AP1200 bootstrap problem
raymond.l
Community Member
I got an AP1200 which can only load the sytem bootstrap. Details as follow:
c -- Copy file
f -- File dir
l -- downLoad file into DRAM
u -- Upload file
p -- xfer Protocol
n -- coNsole
r -- Run
s -- System info.
s
System ID: (Not shown in the forum)
Motherboard: IBM405 200MHz, 8192KB FLASH, 16384KB DRAM, Revision 04
Bootstrap Ver. 1.00: FLASH, CRC 1C914641 (OK)
Initialization: OK
f
Memory Bank total used left
DRAM 16742624 0 16742624
Config 524288 0 524288
FLASH 7602176 0 7602176
Memory Bank:File address size encoding type flags
So there's nothing inside, then I tried to follow the guidelines from http://www.cisco.com/en/US/products/hw/wireless/ps441/products_tech_note09186a0080093c37.shtml to load image files into DRAM. When the transfer completed in Hyper-terminal, it still showed
My task is to upgrade this AP device to Cisco ISO. Any ideas what I can do? Thanks!!!
raymond.l
Community Member
Sorry everyone, I solved the problem by using AP1200-Cisco-IOS-Upgrade-Image-v3.img downloaded from Cisco and it works fine now.
