AP will not join to the controller
suse_x001
Community Member
I have a WLC5760 that currently has 55 APs connected to it. Recently I tried to add another AP but I'm receiving the following error.
*spamApTask1: 1 wcm:  %LWAPP-3-RD_ERR8: Country code (US ) not configured for AP bc:c4:93:68:47:70
I have changed the country code from DE to US and the last AP works but none of the previously 55 AP will work.What country code should I use that will support all the devices?
hajia
Could you provide your AP's Part Number, like this AIR-CAP3702I-H-K9.
And if your APs belong to different country, then they'll never join to the same controller.
suse_x001
Community Member
We have the below two models:
Air-CAP2602I-E-K9
AIR-CAP2602I-A-K9
Refer this document to find right regulatory domain for country these AP deployed
http://www.cisco.com/c/en/us/products/collateral/wireless/access-points/product_data_sheet0900aecd80537b6a.html
It is not recommend to configure country belong to different regulatory domain in the same controller (due to sub optimal power & channel assignment).
In order to solve your problem, you need to configure required country codes on your WLC
5760(config)#ap country ?
WORD Enter the country code (e.g. US,MX,IN) upto a maximum of 20 countries
5760#show wireless country configured
Rasika
*** Pls rate all useful responses ***
