AP1562 is not joining WLC9800
night143r
Hi all,
2 of our 1562 APs are not joining WLC9800. When consoled to AP found out that AP is going to U-Boot and keeps rebooting instead to finding controller. Already tried to reset env and changed partitions
Here is the complete output of AP console.
BootROM - 1.78
Booting from SPI flash, Secure mode
BootROM: RSA Public key verification PASSED
BootROM: CSK block signature verification PASSED
BootROM: Boot header signature verification PASSED
BootROM: Box ID verification PASSED
BootROM: JTAG is disabled
General initialization - Version: 1.0.0
Detected Device ID 6920
Master bootloder version 1.44
High speed PHY - Version: 2.0
BoardId = 0x23board SerDes lanes topology details:
| Lane # | Speed| Type |
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
:** Link is Gen1, check the EP capability
PCIe, Idx 1: Link upgraded to Gen2 based on client cpabilities
PCIe, Idx 2: Link upgraded to Gen2 based on client cpabilities
High speed PHY - Ended Successfully
DDR4 Training Sequence - Ver TIP-0.23.(Sublib 0.8)0
DDR4 Training Sequence - Switching XBAR Window to FastPath Window
DDR4 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
BootROM: Boot image signature verification PASSED
____ _
/ ___|(_) ___ ___ ___
| | | |/ __| / __|/ _ \
| |___ | |\__ \| (__| (_) |
\____||_||___/ \___|\___/
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
** LOADER **
U-Boot 2013.01-g2ee3a18aa (Jun 03 2022 - 11:27:17) SDK version: 2015_T2.0p10
Board: Milos
SoC: MV88F6920 Rev A1
running 2 CPUs
CPU: ARM Cortex A9 MPCore (Rev 1) LE
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DDR4 32 Bit Width,FastPath Memory Access, DLB Enabled, ECC Disabled
DRAM: 1 GiB
RST I2C0
NAND: ECC 4bits, 256 MiB
SF: Detected MX25L3205D with page size 64 KiB, total 4 MiB
PCI-e 1 (IF 0 - bus 0) Root Complex Interface, Detected Link X1, GEN 2.0
PCI-e 2 (IF 1 - bus 1) Root Complex Interface, Detected Link X1, GEN 2.0
Map: Code: 0x3fed8000:0x3ffae448
BSS: 0x3ffeff0c
Stack: 0x3f9c7f20
Heap: 0x3f9c8000:0x3fed8000
U-Boot Environment: 0x00100000:0x00110000 (SPI)
Board configuration:
| port | Interface | PHY address |
| egiga1 | SGMII | 0x01 |
SFP not detected, enable RJ45
Net: , egiga1 [PRIME]
Hit ESC key to stop autoboot: 0
Creating 1 MTD partitions on "nand0":
0x000000200000-0x000010000000 : "mtd=2"
UBI: attaching mtd1 to ubi0
UBIFS: recovery needed
UBIFS: recovery deferred
UBIFS: mounted UBI device 0, volume 0, name "part1"
Loading file 'part1/part.bin' to addr 0x02000000 with size 6278893 (0x005fceed)...
Done
Checking image signing.
Image signing verification success, continue to run...
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Barbados Firmware Image
Created: 2022-02-26 10:37:07 UTC
Image Type: ARM Linux Multi-File Image (uncompressed)
Data Size: 6277885 Bytes = 6 MiB
Load Address: 00008000
Entry Point: 00008000
Contents:
Image 0: 4202696 Bytes = 4 MiB
Image 1: 2059035 Bytes = 2 MiB
Image 2: 16137 Bytes = 15.8 KiB
Verifying Checksum ... OK
## Loading init Ramdisk from multi component Legacy Image at 02000000 ...
## Flattened Device Tree from multi component Image at 02000000
Booting using the fdt at 0x025f8c34
Loading Multi-File Image ... OK
OK
reserving fdt memory region: addr=0 size=4000
Loading Device Tree to 01ff9000, end 01ffff08 ... OK
Starting Device Tree update ('fdt_skip_update' = no)
Limit DDR size at 3GB due to power of 2 requirement of Address decoding
Updating device tree successful
Starting kernel ...
[01/01/1970 00:00:00.0000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
[01/01/1970 00:00:00.0000] Memory: 1025864K/1048576K available (5743K kernel code, 411K rwdata, 2480K rodata, 359K init, 496K bss, 22712K reserved, 0K highmem)
[01/01/1970 00:00:00.1200] CPU1: Booted secondary processor
[01/01/1970 00:00:01.4300] buginf tty flushing thread started, ttyport=be929400
[01/01/1970 00:00:01.5500] m25p80 spi1.0: found mx25l3206, expected n25q032
[*01/01/1970 00:00:02.6309] buginf() enabled.
[*01/01/1970 00:00:02.6406] Made it into bootsh: Feb 26 2022 10:29:25 T-cf8ab999456c0f09e519bc838ef8a46f3f3edbbf-gcf8ab999-aut
[*01/01/1970 00:00:10.4417] bootsh mini ramfs booted /bootpart/part1/ramfs_data_cisco.cpio.lzma
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
[*01/01/1970 00:00:32.6094] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:32.6125] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:32.6156] /init: reading file /storage/config: No such file or directory
[*01/01/1970 00:00:32.6471] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:32.6502] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[ OK ] Reached target Timers.
[ OK ] Created slice -.slice.
[ OK ] Created slice system.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-sshd\x2dkeygen.slice.
[ OK ] Listening on udev Control Socket.
[ OK ] Reached target Slices.
[ OK ] Listening on Delayed Shutdown Socket.
Starting Cisco UBIFS reformat/mount...
[ OK ] Listening on udev Kernel Socket.
Starting udev Kernel Device Manager...
[ OK ] Reached target Sockets.
[ OK ] Reached target Cisco File Systems (Pre).
Starting udev Coldplug all Devices...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Cisco UBIFS reformat/mount.
Starting Cisco early mount...
[ OK ] Started Cisco early mount.
[ OK ] Reached target Local File Systems (Pre).
Starting Cisco system time setup...
Starting Cisco platform file generation...
Starting Cisco fips check...
Starting Cisco seed generation...
[*08/14/2021 23:59:59.0758] Last reload time: Oct 28 21:40:50 2022
[*10/28/2022 21:40:50.0004] Setting system time Fri Oct 28 21:40:50 UTC 2022
[ OK ] Started Cisco system time setup.
[ OK ] Started Cisco seed generation.
[ OK ] Started Cisco fips check.
[ OK ] Started Cisco platform file generation.
Starting Cisco btldr service...
[*10/28/2022 21:40:51.2825] GCM-128 POST passed
[*10/28/2022 21:40:51.2825] GCM-256 POST passed
[ OK ] Started Cisco btldr service.
[ OK ] Reached target Local File Systems.
Starting Security Auditing Service...
[*10/28/2022 21:40:52.8084] parameter passed without an option given
Starting Cisco S10 boot service...
[ OK ] Started Cisco system time saving.
Starting Cisco system time saving...
Starting Cisco act2 check...
Starting Cisco pkg install service...
