AP1131 can't connect to vWLAN Controller
John Bachman
Hello experts,  I am setting up a new vWLAN Controller version 8.0.152.0  with AP1131AG access points.
The controller address is 172.16.10.5
the 2811 router is configured as
ip dhcp pool AP
network 172.16.10.0 255.255.255.0
default-gateway 172.16.10.1
option 43 hex f104.ac10.oa05
option 60 ascii "Cisco AP 1131"
dns-server 172.16.10.1
The error I get is: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
here is the boot log: Can you please assist ? thank you.
Username:
Username: Xmodem file system is available.
flashfs[0]: 26 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 5280256
flashfs[0]: Bytes available: 10718720
flashfs[0]: flashfs fsck took 28 seconds.
Base ethernet MAC Address: 00:24:97:6e:2d:74
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1130-k9w8-mx.124-25e.JAP12/c1130-k9w8-mx.124-25e.JAP12"...#########################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1130-k9w8-mx.124-25e.JAP12/c1130-k9w8-mx.124-25e.JAP12" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1130 Software (C1130-K9W8-M), Version 12.4(25e)JAP12, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Fri 20-Oct-17 23:02 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[2]: 26 files, 8 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 15740928
flashfs[2]: Bytes used: 5280256
flashfs[2]: Bytes available: 10460672
flashfs[2]: flashfs fsck took 4 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
Radio0  present A506 7100 E8000000 A0000000 80000000 3
Rate table has 12 entries (0 SGI/0 BF variants)
Radio1  present A506 6700 E8000100 A0040000 80010000 2
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
%Error opening flash:/c1130-rcvk9w8-mx/info (No such file or directory)cisco AIR-LAP1131AG-A-K9 (PowerPCElvis) processor (revision B0) with 27638K/5120K bytes of memory.
Processor board ID FTX1315T21N
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 8.0.141.32
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:24:97:6E:2D:74
Part Number                          : 73-8962-14
PCA Assembly Number                  : 800-24818-13
PCA Revision Number                  : A0
PCB Serial Number                    : FOC13142Q02
Top Assembly Part Number             : 800-29230-02
Top Assembly Serial Number           : FTX1315T21N
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1131AG-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:05.456: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:07.070: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:07.546: %LINK-6-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:08.734: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:08.807: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:08.834: %LWAPP-4-CLIENTEVENTLOG: Read and initialized AP event log (contains, 986 messages)
*Mar  1 00:00:11.116: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:11.117: %SNMP-5-COLDSTART: SNMP agent on host AP0024.976e.2d74 is undergoing a cold start
*Mar  1 00:55:23.257: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:55:23.257: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:55:23.257: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:55:23.493: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:55:23.493: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to resetlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:55:24.257: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:55:24.257: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:55:26.061: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:55:31.383: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.10.93, mask 255.255.255.0, hostname AP0024.976e.2d74
*Mar  1 00:55:41.877: Logging LWAPP message to 255.255.255.255.
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (172.16.10.1) [OK]
Translating "CISCO-LWAPP-CONTROLLER"...domain server (172.16.10.1) [OK]
*Mar  1 00:55:52.919: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.10.5 obtained through DHCP
*Mar  1 00:55:52.919: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:55:55.582: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:55:56.614: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:55:57.614: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:55:57.653: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:55:58.654: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Not in Bound state.
The AP recycles and assign itself a new dhcp address each time/cycle...
50 Replies 50
@John Bachman wrote:
License State: Active, Not in Use, EULA not accepted
There's the issue right there.
vWLC means that the license needs to be activated before a single AP can join.
And since the EULA wasn't accepted, this means that no license is enabled.
Cisco WLC Licensing
Thank you Leo, I have accepted  the license aggrement, but still have the exact same issue, same errors in logs.
%CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
%CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
Then the AP keeps requesting a new IP address from DHCP!
Dont know if it makes a difference, as I was saying this AP 1131 was converted from Autonomous to Lightweight AP
I still have 2 more AP1131 that are still Autonomous mode, I can try to convert another one.
