23.336: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask6: Jul 23 14:21:23.338: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:21:23.338: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:21:23.338: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:21:23.338: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:21:23.338: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:21:23.338: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:21:23.338: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:21:23.338: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask1: Jul 23 14:21:23.456: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:21:23.456: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:23.456: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:21:23.456: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:23.456: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:23.456: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:21:23.456: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:21:23.457: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:21:23.457: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:21:23.457: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:23.457: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:21:23.457: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:23.457: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:23.458: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:21:23.458: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:21:23.458: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask3: Jul 23 14:21:28.005: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:21:28.005: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:21:30.391: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:21:30.391: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask2: Jul 23 14:21:31.552: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:21:31.552: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask3: Jul 23 14:21:32.036: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:21:32.036: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask1: Jul 23 14:21:33.457: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:21:33.457: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:33.457: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:21:33.457: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:33.457: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:33.457: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:21:33.457: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:21:33.457: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:21:33.458: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:21:33.458: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:21:33.458: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask6: Jul 23 14:21:43.336: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:21:43.336: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:21:43.336: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:21:43.336: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:21:43.336: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:21:43.336: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:21:43.337: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:21:43.337: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask6: Jul 23 14:21:43.338: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:21:43.338: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:21:43.338: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:21:43.338: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:21:43.338: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:21:43.338: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:21:43.339: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:21:43.339: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask1: Jul 23 14:21:43.456: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:21:43.456: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:43.457: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:21:43.457: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:43.457: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:43.457: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:21:43.457: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:21:43.457: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:21:43.458: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:21:43.458: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:43.458: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:21:43.458: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:43.458: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:43.458: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:21:43.458: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:21:43.458: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:21:43.459: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:21:43.459: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:21:43.459: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:21:43.459: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:43.459: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:21:43.459: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:43.459: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:21:43.459: Unknown AP type. Using Controller Version!!!
*spamApTask2: Jul 23 14:21:56.764: f4:0f:1b:69:68:10 Primary Discovery Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:21:56.764: f4:0f:1b:69:68:10 ApModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:21:56.764: apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:21:56.764: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:21:56.764: Unknown AP type. Using Controller Version!!!
*spamApTask2: Jul 23 14:21:56.764: f4:0f:1b:69:68:10 Primary Discovery Response sent to  172.16.250.19:49639
*spamApTask2: Jul 23 14:21:56.765: f4:0f:1b:69:68:10 ApModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:21:56.765: apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:21:56.765: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:21:56.765: Unknown AP type. Using Controller Version!!!
*spamApTask2: Jul 23 14:21:56.765: f4:0f:1b:69:68:10 Primary Discovery Response sent to  172.16.250.19:49639
*spamApTask3: Jul 23 14:21:57.400: f4:0f:1b:3f:46:f0 Primary Discovery Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:21:57.400: f4:0f:1b:3f:46:f0 ApModel: AIR-CAP3702E-A-K9
*spamApTask3: Jul 23 14:21:57.400: apModel: AIR-CAP3702E-A-K9
*spamApTask3: Jul 23 14:21:57.400: apType = 41 apModel: AIR-CAP3702E-A-K9
*spamApTask3: Jul 23 14:21:57.400: Unknown AP type. Using Controller Version!!!
*spamApTask3: Jul 23 14:21:57.400: f4:0f:1b:3f:46:f0 Primary Discovery Response sent to  172.16.250.11:36896
*spamApTask3: Jul 23 14:21:57.401: f4:0f:1b:3f:46:f0 Primary Discovery Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:21:57.401: f4:0f:1b:3f:46:f0 ApModel: AIR-CAP3702E-A-K9
*spamApTask3: Jul 23 14:21:57.401: apModel: AIR-CAP3702E-A-K9
*spamApTask3: Jul 23 14:21:57.401: apType = 41 apModel: AIR-CAP3702E-A-K9
*spamApTask3: Jul 23 14:21:57.401: Unknown AP type. Using Controller Version!!!
*spamApTask3: Jul 23 14:21:57.401: f4:0f:1b:3f:46:f0 Primary Discovery Response sent to  172.16.250.11:36896
*spamApTask3: Jul 23 14:21:57.917: f4:0f:1b:68:ae:e0 Primary Discovery Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:21:57.917: f4:0f:1b:68:ae:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:21:57.917: apModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:21:57.917: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:21:57.917: Unknown AP type. Using Controller Version!!!
*spamApTask3: Jul 23 14:21:57.917: f4:0f:1b:68:ae:e0 Primary Discovery Response sent to  172.16.250.27:30472
*spamApTask3: Jul 23 14:21:57.918: f4:0f:1b:68:ae:e0 Primary Discovery Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:21:57.918: f4:0f:1b:68:ae:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:21:57.918: apModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:21:57.918: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:21:57.918: Unknown AP type. Using Controller Version!!!
