Ap taking ip from wrong vlan
Muhammad.nabeelch
Frequent Visitor
Frequent Visitor
Hi everyone. I am facing an issue. We have 2 networks (2 3850). Vlan 17 for wireless (aruba)and vlan 18 for wired. Both networks have different internet connection. Both switches are connected to a 2960 to connect to a remote switch 2960 through fiber for monitoring purpose. But all the APs (vlan 17) start taking ip from vlan 18 and wired clients start taking ip from vlan 17. Physical connectivity has been verified. Sometimes they will take correct ip. I even tried to remove vlan 18 and interface vlan 18 from the 2960s but still the problem exists. Can anyone please help. Dhcp are configured in peplink load balancer. Thanks.
Mark Elsen
 - Make sure the access points are in the correct vlan (or assigned to the correct vlan) , when starting up.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
balaji.bandi
Check WLAN configuration to make sure you bind the right VLAN.
BB