Here is the procedure I used to convert, (taken on the Cisco website):
  • I configured the BVI1 interface on the AP to IP 10.10.10.102 DGW 10.10.10.1
  • Set the TFTP server on 10.10.10.1, root directory to C: and put the c1140-k9w8-tar.124-25d.JA.tar in that directory
  • Then from the console port, I typed ap#archive download-sw /force-reload /overwrite tftp://10.10.10.1/c1140-k9w8-tar.124-25d.JA.tar
(Cisco Controller) >show license all
License Store: Evaluation License Storage
StoreIndex:  0  Feature: base-ap-count                     Version: 1.0
        License Type: Evaluation
        License State: Active, In Use
            Evaluation total period:  8 weeks  4 days
            Evaluation period left:  8 weeks  3 days
            Expiry date: Fri Apr  5 08:50:57 2019
        License Count: 200 /200 (Active/In-use)
        License Priority: Low
And how many AP license have been activated on the vWLC.  By default & because it's a vWLC, 0 AP license is the starting value.
Next, console into the AP and enter the following command:  capwap ap primary-base <WLC Name> <WLC IP address>
Thank you Leo, In MONITOR -  SUMMARY  It says 200 AP supported.
I have entered the command for primary-base, I get the same errors. It says it can't discover the WLC with the IP address the DHCP server has assigned, so it tries to renew the IP on and on ...
AP0024.976e.2d74#capwap ap primary-base Cisco_1e:ca:ad 172.16.10.5
AP0024.976e.2d74#
Feb  5 11:17:46.688: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Feb  5 11:17:51.695: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
Feb  5 11:17:51.815: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.20.112, mask 255.255.255.0, hostname AP0024.976e.2d74
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (172.16.20.1) [OK]
Translating "CISCO-LWAPP-CONTROLLER"...domain server (172.16.20.1) [OK]
Feb  5 11:17:57.689: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.10.5 obtained through DHCP
Feb  5 11:17:57.689: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
Not in Bound state.
Feb  5 11:18:43.205: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Feb  5 11:18:48.211: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
Feb  5 11:18:48.332: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.20.113, mask 255.255.255.0, hostname AP0024.976e.2d74
Feb  5 11:18:54.206: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.10.5 obtained through DHCP
Feb  5 11:18:54.206: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
 I have upgraded 2nd AP1130 from Autonomous to LW, here is the reboot log
I have the same error, also tried a 3rd AP1131, this time using the rvck image with same issue
Must me something the AP is not getting for the DHCP or the vWLAN Controller to attach...
here is the reboot log of the 2nd AP1130 immediately after the upgrade to LW:
APc47d.4f2f.3524#
APc47d.4f2f.3524#
APc47d.4f2f.3524#Xmodem file system is available.
flashfs[0]: 24 files, 8 directories
flashfs[0]: Bytes used: 5287936
flashfs[0]: Bytes available: 10711040
Base ethernet MAC Address: c4:7d:4f:2f:35:24
Reset done!
executing...
           cisco Systems, Inc.
flashfs[2]: 24 files, 8 directories
flashfs[2]: Bytes used: 5287936
flashfs[2]: Bytes available: 10452992
export@cisco.com.
%Error opening flash:/c1130-k9w8-mx.124-25e.JA1/info (No such file or directory)
Processor board ID FTX1346N1CD
2 802.11 Radio(s)
Base ethernet MAC Address: C4:7D:4F:2F:35:24
PCB Serial Number                    : FOC13452SVC
Top Assembly Part Number             : 800-29144-03
Top Assembly Serial Number           : FTX1346N1CD
Product/Model Number                 : AIR-LAP1131AG-A-K9
*Mar  1 00:00:05.460: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:06.956: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:08.620: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:08.692: %LINK-6-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:08.721: %LWAPP-4-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:09.778: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to upcapwap_read_version_info: Info file flash:/c1130-k9w8-mx.124-25e.JA1/info not find
*Mar  1 00:00:11.208: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:11.209: %SNMP-5-COLDSTART: SNMP agent on host APc47d.4f2f.3524 is undergoing a cold start
*Mar  1 00:12:41.253: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:12:41.253: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:12:41.253: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:12:41.489: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:12:41.489: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to resetlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:12:42.255: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:12:42.255: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:12:44.063: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:12:49.376: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.10.114, mask 255.255.255.0, hostname APc47d.4f2f.3524
*Mar  1 00:12:59.767: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:13:10.810: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.10.5 obtained through DHCP
*Mar  1 00:13:10.810: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:13:13.457: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:13:14.491: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:13:15.491: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:13:15.530: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:13:16.530: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Not in Bound state.