[*10/28/2022 21:40:53.1701] 0
[ OK ] Started udev Coldplug all Devices.
[*10/28/2022 21:40:53.2738]
[*10/28/2022 21:40:53.2738] (write)Unable to open I2C device interface (/dev/act2) for ACT2 (file = -1)
[*10/28/2022 21:40:53.2738] (write)Unable to open I2C device inte[10/28/2022 21:40:53.9500] PCI: enabling device 0000:00:02.0 (0140 -> 0143)
rface (/dev/act2[10/28/2022 21:40:54.0500] PCI: enabling device 0000:02:00.0 (0140 -> 0142)
[*10/28/2022 21:40:53.2745]
[*10/28/2022 21:40:53.2745] (ACT2Boot) Hardware is NOT Cisco (c) authentic
[*10/28/2022 21:40:53.2745] System will reboot in 10 seconds ...
[*10/28/2022 21:40:53.3785] Active version: 17.3.5.42
[*10/28/2022 21:40:53.3813] Backup version: 17.9.2.52
[*10/28/2022 21:40:53.5981]
[*10/28/2022 21:40:53.5981] led pattern module start
[*10/28/2022 21:40:53.7267] device wired0 entered promiscuous mode
[*10/28/2022 21:40:54.1504] wifi0: Initializing TX ring
[*10/28/2022 21:40:54.1592] wifi0: prepare firmware downloading
[ OK ] Started Security Auditing Service.
[ OK ] Started Cisco pkg install service.
[10/28/2022 21:40:57.8300] PCI: enabling device 0000:00:03.0 (0140 -> 0143)
[10/28/2022 21:40:57.9100] PCI: enabling device 0000:03:00.0 (0140 -> 0142)
[*** ] (1 of 2) A start job is running for Cisco act2 check (15s / 1min 5s)[*10/28/2022 21:40:54.9956] wifi0: Firmware downloading
[*10/28/2022 21:40:56.2166] 0;0;<30>systemd[1]: Started Cisco pkg install service.
[*10/28/2022 21:40:57.2364] 0;
[*10/28/2022 21:40:57.3684] Firmware download complete
[*10/28/2022 21:40:57.5624] wifi0: Getting HW specs. Retrying for 3
[*10/28/2022 21:40:57.5627] Mac_Init
[*10/28/2022 21:40:57.5630] Preparing to set HW specs
[*10/28/2022 21:40:57.5633] FIPS enc aes-ccmp Verified
[*10/28/2022 21:40:57.5634] FIPS dec aes-ccmp Verified
[*10/28/2022 21:40:57.5635] FIPS enc aes-ccmp-256 Verified
[*10/28/2022 21:40:57.5636] FIPS dec aes-ccmp-256 Verified
[*10/28/2022 21:40:57.5637] FIPS enc aes-gcmp Verified
[*10/28/2022 21:40:57.5638] FIPS dec aes-gcmp Verified
[*10/28/2022 21:40:57.5639] FIPS enc aes-gcmp-256 Verified
[*10/28/2022 21:40:57.5641] FIPS dec aes-gcmp-256 Verified
[*10/28/2022 21:40:57.9950] wifi1: Initializing TX ring
[*10/28/2022 21:40:58.0030] wifi1: prepare firmware downloading
[*10/28/2022 21:40:58.8219] wifi1: Firmware downloading
[*10/28/2022 21:41:00.0424] 0;0;0;0;0;0;0;
[*10/28/2022 21:41:03.1544] Firmware download complete
[*10/28/2022 21:41:03.2792] ... rebooting now!
[*10/28/2022 21:41:03.3524] wifi1: Getting HW specs. Retrying for 3
[*10/28/2022 21:41:03.3527] Mac_Init
[*10/28/2022 21:41:03.3530] Preparing to set HW specs
[*10/28/2022 21:41:03.3533] FIPS enc aes-ccmp Verified
[*10/28/2022 21:41:03.3534] FIPS dec aes-ccmp Verified
[*10/28/2022 21:41:03.3535] FIPS enc aes-ccmp-256 Verified
[*10/28/2022 21:41:03.3536] FIPS dec aes-ccmp-256 Verified
[*10/28/2022 21:41:03.3537] FIPS enc aes-gcmp Verified
[*10/28/2022 21:41:03.3538] FIPS dec aes-gcmp Verified
[*10/28/2022 21:41:03.3539] FIPS enc aes-gcmp-256 Verified
[*10/28/2022 21:41:03.3540] FIPS dec aes-gcmp-256 Verified
[*10/28/2022 21:41:04.4315] cp: can't create '/storage/syslogs/22.watchdog_status': No such file or directory
[*10/28/2022 21:41:04.4412] Last reload reason : 21:
[ OK ] Started Cisco S10 boot service.
Starting Cisco nss service...
[*10/28/2022 21:41:05.4121] Initializing NSS Firmware
Starting Cisco nolan service...
Starting Cisco watchdog...
[ OK ] Started Cisco nolan service.
[ OK ] Started Cisco watchdog.
[ OK ] Stopped target Timers.
[ OK ] Removed slice system-sshd\x2dkeygen.slice.
[ OK ] Removed slice system-serial\x2dgetty.slice.
[ OK ] Stopped target Sockets.
[ OK ] Stopped target Slices.
[ OK ] Removed slice -.slice.
Stopping Securit[10/28/2022 21:41:06.0800] audit_printk_skb: 60 callbacks suppressed
Stopping Cisco system time saving...
[*10/28/2022 21:41:06.2113]
[*10/28/2022 21:41:06.2113] Writing reload timestamp (Fri Oct 28 21:41:06 UTC 2022) to disk
Stopping Cisco nolan service...
Stopping Cisco watchdog...
[ OK ] Stopped Cisco pkg install service.
Stopping Cisco pkg install service...
[ OK ] Stopped Security Auditing Service.
[ OK ] Stopped Cisco act2 check.
[ OK ] Stopped Cisco nss service.
[ OK ] Stopped Cisco watchdog.
[ OK ] Stopped Cisco system time saving.
[ OK ] Stopped Cisco nolan service.
[ OK ] Stopped Cisco S10 boot service.
Stopping Cisco S10 boot service...
[ OK ] Reached target Shutdown.
[ OK ] Stopped target Local File Systems.
Stopping Cisco seed generation...
Unmounting /firmware...
[*10/28/2022 21:41:07.3339] systemd[5599]: Failed at step CGROUP spawning /bin/umount: No such file or directory
[ OK ] Stopped Cisco fips check.
Stopping Cisco fips check...
Unmounting /tmp...
[*10/28/2022 21:41:07.6037] systemd[5600]: Failed at step CGROUP spawning /bin/umount: No such file or directory
Unmounting /storage...
[*10/28/2022 21:41:07.7638] systemd[5601]: Failed at step CGROUP spawning /bin/umount: No such file or directory
Unmounting /sys/kernel/debug...
[*10/28/2022 21:41:07.9237] systemd[5602]: Failed at step CGROUP spawning /bin/umount: No such file or directory
[ OK ] Stopped Cisco system time setup.
Stopping Cisco system time setup...
[ OK ] Stopped Cisco btldr service.
