AP's not joined in WLC 2504
ndsivaguru
Have Cisco WLC 2504 in HA, I tried to connect the Access point CISCO AP AIR-LAP1131AG-E-K9. Access point have taken IP address from DHCP server and able to ping from WLC.
In WLC it's not joined well. Is this AP model support or not by WLC?
In WLC found the log message like "nterference Profile Failed for Base Radio MAC: 7c:0e:ce:b9:10:80 and slotNo: 0"
WLC software version is 7.6.130.0, Already 3 AP's are connected and working fine.
Sivaguru D
Saurav Lodh
Level 7
Level 7
https://supportforums.cisco.com/discussion/11099501/cisco-4402-lap1131-interference-profile-failed-base-radio-mac
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Initially it was not joined in WLC, we are format (factory reset) the AP then it will connected successfully.
Thanks for your info.
Sivaguru D
Sandeep Choudhary
Yes this AP support WLC 2504 with 7.6.130.0 image.
Paste the output of these:
From WLC: sh sysinfo
From AP: sh version
also paste the complete bootup process from AP console.
Don't forget to rate helpful posts
Abhishek Abhishek
Please refer to the link for troubleshooting AP not joining WLC-
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/99948-lap-notjoin-wlc-tshoot.html