*Mar  1 00:14:07.331: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:14:12.338: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:14:12.458: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.10.115, mask 255.255.255.0, hostname APc47d.4f2f.3524
*Mar  1 00:14:13.488: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:14:18.331: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.10.5 obtained through DHCP
*Mar  1 00:14:18.331: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
Go to Management > Software Activation > Licenses.
Under Base-AP-Count how many APs are allowed?
Thank you Leo, here is a screenshot of the License Detail
License Detail
Name                base-ap-count
Type                evaluation
Version             1.0
Comment
Status              In Use
Expires             8 weeks, 3 days
Built-In License    Yes
Maximum Count       200
Counts Used         200
Priority Low High   Low
Make sure the WLC has the correct time and date. 1 minute error is reason enough to stop the APs from joining.
Make sure NTP is configured.
John,
Please change the following commands on the router for DHCP options:
option 43 hex f104.ac10.oa05 to option 43 hex f104ac100a05
option 60 ascii "Cisco AP 1131" to option 60 ascii "Cisco AP c1130"
Thank you Srkala
The typo with o and 0 was fixed a long time ago.
when I enter f104ac100a05, the router adds the dots between the octet, and changes it to f104.ac10.0a05
I have added the option 60, it did not make a difference.
Here is the config from the 2811
AP are in 172.16.20.0/24
vWLAN is in 172.16.10.0/24
full connectivity between VLANs, internet access and NTP tested,
ip dhcp pool APs
   network 172.16.20.0 255.255.255.0
   default-router 172.16.20.1
   dns-server 172.16.20.1
ip dhcp pool dot10_net
   default-router 172.16.10.1
   option 43 hex f104.ac10.0a05
   dns-server 8.8.8.8
ip domain name homelab.local
ip host CISCO-LWAPP-CONTROLLER 172.16.10.5
ip host CISCO-CATWAP-CONTROLLER 172.16.10.5
ip host CISCO-CAPWAP-CONTROLLER 172.16.10.5
ip name-server 4.2.2.5
ip name-server 4.2.2.6
Ok, I've got a few more tricks up my sleeves.
Can you please console into the AP and post the complete output to the command "dir".
Thank you Leo, here the flash directory
The AP was defaulted (20sec++ mode button with power applied) when I migrated from autonomous a LWAPP
Directory of flash:/
    2  -rwx           0   Mar 1 2002 00:55:41 +00:00  config.txt
    3  -rwx         190   Mar 1 2002 00:00:09 +00:00  env_vars
    7  drwx         320   Mar 1 2002 00:55:19 +00:00  c1130-k9w8-mx.124-25e.JAP12
    5  -rwx        6168   Mar 1 2002 00:55:41 +00:00  private-multiple-fs
    6  drwx           0   Mar 1 2002 00:55:42 +00:00  configs
    4  -rwx           5   Mar 1 2002 00:05:36 +00:00  private-config
   34  -rwx       91739   Mar 1 2002 01:02:52 +00:00  event.log
15740928 bytes total (10460672 bytes free)
Hi There,
How many AP's are currently associated to the WLC?
hello Jürgen
this is a LAB system and I’m trying to connect the first AP.
(Nuts.  No RCV folder.)
Ok, no go HERE and download the WIRELESS LAN LWAPP RECOVERY file (c1130-rcvk9w8-tar.124-25e.JAP12.tar)
Format the flash of the AP and unpack the RCV file to the AP.
Here's how it's done:
1.  Console into the AP;
2.  In enable mode, enter the command "deb cap con cli".
3.  Format the flash using the command "format flash:"
4.  This will take about 5 to 10 minutes;
5.  Once the flash has been complete, unpack the RCV from the TFTP server to the AP (make sure the AP has an IP address) using the command "archive tar /x tftp://<TFTP_IP_ADDRESS>/c1130-rcvk9w8-tar.124-25e.JAP12.tar flash:"
6.  Reboot