Stopping Cisco btldr service...
[ OK ] Stopped Cisco platform file generation.
Stopping Cisco platform file generation...
[ OK ] Stopped Cisco seed generation.
[ OK ] Failed unmounting /firmware.
[ OK ] Failed unmounting /tmp.
[ OK ] Failed unmounting /storage.
[ OK ] Failed unmounting /sys/kernel/debug.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Reached target Final Step.
Starting Reboot...
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped target Cisco File Systems (Pre).
[ OK ] Stopped Cisco early mount.
Stopping Cisco early mount...
[ OK ] Stopped Cisco UBIFS reformat/mount.
Stopping Cisco UBIFS reformat/mount...
[10/28/2022 21:41:09.6100] reboot: Restarting system
BootROM - 1.78
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
Board: Milos
running 2 CPUs
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DRAM: 1 GiB
RST I2C0
BSS: 0x3ffeff0c
Stack: 0x3f9c7f20
Done
Contents:
OK
Starting kernel ...
[01/01/1970 00:00:01.4300] buginf tty flushing thread started, ttyport=be87a000
[*01/01/1970 00:00:02.6313] buginf() enabled.
[*01/01/1970 00:00:02.6409] Made it into bootsh: Feb 26 2022 10:29:25 T-cf8ab999456c0f09e519bc838ef8a46f3f3edbbf-gcf8ab999-aut
[*01/01/1970 00:00:10.3254] bootsh mini ramfs booted /bootpart/part1/ramfs_data_cisco.cpio.lzma
Welcome to Cisco.
available at:
Cisco Systems, Inc.
export@cisco.com.
[*01/01/1970 00:00:32.3500] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:32.3531] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:32.3562] /init: reading file /storage/config: No such file or directory
[*01/01/1970 00:00:32.3879] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:32.3910] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*08/14/2021 23:59:59.0792] Last reload time: Oct 28 21:41:06 2022
[*10/28/2022 21:41:06.0042] Settin[ OK ] Started Cisco system time setup.
[*10/28/2022 21:41:07.1342] GCM-128 POST passed
[*10/28/2022 21:41:07.1343] GCM-256 POST passed
[*10/28/2022 21:41:08.6260] parameter passed without an option given
[*10/28/2022 21:41:08.7363] 0
[*10/28/2022 21:41:08.9014] Active version: 17.3.5.42
[*10/28/2022 21:41:08.9043] Backup version: Starting Cisco act2 check...
[*10/28/2022 21:41:09.1392]
[*10/28/2022 21:41:09.1392] led pattern module start
[*10/28/2022 21:41:09.2403]
[*10/28/2022 21:41:09.2404] (write)Unable to open I2C device interface (/dev/act2) for ACT2 (file = -1)
[*10/28/2022 21:41:09.2404] (write)Unable to open I2C device interface (/dev/ac[10/28/2022 21:41:09.5100] PCI: enabling device 0000:00:02.0 (0140 -> 0143)
t2) for ACT2 (fi[10/28/2022 21:41:09.6000] PCI: enabling device 0000:02:00.0 (0140 -> 0142)
le = -1)
[*10/28/2022 21:41:09.2410]
[*10/28/2022 21:41:09.2410] (ACT2Boot) Hardware is NOT Cisco (c) authentic
[*10/28/2022 21:41:09.2411] System will reboot in 10 seconds ...
[*10/28/2022 21:41:09.2877] device wired0 entered promiscuous mode
[*10/28/2022 21:41:09.7046] wifi0: Initializing TX ring
[*10/28/2022 21:41:09.7136] wifi0: prepare firmware downloading
[*10/28/2022 21:41:10.5488] wifi0: Firmware downloading
[*10/28/2022 21:41:11.7698] 0;0;0;[10/28/2022 21:41:13.3900] PCI: enabling device 0000:00:03.0 (0140 -> 0143)
[10/28/2022 21:41:13.4700] PCI: enabling device 0000:03:00.0 (0140 -> 0142)
[*10/28/2022 21:41:12.9237]
[*10/28/2022 21:41:12.9237] Firmware download complete
[*10/28/2022 21:41:13.1237] wifi0: Getting HW specs. Retrying for 3
[*10/28/2022 21:41:13.1240] Mac_Init
[*10/28/2022 21:41:13.1243] Preparing to set HW specs
[*10/28/2022 21:41:13.1246] FIPS enc aes-ccmp Verified
[*10/28/2022 21:41:13.1247] FIPS dec aes-ccmp Verified
[*10/28/2022 21:41:13.1248] FIPS enc aes-ccmp-256 Verified
[*10/28/2022 21:41:13.1249] FIPS dec aes-ccmp-256 Verified
[*10/28/2022 21:41:13.1250] FIPS enc aes-gcmp Verified
[*10/28/2022 21:41:13.1251] FIPS dec aes-gcmp Verified
[*10/28/2022 21:41:13.1252] FIPS enc aes-gcmp-256 Verified
[*10/28/2022 21:41:13.1254] FIPS dec aes-gcmp-256 Verified
[*10/28/2022 21:41:13.5582] wifi1: Initializing TX ring
[*10/28/2022 21:41:13.5663] wifi1: prepare firmware downloading
[*10/28/2022 21:41:14.3855] wifi1: Firmware downloading
[*10/28/2022 21:41:15.6057] 0;0;0;0;0;0;0;
[*10/28/2022 21:41:18.7351] Firmware download complete
[*10/28/2022 21:41:18.9337] wifi1: Getting HW specs. Retrying for 3
[*10/28/2022 21:41:18.9340] Mac_Init
[*10/28/2022 21:41:18.9343] Preparing to set HW specs
[*10/28/2022 21:41:18.9346] FIPS enc aes-ccmp Verified
[*10/28/2022 21:41:18.9347] FIPS dec aes-ccmp Verified
[*10/28/2022 21:41:18.9348] FIPS enc aes-ccmp-256 Verified
[*10/28/2022 21:41:18.9349] FIPS dec aes-ccmp-256 Verified
[*10/28/2022 21:41:18.9350] FIPS enc aes-gcmp Verified
[*10/28/2022 21:41:18.9351] FIPS dec aes-gcmp Verified
[*10/28/2022 21:41:18.9352] FIPS enc aes-gcmp-256 Verified
[*10/28/2022 21:41:18.9353] FIPS dec aes-gcmp-256 Verified
[*10/28/2022 21:41:19.2443] ... rebooting now!
[*10/28/2022 21:41:20.0370] cp: can't create '/storage/syslogs/23.watchdog_status': No such file or directory
[*10/28/2022 21:41:20.0467] Last reload reason : 21:
[*10/28/2022 21:41:21.5445]
[*10/28/2022 21:41:21.5445] Writing reload timestamp (Fri Oct 28 21:41:21 UTC 2022) to disk
Stopping Securit[10/28/2022 21:41:21.7700] audit_printk_skb: 60 callbacks suppressed
Unmounting /tmp...
[ OK ] Unmounted /sys/kernel/debug.
[ OK ] Unmounted /tmp.
[ OK ] Unmounted /storage.
[ OK ] Unmounted /firmware.
Starting Reboot...
