ap1200 ios12.3(4)JA SNTP PROBLEMS
yong1794
After Upgrading IOS 12.3(4)JA. AP time is not Synchronized with SNTP server.
what's different with NTP and SNTP?
a-vazquez
Level 6
Level 6
The main difference between SNTP and NTP is that SNTP doesn't provide the error-check and filtering functions that NTP provides.
jmatuscak
In 12.3.4 at least for time synching with NTP broadcasts, the SNTP client does not work correctly with a NTP V4 server. If you force your NTP server to respond as being V3, the client synchs. It may be the same for unicast traffic as well.
