ap1200 ios recovery, please help...
after1111
hello everyone...
ive deleted the IOS on my wilress ap1200 ( flash:/c1200-k9w7-mx.122-13.JA4/c1200-k9w7-mx.122-13.JA4). ived tried to upload via tftp but unsuccessful. I cant access through the web brower.
when i restart my AP, this is the prompt:
ap:
ive entered the following information:
ap: set IP_ADDR 192.168.133.160
ap: set NETMASK 255.255.255.0
ap: set DEFAULT_ROUTER 192.168.133.1
Do i need to unzip the ios image file? When i unzip the IOS image file (e.g. c1200-k9w7-tar.122-15.JA) there are many files and sub-folders.
my ap1200 use IOS not Vxworks (what is VXworks - do i need to convert the image file before upload?)
Please direct me tot he right document. Any help would be greatly appreciate.
tran
4t-baron
Read my reply posted on May 4th for the same issue, ap 1200 lost ios.
Following is the proper command that you should use for a regular IOS upgrade with a .tar file on these Aironet devices:
ap#archive download-sw /overwrite /force-reload tftp://IP Address of the PC/the name of the IOS image you downloaded, even with the .tar extension.
Please check the below link for more info:-
https://supportforums.cisco.com/t5/wireless-mobility-documents/cisco-aironet-access-points-ios-recovery/ta-p/3123138.