[10/28/2022 21:41:24.1500] reboot: Restarting system
BootROM - 1.78
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
Board: Milos
running 2 CPUs
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DRAM: 1 GiB
RST I2C0
BSS: 0x3ffeff0c
Stack: 0x3f9c7f20
Done
Contents:
OK
Starting kernel ...
[01/01/1970 00:00:01.4300] buginf tty flushing thread started, ttyport=be8da000
[*01/01/1970 00:00:02.6213] buginf() enabled.
[*01/01/1970 00:00:02.6310] Made it into bootsh: Feb 26 2022 10:29:25 T-cf8ab999456c0f09e519bc838ef8a46f3f3edbbf-gcf8ab999-aut
And it keeps repeating
12 Replies 12
night143r
Another AP logs are below
BootROM - 1.78
Master bootloder version 1.24
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
PCIe, Idx 2: detected no link
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
U-Boot 2013.01-gf899470 (Aug 16 2018 - 15:50:45) SDK version: 2015_T2.0p10
Board: Milos
running 2 CPUs
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DRAM: 1 GiB
RST I2C0
NAND: 256 MiB
PCI-e 1: Detected No Link.
Map: Code: 0x3fed9000:0x3ffad5c4
BSS: 0x3ffef080
Stack: 0x3f9c8f20
Heap: 0x3f9c9000:0x3fed9000
UBIFS: mounted UBI device 0, volume 1, name "part2"
Loading file 'part2/part.bin' to addr 0x02000000 with size 6335021 (0x0060aa2d)...
Done
Created: 2020-10-30 23:30:20 UTC
Data Size: 6334013 Bytes = 6 MiB
Contents:
Image 0: 4203272 Bytes = 4 MiB
Image 1: 2114585 Bytes = 2 MiB
Booting using the fdt at 0x02606774
OK
Starting kernel ...
[01/01/1970 00:00:00.0000] Memory: 1025836K/1048576K available (5743K kernel code, 407K rwdata, 2480K rodata, 359K init, 478K bss, 22740K reserved)
[01/01/1970 00:00:01.4200] buginf tty flushing thread started, ttyport=bf3d8c00
[01/01/1970 00:00:01.5400] m25p80 spi1.0: found mx25l3206, expected n25q032
[01/01/1970 00:00:03.8100] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:05.9000] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:07.9900] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:10.0800] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:12.1700] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:14.2600] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:16.3500] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:18.4400] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[*08/21/2019 15:03:57.5008] buginf() enabled.
[*08/21/2019 15:03:57.5104] Made it into bootsh: Oct 30 2020 16:21:13 T-a9e4eaf8ccf0cad1ba59eaa8794b7332dbca2d5a-ga9e4eaf8-aut
[*08/21/2019 15:04:05.2569] bootsh mini ramfs booted /bootpart/part2/ramfs_data_cisco.cpio.lzma
Welcome to Cisco.
available at:
Cisco Systems, Inc.
export@cisco.com.
[*08/21/2019 15:04:27.0737] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*08/21/2019 15:04:27.0767] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*08/21/2019 15:04:27.1133] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*08/21/2019 15:04:27.1163] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*08/14/2021 23:59:59.0883] Last reload time: Oct 15 17:23:27 2021
[*10/15/2021 17:23:27.0101] Setting system time Fri Oct 15 17:23:27 UTC 2021
[*10/15/2021 17:23:28.3826] GCM-128 POST passed
[*10/15/2021 17:23:28.3826] GCM-256 POST passed
[*10/15/2021 17:23:30.2170] parameter passed without an option given
[*10/15/2021 17:23:30.3622] 34
[10/15/2021 17:23:31.2100] PCI: enabling device 0000:00:02.0 (0140 -> 0143)
[10/15/2021 17:23:31.2900] PCI: enabling device 0000:02:00.0 (0140 -> 0142)
[10/15/2021 17:23:32.0900] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[*10/15/2021 17:23:30.6431] Active version: 17.3.2.32
[*10/15/2021 17:23:30.6468] Backup version: 8.10.130.0
[*10/15/2021 17:23:30.9037]
[*10/15/2021 17:23:30.9037] led pattern module start
[*10/15/2021 17:23:31.0105] device wired0 entered promiscuous mode
[*10/15/2021 17:23:31.3808] wifi0: Initializing TX ring
[*10/15/2021 17:23:31.3854] wifi0: Initializing RX ring
[*10/15/2021 17:23:31.3908] wifi0: prepare firmware downloading
[*10/15/2021 17:23:32.1791] wifi0: Firmware downloading
[*10/15/2021 17:23:33.4184] 0;0;
[*10/15/2021 17:23:34.0580]
[*10/15/2021 17:23:34.0580] Authenticating ACT2 ID:AP1560
[*10/15/2021 17:23:34.0580] Authenticating SN:FOC25296NZE
[*10/15/2021 17:23:34.0585]
[*10/15/2021 17:23:34.0586] (ACT2Boot) Hardware is Cisco (c) authentic
[*10/15/2021 17:23:34.0645] Seeding /dev/urandom from ACT2
[*10/15/2021 17:23:34.4944] 0;
[*10/15/2021 17:23:34.5404] Firmware download complete
[*10/15/2021 17:23:34.7278] Reading ACT2 SUDI certificates
[*10/15/2021 17:23:34.7364] wifi0: Getting HW specs. Retrying for 3
[*10/15/2021 17:23:34.7366] Mac_Init
[*10/15/2021 17:23:34.7370] Preparing to set HW specs
[*10/15/2021 17:23:34.7373] FIPS enc aes-ccmp Verified
[*10/15/2021 17:23:34.7374] FIPS dec aes-ccmp Verified
[*10/15/2021 17:23:34.7375] FIPS enc aes-ccmp-256 Verified
[*10/15/2021 17:23:34.7376] FIPS dec aes-ccmp-256 Verified
[*10/15/2021 17:23:34.7377] FIPS enc aes-gcmp Verified
[*10/15/2021 17:23:34.7378] FIPS dec aes-gcmp Verified
[*10/15/2021 17:23:34.7379] FIPS enc aes-gcmp-256 Verified
[*10/15/2021 17:23:34.7380] FIPS dec aes-gcmp-256 Verified
[*10/15/2021 17:23:35.3504] wifi1 no private ioctls.
[*10/15/2021 17:23:35.3555] wifi1 no private ioctls.
[*10/15/2021 17:23:35.3608] wifi1 no private ioctls.
[*10/15/2021 17:23:35.3658] Error for wireless request "Set Frequency" (8B04) :
[*10/15/2021 17:23:35.3659] SET failed on device wifi1 ; No such device.
[*10/15/2021 17:23:35.3715] Error for wireless request "Set ESSID" (8B1A) :
[*10/15/2021 17:23:35.3715] SET failed on device apr1v0 ; No such device.
[*10/15/2021 17:23:35.3819] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.3924] apr1v0 no private ioctls.
[*10/15/2021 17:23:35.3977] apr1v0 no private ioctls.
[*10/15/2021 17:23:35.4027] apr1v0 no private ioctls.