*spamApTask3: Jul 23 14:21:57.918: f4:0f:1b:68:ae:e0 Primary Discovery Response sent to  172.16.250.27:30472
*spamApTask3: Jul 23 14:21:58.005: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:21:58.005: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:21:58.080: f4:0f:1b:3f:46:f0 Echo Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:21:58.080: f4:0f:1b:3f:46:f0 Echo Response sent to 172.16.250.11:36896
*spamApTask2: Jul 23 14:22:01.552: f4:0f:1b:69:68:10 Echo Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:22:01.552: f4:0f:1b:69:68:10 Echo Response sent to 172.16.250.19:49639
*spamApTask3: Jul 23 14:22:02.037: f4:0f:1b:68:ae:e0 Echo Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:22:02.037: f4:0f:1b:68:ae:e0 Echo Response sent to 172.16.250.27:30472
*spamApTask2: Jul 23 14:22:13.289: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:22:13.289: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask2: Jul 23 14:22:13.290: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask3: Jul 23 14:22:13.936: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:22:13.936: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:22:13.937: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:22:13.937: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:22:14.457: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:22:14.457: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask3: Jul 23 14:22:14.458: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:22:14.458: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask6: Jul 23 14:22:19.836: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:22:19.836: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:19.836: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:22:19.836: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:19.836: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:19.836: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:22:19.837: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:22:19.837: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask6: Jul 23 14:22:19.838: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:22:19.838: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:19.838: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:22:19.838: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:19.838: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:19.838: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:22:19.838: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:22:19.838: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask1: Jul 23 14:22:19.956: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:22:19.957: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:19.957: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:22:19.957: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:19.957: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:19.957: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:22:19.957: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:22:19.957: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:22:19.958: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:22:19.958: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:19.958: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:22:19.958: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:19.958: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:19.958: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:22:19.958: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:22:19.958: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask3: Jul 23 14:22:28.005: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:22:28.005: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask1: Jul 23 14:22:28.615: f4:0f:1b:6a:cd:40 Discovery Request from 172.16.250.23:54122
*spamApTask1: Jul 23 14:22:28.615: f4:0f:1b:6a:cd:40 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.615: f4:0f:1b:6a:cd:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:22:28.615: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.615: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.615: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:22:28.616: f4:0f:1b:6a:cd:40 Discovery Response sent to 172.16.250.23 port 54122
*spamApTask1: Jul 23 14:22:28.616: f4:0f:1b:6a:cd:40 Discovery Response sent to 172.16.250.23:54122
*spamApTask1: Jul 23 14:22:28.617: f4:0f:1b:6a:cd:40 Discovery Request from 172.16.250.23:54122
*spamApTask1: Jul 23 14:22:28.617: f4:0f:1b:6a:cd:40 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.617: f4:0f:1b:6a:cd:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:22:28.617: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.617: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.617: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:22:28.618: f4:0f:1b:6a:cd:40 Discovery Response sent to 172.16.250.23 port 54122
*spamApTask1: Jul 23 14:22:28.618: f4:0f:1b:6a:cd:40 Discovery Response sent to 172.16.250.23:54122
*spamApTask1: Jul 23 14:22:28.789: f4:0f:1b:69:55:f0 Discovery Request from 172.16.250.26:49567
*spamApTask1: Jul 23 14:22:28.789: f4:0f:1b:69:55:f0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.789: f4:0f:1b:69:55:f0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:22:28.789: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.789: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.789: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:22:28.790: f4:0f:1b:69:55:f0 Discovery Response sent to 172.16.250.26 port 49567
*spamApTask1: Jul 23 14:22:28.790: f4:0f:1b:69:55:f0 Discovery Response sent to 172.16.250.26:49567
*spamApTask1: Jul 23 14:22:28.790: f4:0f:1b:69:55:f0 Discovery Request from 172.16.250.26:49567
*spamApTask1: Jul 23 14:22:28.790: f4:0f:1b:69:55:f0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.790: f4:0f:1b:69:55:f0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:22:28.790: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.790: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.790: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:22:28.791: f4:0f:1b:69:55:f0 Discovery Response sent to 172.16.250.26 port 49567
*spamApTask1: Jul 23 14:22:28.791: f4:0f:1b:69:55:f0 Discovery Response sent to 172.16.250.26:49567
*spamApTask6: Jul 23 14:22:28.844: f4:0f:1b:6a:cb:90 Discovery Request from 172.16.250.25:54117
*spamApTask6: Jul 23 14:22:28.844: f4:0f:1b:6a:cb:90 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:28.844: f4:0f:1b:6a:cb:90 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:22:28.844: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:28.844: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:28.844: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:22:28.844: f4:0f:1b:6a:cb:90 Discovery Response sent to 172.16.250.25 port 54117
*spamApTask6: Jul 23 14:22:28.844: f4:0f:1b:6a:cb:90 Discovery Response sent to 172.16.250.25:54117
*spamApTask6: Jul 23 14:22:28.845: f4:0f:1b:6a:cb:90 Discovery Request from 172.16.250.25:54117
*spamApTask6: Jul 23 14:22:28.845: f4:0f:1b:6a:cb:90 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:28.845: f4:0f:1b:6a:cb:90 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:22:28.845: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:28.845: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:28.846: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:22:28.846: f4:0f:1b:6a:cb:90 Discovery Response sent to 172.16.250.25 port 54117
*spamApTask6: Jul 23 14:22:28.846: f4:0f:1b:6a:cb:90 Discovery Response sent to 172.16.250.25:54117
*spamApTask1: Jul 23 14:22:28.881: f4:0f:1b:5d:56:d0 Discovery Request from 172.16.250.3:53782
*spamApTask1: Jul 23 14:22:28.881: f4:0f:1b:5d:56:d0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.882: f4:0f:1b:5d:56:d0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:22:28.882: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.882: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.882: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:22:28.882: f4:0f:1b:5d:56:d0 Discovery Response sent to 172.16.250.3 port 53782
*spamApTask1: Jul 23 14:22:28.882: f4:0f:1b:5d:56:d0 Discovery Response sent to 172.16.250.3:53782
*spamApTask1: Jul 23 14:22:28.883: f4:0f:1b:5d:56:d0 Discovery Request from 172.16.250.3:53782
*spamApTask1: Jul 23 14:22:28.883: f4:0f:1b:5d:56:d0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.883: f4:0f:1b:5d:56:d0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:22:28.883: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.883: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:28.883: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:22:28.883: f4:0f:1b:5d:56:d0 Discovery Response sent to 172.16.250.3 port 53782
*spamApTask1: Jul 23 14:22:28.883: f4:0f:1b:5d:56:d0 Discovery Response sent to 172.16.250.3:53782
*spamApTask3: Jul 23 14:22:29.234: f4:0f:1b:54:d6:a0 Discovery Request from 172.16.250.24:1211
*spamApTask3: Jul 23 14:22:29.234: f4:0f:1b:54:d6:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:22:29.235: f4:0f:1b:54:d6:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask3: Jul 23 14:22:29.235: apModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:22:29.235: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:22:29.235: Unknown AP type. Using Controller Version!!!
