AP
paltel
Level 5
Level 5
I search for A Cisco AP that support security features. such that 802.1x, WPAv2, and also mac authentication. from the client side, for the WPA v2 working normally i think need to upgrade the driver for the client wireless adapter, right?
mchin345
Level 11
Level 11
In the following URL, select each APs individually. You will get a section called Data Sheets which will have a snap shot of all supported features in each Access point.
http://www.cisco.com/en/US/products/hw/wireless/index.html#products