[*10/15/2021 17:23:35.4090] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.4143] apr1v0 no private ioctls.
[*10/15/2021 17:23:35.4194] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.4195] SET failed on device apr1v0 ; No such device.
[*10/15/2021 17:23:35.4255] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.4323] apr1v1 no private ioctls.
[*10/15/2021 17:23:35.4375] apr1v1 no private ioctls.
[*10/15/2021 17:23:35.4427] apr1v1 no private ioctls.
[*10/15/2021 17:23:35.4487] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.4541] apr1v1 no private ioctls.
[*10/15/2021 17:23:35.4592] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.4593] SET failed on device apr1v1 ; No such device.
[*10/15/2021 17:23:35.4655] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.4722] apr1v2 no private ioctls.
[*10/15/2021 17:23:35.4775] apr1v2 no private ioctls.
[*10/15/2021 17:23:35.4826] apr1v2 no private ioctls.
[*10/15/2021 17:23:35.4887] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.4941] apr1v2 no private ioctls.
[*10/15/2021 17:23:35.4993] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.4994] SET failed on device apr1v2 ; No such device.
[*10/15/2021 17:23:35.5054] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.5129] apr1v3 no private ioctls.
[*10/15/2021 17:23:35.5185] apr1v3 no private ioctls.
[*10/15/2021 17:23:35.5236] apr1v3 no private ioctls.
[*10/15/2021 17:23:35.5297] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.5350] apr1v3 no private ioctls.
[*10/15/2021 17:23:35.5402] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.5403] SET failed on device apr1v3 ; No such device.
[*10/15/2021 17:23:35.5465] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.5531] apr1v4 no private ioctls.
[*10/15/2021 17:23:35.5532]
[*10/15/2021 17:23:35.5583] apr1v4 no private ioctls.
[*10/15/2021 17:23:35.5634] apr1v4 no private ioctls.
[*10/15/2021 17:23:35.5694] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.5841] apr1v4 no private ioctls.
[*10/15/2021 17:23:35.5959] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.5960] SET failed on device apr1v4 ; No such device.
[*10/15/2021 17:23:35.6079] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.6146] apr1v5 no private ioctls.
[*10/15/2021 17:23:35.6234] apr1v5 no private ioctls.
[*10/15/2021 17:23:35.6284] apr1v5 no private ioctls.
[*10/15/2021 17:23:35.6285]
[*10/15/2021 17:23:35.6344] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.6396] apr1v5 no private ioctls.
[*10/15/2021 17:23:35.6397]
[*10/15/2021 17:23:35.6446] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.6446] SET failed on device apr1v5 ; No such device.
[*10/15/2021 17:23:35.6507] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.6573] apr1v6 no private ioctls.
[*10/15/2021 17:23:35.6625] apr1v6 no private ioctls.
[*10/15/2021 17:23:35.6676] apr1v6 no private ioctls.
[*10/15/2021 17:23:35.6738] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.6791] apr1v6 no private ioctls.
[*10/15/2021 17:23:35.6792]
[*10/15/2021 17:23:35.6843] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.6843] SET failed on device apr1v6 ; No such device.
[*10/15/2021 17:23:35.6904] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.6970] apr1v7 no private ioctls.
[*10/15/2021 17:23:35.7021] apr1v7 no private ioctls.
[*10/15/2021 17:23:35.7075] apr1v7 no private ioctls.
[*10/15/2021 17:23:35.7136] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.7189] apr1v7 no private ioctls.
[*10/15/2021 17:23:35.7190]
[*10/15/2021 17:23:35.7240] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.7240] SET failed on device apr1v7 ; No such device.
[*10/15/2021 17:23:35.7302] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.7368] apr1v8 no private ioctls.
[*10/15/2021 17:23:35.7420] apr1v8 no private ioctls.
[*10/15/2021 17:23:35.7472] apr1v8 no private ioctls.
[*10/15/2021 17:23:35.7534] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.7587] apr1v8 no private ioctls.
[*10/15/2021 17:23:35.7638] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.7639] SET failed on device apr1v8 ; No such device.
[*10/15/2021 17:23:35.7700] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.7766] apr1v9 no private ioctls.
[*10/15/2021 17:23:35.7823] apr1v9 no private ioctls.
[*10/15/2021 17:23:35.7824]
[*10/15/2021 17:23:35.7879] apr1v9 no private ioctls.
[*10/15/2021 17:23:35.7942] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.7995] apr1v9 no private ioctls.
[*10/15/2021 17:23:35.8046] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.8047] SET failed on device apr1v9 ; No such device.
[*10/15/2021 17:23:35.8109] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.8176] apr1v10 no private ioctls.
[*10/15/2021 17:23:35.8226] apr1v10 no private ioctls.
[*10/15/2021 17:23:35.8227]
[*10/15/2021 17:23:35.8280] apr1v10 no private ioctls.
[*10/15/2021 17:23:35.8341] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.8394] apr1v10 no private ioctls.
[*10/15/2021 17:23:35.8489] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.8490] SET failed on device apr1v10 ; No such device.
[*10/15/2021 17:23:35.8549] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.8678] apr1v11 no private ioctls.
[*10/15/2021 17:23:35.8816] apr1v11 no private ioctls.
[*10/15/2021 17:23:35.8867] apr1v11 no private ioctls.
[*10/15/2021 17:23:35.8926] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.8979] apr1v11 no private ioctls.
[*10/15/2021 17:23:35.9028] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.9029] SET failed on device apr1v11 ; No such device.
[*10/15/2021 17:23:35.9124] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.9197] apr1v12 no private ioctls.
[*10/15/2021 17:23:35.9248] apr1v12 no private ioctls.
[*10/15/2021 17:23:35.9299] apr1v12 no private ioctls.
[*10/15/2021 17:23:35.9360] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.9414] apr1v12 no private ioctls.
[*10/15/2021 17:23:35.9466] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.9466] SET failed on device apr1v12 ; No such device.
[*10/15/2021 17:23:35.9527] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.9593] apr1v13 no private ioctls.
[*10/15/2021 17:23:35.9644] apr1v13 no private ioctls.
[*10/15/2021 17:23:35.9695] apr1v13 no private ioctls.
[*10/15/2021 17:23:35.9696]
[*10/15/2021 17:23:35.9756] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.9811] apr1v13 no private ioctls.
[*10/15/2021 17:23:35.9861] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.9862] SET failed on device apr1v13 ; No such device.
[*10/15/2021 17:23:35.9924] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.9991] apr1v14 no private ioctls.
[*10/15/2021 17:23:36.0043] apr1v14 no private ioctls.
[*10/15/2021 17:23:36.0093] apr1v14 no private ioctls.
[*10/15/2021 17:23:36.0155] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:36.0209] apr1v14 no private ioctls.
[*10/15/2021 17:23:36.0260] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:36.0261] SET failed on device apr1v14 ; No such device.
[*10/15/2021 17:23:36.0322] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:36.0388] apr1v15 no private ioctls.
[*10/15/2021 17:23:36.0389]
[*10/15/2021 17:23:36.0440] apr1v15 no private ioctls.
[*10/15/2021 17:23:36.0441]
[*10/15/2021 17:23:36.0491] apr1v15 no private ioctls.
