11-17-2003 03:08 AM - edited 07-04-2021 09:09 AM
i have problems with PDT Symbols 6100 and AP 1100.
They can roaming between 2 APs 3 or 4 times per minutes and then there is many PDT working at the same time they lose the connexion to the AP.
I can't change any parameters on the PDT so what can i do on then AP?
11-30-2003 11:54 PM
Have you been able to resolve this issue - as we are experiencing a similar problem?
thanks
12-01-2003 09:08 AM
sounds like your problem is that your roaming, then when you roam to an ap with a few people working off of you lose your connection.
You may want to do a Site Survey and check the coverage there when everyone is working off of those access points.
Worst case senario, is that you would have to add an access point to that area.