*spamApTask3: Jul 23 14:22:29.235: f4:0f:1b:54:d6:a0 Discovery Response sent to 172.16.250.24 port 1211
*spamApTask3: Jul 23 14:22:29.235: f4:0f:1b:54:d6:a0 Discovery Response sent to 172.16.250.24:1211
*spamApTask3: Jul 23 14:22:29.236: f4:0f:1b:54:d6:a0 Discovery Request from 172.16.250.24:1211
*spamApTask3: Jul 23 14:22:29.236: f4:0f:1b:54:d6:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:22:29.236: f4:0f:1b:54:d6:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask3: Jul 23 14:22:29.236: apModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:22:29.236: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:22:29.236: Unknown AP type. Using Controller Version!!!
*spamApTask3: Jul 23 14:22:29.236: f4:0f:1b:54:d6:a0 Discovery Response sent to 172.16.250.24 port 1211
*spamApTask3: Jul 23 14:22:29.236: f4:0f:1b:54:d6:a0 Discovery Response sent to 172.16.250.24:1211
*spamApTask4: Jul 23 14:22:29.239: f4:0f:1b:70:db:b0 Discovery Request from 172.16.250.22:30494
*spamApTask4: Jul 23 14:22:29.239: f4:0f:1b:70:db:b0 ApModel: AIR-CAP3702I-A-K9
*spamApTask4: Jul 23 14:22:29.239: f4:0f:1b:70:db:b0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask4: Jul 23 14:22:29.239: apModel: AIR-CAP3702I-A-K9
*spamApTask4: Jul 23 14:22:29.240: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask4: Jul 23 14:22:29.240: Unknown AP type. Using Controller Version!!!
*spamApTask4: Jul 23 14:22:29.240: f4:0f:1b:70:db:b0 Discovery Response sent to 172.16.250.22 port 30494
*spamApTask4: Jul 23 14:22:29.240: f4:0f:1b:70:db:b0 Discovery Response sent to 172.16.250.22:30494
*spamApTask4: Jul 23 14:22:29.241: f4:0f:1b:70:db:b0 Discovery Request from 172.16.250.22:30494
*spamApTask4: Jul 23 14:22:29.241: f4:0f:1b:70:db:b0 ApModel: AIR-CAP3702I-A-K9
*spamApTask4: Jul 23 14:22:29.241: f4:0f:1b:70:db:b0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask4: Jul 23 14:22:29.241: apModel: AIR-CAP3702I-A-K9
*spamApTask4: Jul 23 14:22:29.241: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask4: Jul 23 14:22:29.241: Unknown AP type. Using Controller Version!!!
*spamApTask4: Jul 23 14:22:29.241: f4:0f:1b:70:db:b0 Discovery Response sent to 172.16.250.22 port 30494
*spamApTask4: Jul 23 14:22:29.241: f4:0f:1b:70:db:b0 Discovery Response sent to 172.16.250.22:30494
*spamApTask1: Jul 23 14:22:29.957: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:22:29.957: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:29.957: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:22:29.957: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:29.957: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:29.957: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:22:29.958: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:22:29.958: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:22:29.958: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:22:29.958: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:29.958: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:22:29.958: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:29.958: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:29.958: Unknown AP type. Using Controller Version!!!