[*10/15/2021 17:23:36.0553] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:36.0607] apr1v15 no private ioctls.
[*10/15/2021 17:23:36.0658] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:36.0659] SET failed on device apr1v15 ; No such device.
[*10/15/2021 17:23:36.0719] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:36.0782] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:36.2896] Last reload reason : 23: Systemd critical process crash
[ OK ] Started Cisco act2 check.
[*10/15/2021 17:23:47.7309] Initializing NSS Firmware
[ OK ] Started Cisco pre-PoE negotiation.
Starting Cisco pre-PoE negotiation...
[ OK ] Started Cisco nss service.
Starting Cisco S15platform...
Starting Cisco Kclick...
[10/15/2021 17:23:51.2800] Disabling lock debugging due to kernel taint
[ OK ] Started Cisco S15platform.
[ OK ] Started Cisco Kclick.
Starting Cisco ME service...
[*10/15/2021 17:23:51.4800] stile module dp init successfully
[*10/15/2021 17:23:51.4800] NBAR Label:BLD_POLARIS_DEV_LATEST_20200414_053707 Module timestamp: Oct 30 2020 at 16:11:52 User: ttaichol
Starting Cisco Sku service...
[*10/15/2021 17:23:54.1372] SKU to radio FW
[*10/15/2021 17:23:54.1792] wifi1 no privat Starting Cisco certificate create service...
[ OK ] Started Cisco ME service.
[ OK ] Started Cisco Sku service.
[ OK ] Started Cisco certificate create service.
Starting Cisco certtime service...
[*10/15/2021 17:23:54.8797] Create symlink /dev/mic_cert result 0
[*10/15/2021 17:23:54.8797] Loading certificates from storage...
[*10/15/2021 17:23:54.9129] milos /tmp/SC4_1dbm.txt
[ OK ] Started Cisco Tam service.
Starting Cisco Tam service...
Starting Cisco S16platfomm...
Starting rsyslog client...
Starting Cisco syslog service...
[ OK ] Started Cisco S16platfomm.
[ OK ] Started rsyslog client.
[ OK ] Started Cisco syslog service.
Starting Cisco synclogd...
[ OK ] Started Cisco synclogd.
[ OK ] Started Cisco certtime service.
[ OK ] Reached target System Initialization.
[ OK ] Reached target Paths.
[ OK ] Reached target Basic System.
Starting capwapd...
Starting Cisco printkd...
[*10/15/2021 17:23:59.7425] starting tam services using ACT2...
[*10/15/2021 17:23:59.7425] TAM init done
[ OK ] Started NTP_PROC daemon.
Starting NTP_PROC daemon...
Starting WCPD process...
[ OK ] Started System Monitor service.
Starting System Monitor service...
Starting Hostapd process...
Starting Cisco klogd...
Starting Cisco brain service...
Starting Clean Air daemon...
Starting AP Trace daemon...
Starting Cisco rtd service...
[*10/15/2021 17:24:01.2564]
[*10/15/2021 17:24:01.2564] Click sched monitor: schedulers = 1 Starting Fast CGI daemon...
Starting Cisco image/firmware updater service...
Starting Marvell Forwarding daemon...
Starting Cisco led service...
Starting Cisco kexec...
Starting gRPC server daemon...
[ OK ] Started Serial Getty on ttyS0.
Starting Serial Getty on ttyS0...
[ OK ] Reached target Login Prompts.
Starting OpenSSH server daemon...
[ OK ] Started Cisco image/firmware updater service.
[ OK ] Started Cisco led service.
[ OK ] Started Cisco kexec.
[ OK ] Started Cisco klogd.
[ OK ] Started Cisco printkd.
[ OK ] Started AP Trace daemon.
[ OK ] Started Cisco rtd service.
[ OK ] Started Fast CGI daemon.
[ OK ] Started Hostapd process.
[ OK ] Started Cisco brain service.
[10/15/2021 17:24:03.1800] wired0 emac 1: link up
[10/15/2021 17:24:03.2300] wired0: link up
[ OK ] Started OpenSSH server daemon.
User Access Verification
Username: [10/15/2021 17:24:09.1400] wired0 emac 1: link up
[10/15/2021 17:24:09.2000] wired0: link up
[*10/15/2021 17:24:09.8517] ip6_port srcr2, ip6local fe80::f24a:2ff:feaf:e02e, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
[*10/15/2021 17:24:10.2049] pid 8006's current affinity mask: 3
[*10/15/2021 17:24:10.2049] pid 8006's new affinity mask: 1
[*10/15/2021 17:24:10.6637] device aptrace0 entered promiscuous mode
[*10/15/2021 17:24:10.7365] device to_container entered promiscuous mode
[*10/15/2021 17:24:11.2756] chpasswd: password for user changed
[*10/15/2021 17:24:12.1433] DOT11_TXP[0]:Domain configured: 1 class:E
[*10/15/2021 17:24:12.2797] DOT11_TXP[0]:Domain configured: 40 class:M
[*10/15/2021 17:24:12.7177] DOT11_TXP[0]:Domain configured: 40 class:M
[*10/15/2021 17:24:14.9193] DOT11_TXP[0]:Domain configured: 1 class:E
[*10/15/2021 17:24:15.0636] DOT11_TXP[0]:Domain configured: 40 class:M
[*10/15/2021 17:24:16.9210] ethernet_port wired0, ip 172.16.136.227, netmask 255.255.252.0, gw 172.16.136.1, mtu 1500, bcast 172.16.139.255, dns1 172.16.136.1, dns2 8.8.8.8, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*10/15/2021 17:24:18.1707] DOT11_DRV[0]: Stopped Radio 0
[*10/15/2021 17:24:18.1997] DOT11_DRV[0]: DOT11_DRV[0]: set_channel Channel set to 6
[*10/15/2021 17:24:18.7717] 00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:24:18.7717] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:18.7717] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:24:18.7717] Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
[*10/15/2021 17:24:18.7717] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:24:18.7717] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:24:18.7717] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:24:18.7717] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:24:18.7717] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:24:18.7717] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:24:18.7717] 00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:24:18.7717] Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:18.7718] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:24:18.7718] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:24:18.7718] Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
[*10/15/2021 17:24:18.7718] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:24:18.7718] Memory behind bridge: f8000000-f82fffff
[*10/15/2021 17:24:18.7718] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:24:18.7718] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:24:18.7718] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:24:18.7718] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:24:18.7718] 00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:24:18.7718] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:18.7718] Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
[*10/15/2021 17:24:18.7718] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:24:18.7719] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:24:18.7719] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:24:18.7719] 02:00.0 Ethernet controller: Marvell Technology Group Ltd. Device 2b40
[*10/15/2021 17:24:18.7719] Subsystem: Marvell Technology Group Ltd. Device 0000
[*10/15/2021 17:24:18.7719] Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:18.7719] Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:24:18.7719] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:24:18.7719] Interrupt: pin A routed to IRQ 65
[*10/15/2021 17:24:18.7719] Region 0: Memory at f8000000 (64-bit, prefetchable) [size=2M]
[*10/15/2021 17:24:18.7719] Region 2: Memory at f8200000 (64-bit, prefetchable) [size=1M]
[*10/15/2021 17:24:18.7719] Capabilities: [40] Power Management version 3
[*10/15/2021 17:24:18.7719] Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold+)
[*10/15/2021 17:24:18.7719] Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
[*10/15/2021 17:24:18.7719] Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+
[*10/15/2021 17:24:18.7719] Address: 0000000000000000 Data: 0000
[*10/15/2021 17:24:18.7719] Masking: 00000000 Pending: 00000000
[*10/15/2021 17:24:18.7719] Capabilities: [70] Express (v2) Endpoint, MSI 00
[*10/15/2021 17:24:18.7720] DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <1us, L1 unlimited
[*10/15/2021 17:24:18.7720] ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
