AP1100 - Multiple SSID/VLAN connection problem
ostewart
Community Member
I've configured multiple SSID with associated VLANs for internal and external network connections, but I'm having a problem connecting to the non-advertised internal network SSID. I can only connect to the advertised SSID in either case. Does anyone have any suggestions.
rfrost
Community Member
I've had the same problem with similar configuration using Netgear wireless cards. The integrated wireless in our Dell laptops works just fine. I've had a long term case with Netgear trying to solve it, they finally bought the same type of access point to test and said it worked fine. They still haven't solved my problem and frankly I don't think they're going to.