*spamApTask3: Jul 23 14:22:30.394: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:22:30.394: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask2: Jul 23 14:22:31.553: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:22:31.553: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask3: Jul 23 14:22:32.038: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:22:32.038: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask6: Jul 23 14:22:39.836: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:22:39.836: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:39.836: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:22:39.837: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:39.837: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:39.837: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:22:39.837: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:22:39.837: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask6: Jul 23 14:22:39.838: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:22:39.838: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:39.838: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:22:39.838: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:39.838: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:22:39.838: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:22:39.839: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:22:39.839: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask1: Jul 23 14:22:39.957: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:22:39.957: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:39.957: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:22:39.957: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:39.957: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:39.957: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:22:39.957: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:22:39.957: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:22:39.958: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:22:39.958: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:39.958: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:22:39.958: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:39.958: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:39.958: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:22:39.959: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:22:39.959: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:22:39.959: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:22:39.959: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:39.959: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:22:39.959: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:39.959: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:22:39.959: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:22:39.960: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:22:39.960: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*sshpmLscTask: Jul 23 14:22:43.782: sshpmLscTask: LSC Task received a message 4
*spamApTask3: Jul 23 14:22:58.005: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:22:58.006: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask2: Jul 23 14:23:01.554: f4:0f:1b:69:68:10 Echo Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:23:01.554: f4:0f:1b:69:68:10 Echo Response sent to 172.16.250.19:49639
*spamApTask3: Jul 23 14:23:02.037: f4:0f:1b:68:ae:e0 Echo Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:23:02.037: f4:0f:1b:68:ae:e0 Echo Response sent to 172.16.250.27:30472
*spamApTask2: Jul 23 14:23:13.290: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:23:13.291: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask2: Jul 23 14:23:13.291: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:23:13.292: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask3: Jul 23 14:23:13.937: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:13.937: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:13.938: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:13.938: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:14.457: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:23:14.457: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask3: Jul 23 14:23:14.458: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:23:14.458: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask6: Jul 23 14:23:16.336: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:23:16.336: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:23:16.336: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:23:16.336: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:23:16.336: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:23:16.336: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:23:16.337: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:23:16.337: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask6: Jul 23 14:23:16.338: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:23:16.338: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:23:16.338: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:23:16.338: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:23:16.338: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:23:16.338: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:23:16.338: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:23:16.339: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask1: Jul 23 14:23:16.457: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:23:16.457: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:16.457: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:23:16.457: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:16.457: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:16.457: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:23:16.457: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:23:16.457: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:23:16.458: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:23:16.458: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:16.458: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:23:16.458: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:16.458: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:16.458: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:23:16.459: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:23:16.459: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:23:26.458: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:23:26.458: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:26.458: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:23:26.458: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:26.458: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:26.458: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:23:26.458: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:23:26.458: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:23:26.459: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:23:26.459: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask3: Jul 23 14:23:28.012: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:28.013: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:30.396: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:30.396: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask2: Jul 23 14:23:31.557: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:23:31.557: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask3: Jul 23 14:23:32.041: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:23:32.041: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask6: Jul 23 14:23:36.336: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:23:36.337: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:23:36.337: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:23:36.337: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:23:36.337: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:23:36.337: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:23:36.337: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:23:36.337: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask6: Jul 23 14:23:36.338: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:23:36.338: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:23:36.339: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:23:36.339: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:23:36.339: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:23:36.339: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:23:36.339: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:23:36.339: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask1: Jul 23 14:23:36.457: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:23:36.457: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:36.457: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:23:36.457: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:36.458: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:36.458: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:23:36.458: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:23:36.458: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:23:36.458: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:23:36.458: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:36.458: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:23:36.459: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:36.459: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:36.459: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:23:36.459: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:23:36.459: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:23:36.459: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:23:36.459: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:36.459: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:23:36.460: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:36.460: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:23:36.460: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:36.460: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:23:36.460: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:23:36.460: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:23:36.460: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask2: Jul 23 14:23:56.767: f4:0f:1b:69:68:10 Primary Discovery Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:23:56.767: f4:0f:1b:69:68:10 ApModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:23:56.768: apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:23:56.768: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:23:56.768: Unknown AP type. Using Controller Version!!!
*spamApTask2: Jul 23 14:23:56.768: f4:0f:1b:69:68:10 Primary Discovery Response sent to  172.16.250.19:49639
*spamApTask2: Jul 23 14:23:56.768: f4:0f:1b:69:68:10 Primary Discovery Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:23:56.768: f4:0f:1b:69:68:10 ApModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:23:57.401: f4:0f:1b:3f:46:f0 Primary Discovery Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:57.401: f4:0f:1b:3f:46:f0 ApModel: AIR-CAP3702E-A-K9
*spamApTask3: Jul 23 14:23:57.401: apModel: AIR-CAP3702E-A-K9
*spamApTask3: Jul 23 14:23:57.401: apType = 41 apModel: AIR-CAP3702E-A-K9
*spamApTask3: Jul 23 14:23:57.401: Unknown AP type. Using Controller Version!!!
*spamApTask3: Jul 23 14:23:57.401: f4:0f:1b:3f:46:f0 Primary Discovery Response sent to  172.16.250.11:36896
*spamApTask3: Jul 23 14:23:57.402: f4:0f:1b:3f:46:f0 Primary Discovery Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:57.402: f4:0f:1b:3f:46:f0 ApModel: AIR-CAP3702E-A-K9
*spamApTask3: Jul 23 14:23:57.402: apModel: AIR-CAP3702E-A-K9
*spamApTask3: Jul 23 14:23:57.402: apType = 41 apModel: AIR-CAP3702E-A-K9
*spamApTask3: Jul 23 14:23:57.402: Unknown AP type. Using Controller Version!!!
*spamApTask3: Jul 23 14:23:57.403: f4:0f:1b:3f:46:f0 Primary Discovery Response sent to  172.16.250.11:36896
*spamApTask2: Jul 23 14:23:57.432: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:23:57.433: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask2: Jul 23 14:23:57.434: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:23:57.434: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask2: Jul 23 14:23:57.435: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:23:57.435: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask3: Jul 23 14:23:57.917: f4:0f:1b:68:ae:e0 Primary Discovery Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:23:57.918: f4:0f:1b:68:ae:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:23:57.918: apModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:23:57.918: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:23:57.918: Unknown AP type. Using Controller Version!!!
*spamApTask3: Jul 23 14:23:57.918: f4:0f:1b:68:ae:e0 Primary Discovery Response sent to  172.16.250.27:30472
*spamApTask3: Jul 23 14:23:57.919: f4:0f:1b:68:ae:e0 Primary Discovery Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:23:57.919: f4:0f:1b:68:ae:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:23:57.919: apModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:23:57.919: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask3: Jul 23 14:23:57.919: Unknown AP type. Using Controller Version!!!