[*10/15/2021 17:24:18.7720] DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
[*10/15/2021 17:24:18.7720] RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
[*10/15/2021 17:24:18.7720] MaxPayload 128 bytes, MaxReadReq 512 bytes
[*10/15/2021 17:24:18.7720] DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
[*10/15/2021 17:24:18.7720] LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 unlimited
[*10/15/2021 17:24:18.7720] ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
[*10/15/2021 17:24:18.7720] LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
[*10/15/2021 17:24:18.7720] ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
[*10/15/2021 17:24:18.7720] LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
[*10/15/2021 17:24:18.7720] DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
[*10/15/2021 17:24:18.7720] DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
[*10/15/2021 17:24:18.7720] LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
[*10/15/2021 17:24:18.7720] Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
[*10/15/2021 17:24:18.7720] Compliance De-emphasis: -6dB
[*10/15/2021 17:24:18.7725] LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
[*10/15/2021 17:24:18.7725] EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
[*10/15/2021 17:24:18.7725] Capabilities: [b0] MSI-X: Enable- Count=32 Masked-
[*10/15/2021 17:24:18.7725] Vector table: BAR=2 offset=00001000
[*10/15/2021 17:24:18.7725] PBA: BAR=2 offset=00001800
[*10/15/2021 17:24:18.7726] Capabilities: [100 v2] Advanced Error Reporting
[*10/15/2021 17:24:18.7726] UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:24:18.7726] UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:24:18.7726] UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:24:18.7726] CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
[*10/15/2021 17:24:18.7726] CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
[*10/15/2021 17:24:18.7726] AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
[*10/15/2021 17:24:18.7726] Capabilities: [140 v1] Device Serial Number 00-00-00-00-00-00-00-00
[*10/15/2021 17:24:18.7726] Capabilities: [150 v1] Power Budgeting <?>
[*10/15/2021 17:24:18.7726] Capabilities: [160 v1] Latency Tolerance Reporting
[*10/15/2021 17:24:18.7726] Max snoop latency: 0ns
[*10/15/2021 17:24:18.7726] Max no snoop latency: 0ns
[*10/15/2021 17:24:18.7726] Kernel driver in use: wifi
[*10/15/2021 17:24:18.7812] wifi0 Link encap:Ethernet HWaddr B8:A3:77:83:AE:A0
[*10/15/2021 17:24:18.7812] BROADCAST MULTICAST MTU:1500 Metric:1
[*10/15/2021 17:24:18.7812] RX packets:0 errors:0 dropped:0 overruns:0 frame:0
[*10/15/2021 17:24:18.7812] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
[*10/15/2021 17:24:18.7813] collisions:0 txqueuelen:1000
[*10/15/2021 17:24:18.7813] RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
[*10/15/2021 17:24:18.7813] Interrupt:65 Memory:f8000000-f8200000
[*10/15/2021 17:24:18.7945] ifconfig: wifi1: error fetching interface information: Device not found
[*10/15/2021 17:24:18.7948] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver get_vap_if_index ioctl SIOCGIFINDEX failed for apr1v0 error No such device
[*10/15/2021 17:24:18.7949] populate_if_index_table: if_index -1 out of range for radio 1 vap 0 of 16
[*10/15/2021 17:24:18.7950] /opt/cisco/bin/wcpd: /san1/BUILD/workspace/c173_2_throttle_17_3_2_32_CCO/label/barbados/base/../elts-meraki/elements/wcp/wcp_common/wcp_db.cc: 3728: void WcpDb::populate_if_index_table(): Assertion `if_index >= 0 && if_index < 64' failed.
[*10/15/2021 17:24:20.7348] AP IPv4 Address updated from 0.0.0.0 to 172.16.136.227
[*10/15/2021 17:24:24.3884] systemd[1]: wcpd.service failed.
[*10/15/2021 17:24:27.3877] DOT11_TXP[1]:Domain configured: 40 class:M
[*10/15/2021 17:24:27.9025] DOT11_TXP[0]:Domain configured: 1 class:E
[*10/15/2021 17:24:28.0506] DOT11_TXP[0]:Domain configured: 40 class:M
[*10/15/2021 17:24:30.2845] DOT11_TXP[0]:Domain configured: 1 class:E
[*10/15/2021 17:24:30.4426] DOT11_TXP[0]:Domain configured: 40 class:M
[*10/15/2021 17:24:33.0523] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:24:33.0647] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:24:33.1178] 00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:24:33.1178] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:33.1178] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:24:33.1178] Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
[*10/15/2021 17:24:33.1178] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:24:33.1179] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:24:33.1179] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:24:33.1179] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:24:33.1179] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:24:33.1179] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:24:33.1179] 00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:24:33.1179] Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:33.1179] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:24:33.1179] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:24:33.1179] Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
[*10/15/2021 17:24:33.1179] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:24:33.1179] Memory behind bridge: f8000000-f82fffff
[*10/15/2021 17:24:33.1179] 00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:24:33.1179] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:33.1180] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:24:33.1180] Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
[*10/15/2021 17:24:33.1180] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:24:33.1180] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:24:33.1180] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:24:33.1180] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:24:33.1180] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:24:33.1180] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:24:33.1180] 02:00.0 Ethernet controller: Marvell Technology Group Ltd. Device 2b40
[*10/15/2021 17:24:33.1180] Subsystem: Marvell Technology Group Ltd. Device 0000
[*10/15/2021 17:24:33.1180] Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:33.1180] Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:24:33.1180] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:24:33.1180] Interrupt: pin A routed to IRQ 65
[*10/15/2021 17:24:33.1180] Region 0: Memory at f8000000 (64-bit, prefetchable) [size=2M]
[*10/15/2021 17:24:33.1180] Region 2: Memory at f8200000 (64-bit, prefetchable) [size=1M]
[*10/15/2021 17:24:33.1180] Capabilities: [40] Power Management version 3
[*10/15/2021 17:24:33.1180] Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold+)
[*10/15/2021 17:24:33.1180] Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
[*10/15/2021 17:24:33.1180] Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+
[*10/15/2021 17:24:33.1181] Address: 0000000000000000 Data: 0000
[*10/15/2021 17:24:33.1181] Masking: 00000000 Pending: 00000000
[*10/15/2021 17:24:33.1181] Capabilities: [70] Express (v2) Endpoint, MSI 00
[*10/15/2021 17:24:33.1181] DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <1us, L1 unlimited
[*10/15/2021 17:24:33.1181] ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
[*10/15/2021 17:24:33.1181] DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
[*10/15/2021 17:24:33.1181] RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
[*10/15/2021 17:24:33.1181] MaxPayload 128 bytes, MaxReadReq 512 bytes
[*10/15/2021 17:24:33.1181] DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
[*10/15/2021 17:24:33.1181] LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 unlimited
[*10/15/2021 17:24:33.1181] ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
[*10/15/2021 17:24:33.1181] LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
