AP1200 Duplicate IP Issue
kevinchan
Level 2
Level 2
Hi All,
Just want to see if anybody is having the same issue...
Wireless Subnet with 50+ AP1230s were rebooted due to power failure...
Once rebooted; I notice numerous AP1230s have duplicated IP of other APs in the same subnet.
It almost seems like the APs are answering to the DHCP offer that's not directed to them.
any clue?
Kevin Chan
Not applicable
Try to find if there is some device that is wired to the network, which also has a built-in wireless card that is activated. If so, disable the wireless card and then the isssue might be sloved.