*spamApTask3: Jul 23 14:23:57.919: f4:0f:1b:68:ae:e0 Primary Discovery Response sent to  172.16.250.27:30472
*spamApTask3: Jul 23 14:23:58.010: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:58.010: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:58.082: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:58.082: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:58.083: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:58.084: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:58.084: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:58.085: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:23:58.599: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:23:58.599: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask3: Jul 23 14:23:58.600: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:23:58.600: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask3: Jul 23 14:23:58.601: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:23:58.601: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask2: Jul 23 14:24:00.015: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:24:00.016: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask2: Jul 23 14:24:00.016: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:24:00.017: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:24:00.017: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask3: Jul 23 14:24:00.793: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:00.793: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:00.794: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:00.794: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:00.795: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:00.795: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:01.218: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:24:01.218: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask3: Jul 23 14:24:01.219: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:24:01.219: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask3: Jul 23 14:24:01.220: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask2: Jul 23 14:24:05.915: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:24:05.915: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask2: Jul 23 14:24:05.916: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:24:05.916: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask2: Jul 23 14:24:05.917: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:24:05.917: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask3: Jul 23 14:24:06.628: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:06.628: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:06.629: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:06.629: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:06.630: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:06.630: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:07.193: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:24:07.193: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask3: Jul 23 14:24:07.194: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:24:07.194: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask3: Jul 23 14:24:07.195: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:24:07.195: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask6: Jul 23 14:24:12.836: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:24:12.836: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:24:12.836: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:24:12.837: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:24:12.837: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:24:12.837: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:24:12.837: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:24:12.837: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask6: Jul 23 14:24:12.838: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:24:12.838: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:24:12.838: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:24:12.838: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:24:12.838: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:24:12.838: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:24:12.839: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:24:12.839: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask1: Jul 23 14:24:12.957: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:24:12.957: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:12.957: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:24:12.958: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:12.958: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:12.958: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:24:12.958: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:24:12.958: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:24:12.958: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:24:12.958: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:12.958: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:24:12.959: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:12.959: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:24:12.959: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:24:12.959: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask2: Jul 23 14:24:13.292: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:24:13.292: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask2: Jul 23 14:24:13.293: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:24:13.293: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask3: Jul 23 14:24:13.937: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:13.937: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:13.938: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:13.938: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:14.458: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:24:14.458: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask3: Jul 23 14:24:14.459: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask1: Jul 23 14:24:22.958: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:24:22.958: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:22.958: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:24:22.958: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:22.958: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:22.958: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:24:22.959: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:24:22.959: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:24:22.959: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:24:22.959: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:22.959: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:24:22.959: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:22.959: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:22.959: Unknown AP type. Using Controller Version!!!
*spamApTask3: Jul 23 14:24:28.010: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:28.010: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:30.400: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:30.400: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask2: Jul 23 14:24:31.570: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:24:31.570: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask3: Jul 23 14:24:32.046: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:24:32.047: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask6: Jul 23 14:24:32.837: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:24:32.837: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:24:32.837: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:24:32.837: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:24:32.837: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:24:32.837: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:24:32.837: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:24:32.837: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask6: Jul 23 14:24:32.838: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:24:32.838: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:24:32.838: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:24:32.838: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:24:32.839: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:24:32.839: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:24:32.839: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:24:32.839: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask1: Jul 23 14:24:32.958: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:24:32.958: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:32.958: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:24:32.958: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:32.958: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:32.958: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:24:32.958: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:24:32.958: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:24:32.959: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:24:32.959: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:32.959: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:24:32.959: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:32.959: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:32.959: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:24:32.959: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:24:32.959: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:24:32.960: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:24:32.960: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:24:32.960: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:24:32.960: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:32.960: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:24:32.960: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:32.960: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:24:32.960: Unknown AP type. Using Controller Version!!!
*spamApTask2: Jul 23 14:24:38.740: f4:0f:1b:6a:cd:40 Discovery Request from 172.16.250.23:54123
*spamApTask2: Jul 23 14:24:38.740: f4:0f:1b:6a:cd:40 ApModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:38.740: f4:0f:1b:6a:cd:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask2: Jul 23 14:24:38.740: apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:38.740: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:38.740: Unknown AP type. Using Controller Version!!!
*spamApTask2: Jul 23 14:24:38.740: f4:0f:1b:6a:cd:40 Discovery Response sent to 172.16.250.23 port 54123
*spamApTask2: Jul 23 14:24:38.740: f4:0f:1b:6a:cd:40 Discovery Response sent to 172.16.250.23:54123
*spamApTask2: Jul 23 14:24:38.742: f4:0f:1b:6a:cd:40 Discovery Request from 172.16.250.23:54123
*spamApTask2: Jul 23 14:24:38.742: f4:0f:1b:6a:cd:40 ApModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:38.742: f4:0f:1b:6a:cd:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask2: Jul 23 14:24:38.742: apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:38.742: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:38.742: Unknown AP type. Using Controller Version!!!
*spamApTask2: Jul 23 14:24:38.742: f4:0f:1b:6a:cd:40 Discovery Response sent to 172.16.250.23 port 54123
*spamApTask2: Jul 23 14:24:38.742: f4:0f:1b:6a:cd:40 Discovery Response sent to 172.16.250.23:54123
*spamApTask2: Jul 23 14:24:38.907: f4:0f:1b:69:55:f0 Discovery Request from 172.16.250.26:49568
*spamApTask2: Jul 23 14:24:38.907: f4:0f:1b:69:55:f0 ApModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:38.907: f4:0f:1b:69:55:f0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask2: Jul 23 14:24:38.907: apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:38.907: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:38.907: Unknown AP type. Using Controller Version!!!
