AP1242 Autonomous AP Authentication for MS-CHAP
munshingtham
Hi all,
I have a requirement for a printer server for authenticating by using WPA2-PEAP-MSCHAPv2 with certificate on one of my customer site.
Since there are no Printer Server that supported WPA2, I would like to configure my AP1242 as WGB and do the same job as required.
I checked on AP1242, there is a column for configuring AP Authentication via the Uplink SSID port. But I do not know how to configure it by referring to the manual..... Is there any configuration guide for that? Or guide can be given to me?
At the same time, there is some date validity on teh certificate as well. So, how do I set the date if ever that the WGB is turned off.
Thank you.
Tham ms
smalkeric
Level 6
Level 6
Have a look at this document for configuring Ms-Chap:
http://www.cisco.com/en/US/docs/ios/11_3/feature/guide/MSCHAP.html
