AP1100 Wireless Administration
nrousseau
I've installed an AP1100 and a Wireless client (AIR-PCI352).
When I run ACU, all seems ok, I can see the AP etc..., all tests are ok too with 95%/100% signal.
I can ping the AP to (10.0.0.1)
Here is my problem :
Under Internet Explorer, when I type 10.0.0.1, i get the Login/password window, enter login + password, and get nothing 😞 only a blank window, no message and no Express Setup window.
I don't have the problem if I plug an Ethernet cable between my pc and AP.
Is it a default security to prevent wireless administration task ? if yes, could it be bypassed ?
Thanks for help.
nrousseau
Ok, problem fixed upgrading Ndis Driver to 8.3 from Cisco Aironet Client Adapter Installation Wizard version 1.1 package.