*spamApTask2: Jul 23 14:24:38.908: f4:0f:1b:69:55:f0 Discovery Response sent to 172.16.250.26 port 49568
*spamApTask2: Jul 23 14:24:38.908: f4:0f:1b:69:55:f0 Discovery Response sent to 172.16.250.26:49568
*spamApTask2: Jul 23 14:24:38.909: f4:0f:1b:69:55:f0 Discovery Request from 172.16.250.26:49568
*spamApTask2: Jul 23 14:24:38.909: f4:0f:1b:69:55:f0 ApModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:38.909: f4:0f:1b:69:55:f0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask2: Jul 23 14:24:38.909: apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:38.909: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:38.909: Unknown AP type. Using Controller Version!!!
*spamApTask2: Jul 23 14:24:38.909: f4:0f:1b:69:55:f0 Discovery Response sent to 172.16.250.26 port 49568
*spamApTask2: Jul 23 14:24:38.909: f4:0f:1b:69:55:f0 Discovery Response sent to 172.16.250.26:49568
*spamApTask5: Jul 23 14:24:38.968: f4:0f:1b:6a:cb:90 Discovery Request from 172.16.250.25:54116
*spamApTask5: Jul 23 14:24:38.968: f4:0f:1b:6a:cb:90 ApModel: AIR-CAP3702I-A-K9
*spamApTask5: Jul 23 14:24:38.968: f4:0f:1b:6a:cb:90 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask5: Jul 23 14:24:38.968: apModel: AIR-CAP3702I-A-K9
*spamApTask5: Jul 23 14:24:38.968: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask5: Jul 23 14:24:38.968: Unknown AP type. Using Controller Version!!!
*spamApTask5: Jul 23 14:24:38.968: f4:0f:1b:6a:cb:90 Discovery Response sent to 172.16.250.25 port 54116
*spamApTask5: Jul 23 14:24:38.968: f4:0f:1b:6a:cb:90 Discovery Response sent to 172.16.250.25:54116
*spamApTask5: Jul 23 14:24:38.969: f4:0f:1b:6a:cb:90 Discovery Request from 172.16.250.25:54116
*spamApTask5: Jul 23 14:24:38.969: f4:0f:1b:6a:cb:90 ApModel: AIR-CAP3702I-A-K9
*spamApTask5: Jul 23 14:24:38.969: f4:0f:1b:6a:cb:90 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask5: Jul 23 14:24:38.969: apModel: AIR-CAP3702I-A-K9
*spamApTask5: Jul 23 14:24:38.969: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask5: Jul 23 14:24:38.970: Unknown AP type. Using Controller Version!!!
*spamApTask5: Jul 23 14:24:38.970: f4:0f:1b:6a:cb:90 Discovery Response sent to 172.16.250.25 port 54116
*spamApTask5: Jul 23 14:24:38.970: f4:0f:1b:6a:cb:90 Discovery Response sent to 172.16.250.25:54116
*spamApTask2: Jul 23 14:24:39.002: f4:0f:1b:5d:56:d0 Discovery Request from 172.16.250.3:53783
*spamApTask2: Jul 23 14:24:39.002: f4:0f:1b:5d:56:d0 ApModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:39.003: f4:0f:1b:5d:56:d0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask2: Jul 23 14:24:39.003: apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:39.003: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:39.003: Unknown AP type. Using Controller Version!!!
*spamApTask2: Jul 23 14:24:39.003: f4:0f:1b:5d:56:d0 Discovery Response sent to 172.16.250.3 port 53783
*spamApTask2: Jul 23 14:24:39.003: f4:0f:1b:5d:56:d0 Discovery Response sent to 172.16.250.3:53783
*spamApTask2: Jul 23 14:24:39.004: f4:0f:1b:5d:56:d0 Discovery Request from 172.16.250.3:53783
*spamApTask2: Jul 23 14:24:39.004: f4:0f:1b:5d:56:d0 ApModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:39.004: f4:0f:1b:5d:56:d0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask2: Jul 23 14:24:39.004: apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:39.004: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:39.004: Unknown AP type. Using Controller Version!!!
*spamApTask2: Jul 23 14:24:39.005: f4:0f:1b:5d:56:d0 Discovery Response sent to 172.16.250.3 port 53783
*spamApTask2: Jul 23 14:24:39.005: f4:0f:1b:5d:56:d0 Discovery Response sent to 172.16.250.3:53783
*spamApTask2: Jul 23 14:24:39.355: f4:0f:1b:54:d6:a0 Discovery Request from 172.16.250.24:1210
*spamApTask2: Jul 23 14:24:39.355: f4:0f:1b:54:d6:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:39.355: f4:0f:1b:54:d6:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask2: Jul 23 14:24:39.355: apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:39.355: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:39.355: Unknown AP type. Using Controller Version!!!
