AP1231G And Linksys WUSB54G
logintck
HI
I buy a new AP1231G as our offce wireless hub and buy some Linksys WUSB54G (USB wireless adaptor of our Notebooks)
When I configurate the SSID, Encryption level. So I try to connect to wireless hub with the notesbook.
I found some problems
1. Although the the connection is established (according to AP1231 console information) the notesbook can't been assign the IP, in the others word, the notebook can't find the DHCP server. IP address of notebook is 169.xxx.xxx.xxx ( I have double checked the setting of WEP, SSID) Any idea to solve it?
2. From the Console of AP1231G. it recongine the linksys adaptor as repeator. not a Client. Is it correct?
Thx for your help
john.gudmann
I have seen the same with Intramec scanner (PDA Client)
Tray to switch off the Aironet extension
(in cli type "no dot11 extension aironet")
