Showing results forĀ
Search instead forĀ
Did you mean:Ā
AP's won't connect to controller
wbo000001
I'm new to the Cisco Wireless products. We acquired a Cisco 2504 wireless controller and a couple of Cisco Aironet 1602i AP's.
I was abled to configure the controller, but the AP's won't join.
This is what the AP's spit at me when I connect to the console:
*Mar  1 00:01:43.606: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_Wi
Fi_Controller'running version 7.0.220.0 is rejected.
*Mar  1 00:01:43.606: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:43.606: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m
essage type 2 state 2.
*Mar  1 00:01:43.606: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Mar  1 00:01:43.606: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap p
acket from 192.168.102.72
e from controller
The version of the software of the AP's is 15.2. The controller has software version 7.0.220.0.
What is causing these messages?
Wim
Rasika Nayanajith
Rasika Nayanajith
1600 AP require 7.4.x.x WLC software. So upgrade your 2504 & try this.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Rasika
Updating the controller to version 7.4.100.0 resolved the problem. The AP's have all connected to the controller.
Thanks for you help!
Abhishek Abhishek
As per your query i can suggest you the following solution-
Please upgrade your 2504 and then try to join the AP’s.
Hope this will help you.