*spamApTask2: Jul 23 14:24:39.356: f4:0f:1b:54:d6:a0 Discovery Response sent to 172.16.250.24 port 1210
*spamApTask2: Jul 23 14:24:39.356: f4:0f:1b:54:d6:a0 Discovery Response sent to 172.16.250.24:1210
*spamApTask2: Jul 23 14:24:39.357: f4:0f:1b:54:d6:a0 Discovery Request from 172.16.250.24:1210
*spamApTask2: Jul 23 14:24:39.357: f4:0f:1b:54:d6:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:39.357: f4:0f:1b:54:d6:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask2: Jul 23 14:24:39.357: apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:39.357: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask2: Jul 23 14:24:39.357: Unknown AP type. Using Controller Version!!!
*spamApTask2: Jul 23 14:24:39.357: f4:0f:1b:54:d6:a0 Discovery Response sent to 172.16.250.24 port 1210
*spamApTask2: Jul 23 14:24:39.357: f4:0f:1b:54:d6:a0 Discovery Response sent to 172.16.250.24:1210
*spamApTask5: Jul 23 14:24:39.360: f4:0f:1b:70:db:b0 Discovery Request from 172.16.250.22:30495
*spamApTask5: Jul 23 14:24:39.360: f4:0f:1b:70:db:b0 ApModel: AIR-CAP3702I-A-K9
*spamApTask5: Jul 23 14:24:39.360: f4:0f:1b:70:db:b0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask5: Jul 23 14:24:39.360: apModel: AIR-CAP3702I-A-K9
*spamApTask5: Jul 23 14:24:39.360: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask5: Jul 23 14:24:39.360: Unknown AP type. Using Controller Version!!!
*spamApTask5: Jul 23 14:24:39.361: f4:0f:1b:70:db:b0 Discovery Response sent to 172.16.250.22 port 30495
*spamApTask5: Jul 23 14:24:39.361: f4:0f:1b:70:db:b0 Discovery Response sent to 172.16.250.22:30495
*spamApTask5: Jul 23 14:24:39.362: f4:0f:1b:70:db:b0 Discovery Request from 172.16.250.22:30495
*spamApTask5: Jul 23 14:24:39.362: f4:0f:1b:70:db:b0 ApModel: AIR-CAP3702I-A-K9
*spamApTask5: Jul 23 14:24:39.362: f4:0f:1b:70:db:b0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask5: Jul 23 14:24:39.362: apModel: AIR-CAP3702I-A-K9
*spamApTask5: Jul 23 14:24:39.362: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask5: Jul 23 14:24:39.362: Unknown AP type. Using Controller Version!!!
*spamApTask5: Jul 23 14:24:39.362: f4:0f:1b:70:db:b0 Discovery Response sent to 172.16.250.22 port 30495
*spamApTask5: Jul 23 14:24:39.362: f4:0f:1b:70:db:b0 Discovery Response sent to 172.16.250.22:30495
*sshpmLscTask: Jul 23 14:24:43.782: sshpmLscTask: LSC Task received a message 4
*spamApTask3: Jul 23 14:24:58.010: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:24:58.011: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask2: Jul 23 14:25:01.569: f4:0f:1b:69:68:10 Echo Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:25:01.569: f4:0f:1b:69:68:10 Echo Response sent to 172.16.250.19:49639
*spamApTask3: Jul 23 14:25:02.046: f4:0f:1b:68:ae:e0 Echo Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:25:02.046: f4:0f:1b:68:ae:e0 Echo Response sent to 172.16.250.27:30472
*spamApTask6: Jul 23 14:25:09.336: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:25:09.337: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:25:09.337: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:25:09.337: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:25:09.337: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:25:09.337: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:25:09.337: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:25:09.337: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask6: Jul 23 14:25:09.338: f4:0f:1b:5d:5b:e0 Discovery Request from 172.16.250.4:53802
*spamApTask6: Jul 23 14:25:09.338: f4:0f:1b:5d:5b:e0 ApModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:25:09.339: f4:0f:1b:5d:5b:e0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask6: Jul 23 14:25:09.339: apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:25:09.339: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask6: Jul 23 14:25:09.339: Unknown AP type. Using Controller Version!!!
*spamApTask6: Jul 23 14:25:09.339: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4 port 53802
*spamApTask6: Jul 23 14:25:09.339: f4:0f:1b:5d:5b:e0 Discovery Response sent to 172.16.250.4:53802
*spamApTask1: Jul 23 14:25:09.458: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:25:09.458: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:25:09.458: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:25:09.458: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:25:09.458: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:25:09.458: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:25:09.458: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:25:09.458: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask1: Jul 23 14:25:09.459: f4:0f:1b:67:3a:a0 Discovery Request from 172.16.250.5:36892
*spamApTask1: Jul 23 14:25:09.459: f4:0f:1b:67:3a:a0 ApModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:25:09.459: f4:0f:1b:67:3a:a0 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 250, joined Aps =3
*spamApTask1: Jul 23 14:25:09.459: apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:25:09.459: apType = 41 apModel: AIR-CAP3702I-A-K9
*spamApTask1: Jul 23 14:25:09.459: Unknown AP type. Using Controller Version!!!
