AP Templates and WLAN Override
ecornwell
Level 2
Level 2
I've been trying to use AP Templates and set multiple settings on different groups of AP's. One of the settings I really want to use is WLAN Override. I can set the template up but when I apply it to an AP and reboot the AP, only one of the two WLANs I selected is checked. If I go into each AP and select it manually then reboot it, it works just fine.
Has anyone else had the same problem? It's kind of a pain to go out and set everything manually. We're trying to work out a few templates so we can quickly deploy new AP's when needed.
Thanks!
Eric
ecornwell
Level 2
Level 2
I figured out the problem.
We have two WLC's and they WLAN ID's were out of sync between the two. When I fixed this problem, the ap templates have worked fine ever since.
