AP Statistics for C9800-40 Wireless Controller
Bill
Level 6
Level 6
We have a C9800-40 running version 17.9.3
I’m looking to see if there are AP Statistics like the old WLC 5508 had.
With the 5508 there were AP Usage and Throughput statistics.
I am not finding that with the 9800.
Are those statistics available on the 9800 ?
I we can enable AP Statistics, but that is for CPU and memory.
I’m not finding throughput statistics.
5 Replies 5
Mark Elsen
 - Ref : https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/2-2-3/release_notes/b_cisco_dna_center_rn_2_2_3.html
                      Looks like DNA center may provide this
AP - Usage and Client Breakdown
This release supports a new AP - Usage and Client Breakdown report. This report provides analytics data about total usage through selected access points and breakdown of the clients and traffic by OS types, SSID, and VLAN.
  • Supported report file formats include PDF, CSV, TDE, and JSON......
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks for the Reply.
I noticed that too,
Unfortunately, we do not have DNAC.
Leo Laohoo
sh ap summary load-info
dmetheny
Community Member
You can see AP statistics by going to Monitoring > Wireless > AP Statistics, then selecting the AP you want to view statistics for towards the bottom of the pop-up window.  It isn't formatted the same as the 5508, but it provides some decent radio utilization data.
Hope this helps!
Ambuj M
lot of good suggestions, would also recommend these set of command on 9800 for monitoring key KPIs for APs.
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/217738-monitor-catalyst-9800-kpis-key-performa.html#anc4
-hope this helps-