*spamApTask1: Jul 23 14:25:09.459: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5 port 36892
*spamApTask1: Jul 23 14:25:09.459: f4:0f:1b:67:3a:a0 Discovery Response sent to 172.16.250.5:36892
*spamApTask2: Jul 23 14:25:13.294: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:25:13.294: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask2: Jul 23 14:25:13.295: f4:0f:1b:69:68:10 WTP Event Request from 172.16.250.19:49639
*spamApTask2: Jul 23 14:25:13.295: f4:0f:1b:69:68:10 WTP Event Response sent to 172.16.250.19:49639
*spamApTask3: Jul 23 14:25:13.938: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:25:13.938: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:25:13.939: f4:0f:1b:3f:46:f0 WTP Event Request from 172.16.250.11:36896
*spamApTask3: Jul 23 14:25:13.939: f4:0f:1b:3f:46:f0 WTP Event Response sent to 172.16.250.11:36896
*spamApTask3: Jul 23 14:25:14.458: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
*spamApTask3: Jul 23 14:25:14.458: f4:0f:1b:68:ae:e0 WTP Event Response sent to 172.16.250.27:30472
*spamApTask3: Jul 23 14:25:14.459: f4:0f:1b:68:ae:e0 WTP Event Request from 172.16.250.27:30472
debug capwap events disable
(Cisco Controller) >
(Cisco Controller) >debug capwap errors disable
(Cisco Controller) >debug pm pki disable
Well, this stands out: *spamApTask6: Jul 23 14:21:23.336: Unknown AP type. Using Controller Version!!!
yup, that's what I see as well. It looks like the WLC doesn't know what to do with the AP type, but 7.6.120.0 supports the 3700.
reboot the WLC and see if that fixes it. that should clear out the memory buffers.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Restarted the WLC and now I have 4 AP's joined, which is one more than before.  I think it's time to open a TAC case.
Are you using option 43 on the DHCP??, I mean Vendor Class Identifier or configuring generic Option 43 pointing to a group of WLC IP's which requires different sub option code (241 or 102) depending on the configuration that you are using.
I am mentioning this because I had a similar issue and it was the VCI not included in the DHCP Option 43 for my specific configuration.
OR if you have Win Server 2012 with the DHCP load balancing configuration then probably you do not have something properly configured on the DHCP.
I am mentioning all the previous because YOUR client configured the DHCP Server so probably he changed something.
If I have a chance tomorrow, I will post some screenshots about HOW the DHCP Server should be configured (taking into account that I am part of the group responsible for that specific configuration in the server)
regards
No, the AP's are just using DNS to resolve the IP address of the WLC.  I double checked the DHCP config and there aren't any option settings.  They are only running Windows 2003 servers as well, so nothing fancy going there.
I am not using DNS to assign the WLC to an specific AP. Configure the DHCP Option 43 is very simple. So I will post tomorrow some screenshots with the steps required in case you want to use it. I will show you as well how to change it. Not a big deal.
Important to mention that configure Option 43 is slightly different to the steps shown on this link:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/97066-dhcp-option-43.html
regards
Just a quick update.  Yesterday around 9 am, the remaining 7 AP's joined the WLC.  As far as I know, nothing has changed on the network.  I am not onsite at the client, so I could be wrong.
Now, here is another odd issue.  They also have an ISE server, which is on a different network then the WLC.  Last week, it worked fine for wireless authentication (using PEAP).  I tested again yesterday since I made a change to the ISE server and it didn't work.  I checked the logs on the WLC and it said communication to the radius (i.e. ISE) server failed.  I checked the logs on the ISE server and there wasn't anything in them about failed radius auth, so I tried to ping the WLC from the ISE server and vice versa.  Neither could ping the other.  However, each device can ping other devices on those networks and I can ping/access them both across the VPN I am using.
I am more than willing to put the DHCP option 43 in the DHCP settings.  One of my co-workers said that I should break up the AP's into their own smaller networks as this is a Cisco best practice.
Hi Deyster, give me a chance and I will send you a detailed procedure with some screenshots how to configure option 43. It is pretty simple.
I have some others ideas on which I was thinking today. Do you have HA availability configured on the AP's?. I also suggest you to enable SSH + overwrite the defaults credentials on the AP's so you can access them. Based on my experience with multiple types of AP's and IOS Versions (starting on 7.3, now I am running 7.6.122.9), HA configured directly on the controller apparently does not work properly so it is much better to do this through CLI on the AP. I will send you later some commands to do this (starting with the DEBUG CAPWAP CONSOLE CLI for configuring the AP).
On the other hand, I also have and ISE server so I have the following questions:
1.-Are you using WebAuth?. What is your version on the WLC's?
2.-Can you ping from the ISE subnet into the WLC management IP or at least the WLC default GW?
3.-Did you check that the WLC is included into the ISE Devices with the radius key so they can authenticate each other ?(you need to include the ISE with the radius key in the WLC authentication/authorization part).
4.-What was the change you made on ISE?
5.-Access your ISE through CLI (not GUI) and check the Default Gateway IP and mask, name servers IP, etc etc.
thanks
I got the issue with the communication between ISE and WLC fixed.  The core switch they are running only allows for 6 ports in a port channel.  I thought I had configured all 8 that are connected to the core to be in the port channel.  Apparently, I missed two and they were access ports.  Since I couldn't add them (I tried, but it failed with an error), I shut them down.  Once those ports were shut down, the WLC could ping the ISE and vice versa.  I am surprised this issue didn't creep up earlier, but that's how this goes.
I am hoping this also resolves the AP join issue, but time will tell.
I did set up SSH access to the AP's.
I do not have HA availability configured on the AP's as this is a single controller deployment.
Let me know if you are still interested on the procedure for the Option 43.
By the way, we have changed the WLC's versions so many times recently due to some bugs so let us know what is the version you are running.
Nice that you could solve your issue.
Attached the procedure for DHCP OPTION 43 on Win Server 2003, hope this helps.
regards
You should of seen errors on the CORE if you had all 8 connected and only 6 on an etherchannel.  That will cause issues with AP join and clients not connecting and obtaining DHCP, etc.
Scott
-Scott