[*10/15/2021 17:24:33.1181] ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
[*10/15/2021 17:24:33.1181] LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
[*10/15/2021 17:24:33.1181] DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
[*10/15/2021 17:24:33.1181] DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
[*10/15/2021 17:24:33.1181] LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
[*10/15/2021 17:24:33.1181] Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
[*10/15/2021 17:24:33.1182] Compliance De-emphasis: -6dB
[*10/15/2021 17:24:33.1187] LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
[*10/15/2021 17:24:33.1187] EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
[*10/15/2021 17:24:33.1187] Capabilities: [b0] MSI-X: Enable- Count=32 Masked-
[*10/15/2021 17:24:33.1187] Vector table: BAR=2 offset=00001000
[*10/15/2021 17:24:33.1187] PBA: BAR=2 offset=00001800
[*10/15/2021 17:24:33.1187] Capabilities: [100 v2] Advanced Error Reporting
[*10/15/2021 17:24:33.1187] UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:24:33.1188] UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:24:33.1188] UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
***Output truncated 40845 bytes***
[*10/15/2021 17:24:34.2124] UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:24:34.2125] CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
[*10/15/2021 17:24:34.2125] CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
[*10/15/2021 17:24:34.2125] AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
[*10/15/2021 17:24:34.2125] Capabilities: [140 v1] Device Serial Number 00-00-00-00-00-00-00-00
[*10/15/2021 17:24:34.2125] Capabilities: [150 v1] Power Budgeting <?>
[*10/15/2021 17:24:34.2125] Capabilities: [160 v1] Latency Tolerance Reporting
[*10/15/2021 17:24:34.2125] Max snoop latency: 0ns
[*10/15/2021 17:24:34.2125] Max no snoop latency: 0ns
[*10/15/2021 17:24:34.2125] Kernel driver in use: wifi
[*10/15/2021 17:24:34.2240] wifi0 Link encap:Ethernet HWaddr B8:A3:77:83:AE:A0
[*10/15/2021 17:24:34.2240] BROADCAST MULTICAST MTU:1500 Metric:1
[*10/15/2021 17:24:34.2240] RX packets:0 errors:0 dropped:0 overruns:0 frame:0
[*10/15/2021 17:24:34.2240] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
[*10/15/2021 17:24:34.2240] collisions:0 txqueuelen:1000
[*10/15/2021 17:24:34.2240] RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
[*10/15/2021 17:24:34.2241] Interrupt:65 Memory:f8000000-f8200000
[*10/15/2021 17:24:34.2392] ifconfig: wifi1: error fetching interface information: Device not found
[*10/15/2021 17:24:34.2396] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v6 error No such device
[*10/15/2021 17:24:34.2396] DOT11_DRV[1]: Unable to read bssid from val for vap_id:6
[*10/15/2021 17:24:34.2397] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A9
[*10/15/2021 17:24:34.2441] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v7 error No such device
[*10/15/2021 17:24:34.2441] DOT11_DRV[1]: Unable to set bssid in val for vap_id:7 RC:-1
[*10/15/2021 17:24:34.2488] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v7 error No such device
[*10/15/2021 17:24:34.2489] DOT11_DRV[1]: Unable to read bssid from val for vap_id:7
[*10/15/2021 17:24:34.2489] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A8
[*10/15/2021 17:24:34.2537] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v8 error No such device
[*10/15/2021 17:24:34.2538] DOT11_DRV[1]: Unable to set bssid in val for vap_id:8 RC:-1
[*10/15/2021 17:24:34.2587] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v8 error No such device
[*10/15/2021 17:24:34.2587] DOT11_DRV[1]: Unable to read bssid from val for vap_id:8
[*10/15/2021 17:24:34.2588] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A7
[*10/15/2021 17:24:34.2629] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v9 error No such device
[*10/15/2021 17:24:34.2629] DOT11_DRV[1]: Unable to set bssid in val for vap_id:9 RC:-1
[*10/15/2021 17:24:34.2675] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v9 error No such device
[*10/15/2021 17:24:34.2676] DOT11_DRV[1]: Unable to read bssid from val for vap_id:9
[*10/15/2021 17:24:34.2676] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A6
[*10/15/2021 17:24:34.2722] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v10 error No such device
[*10/15/2021 17:24:34.2723] DOT11_DRV[1]: Unable to set bssid in val for vap_id:10 RC:-1
[*10/15/2021 17:24:34.2771] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v10 error No such device
[*10/15/2021 17:24:34.2772] DOT11_DRV[1]: Unable to read bssid from val for vap_id:10
[*10/15/2021 17:24:34.2772] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A5
[*10/15/2021 17:24:34.2815] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v11 error No such device
[*10/15/2021 17:24:34.2815] DOT11_DRV[1]: Unable to set bssid in val for vap_id:11 RC:-1
[*10/15/2021 17:24:34.3344] 00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:24:34.3344] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:34.3344] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:24:34.3344] Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
[*10/15/2021 17:24:34.3344] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:24:34.3344] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:24:34.3344] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:24:34.3345] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:24:34.3345] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:24:34.3345] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:24:34.3345] 00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:24:34.3345] Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:34.3345] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:24:34.3345] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:24:34.3345] Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
[*10/15/2021 17:24:34.3345] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:24:34.3345] Memory behind bridge: f8000000-f82fffff
[*10/15/2021 17:24:34.3345] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:24:34.3345] 00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:24:34.3345] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:34.3346] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:24:34.3346] Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
[*10/15/2021 17:24:34.3346] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:24:34.3346] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:24:34.3346] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:24:34.3346] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:24:34.3346] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:24:34.3346] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:24:34.3346] 02:00.0 Ethernet controller: Marvell Technology Group Ltd. Device 2b40
[*10/15/2021 17:24:34.3346] Subsystem: Marvell Technology Group Ltd. Device 0000
[*10/15/2021 17:24:34.3346] Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:34.3346] Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:24:34.3346] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:24:34.3346] Interrupt: pin A routed to IRQ 65
[*10/15/2021 17:24:34.3346] Region 0: Memory at f8000000 (64-bit, prefetchable) [size=2M]
[*10/15/2021 17:24:34.3346] Region 2: Memory at f8200000 (64-bit, prefetchable) [size=1M]
[*10/15/2021 17:24:34.3346] Capabilities: [40] Power Management version 3
[*10/15/2021 17:24:34.3346] Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold+)
[*10/15/2021 17:24:34.3346] Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
[*10/15/2021 17:24:34.3346] Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+
[*10/15/2021 17:24:34.3347] Address: 0000000000000000 Data: 0000
[*10/15/2021 17:24:34.3347] Masking: 00000000 Pending: 00000000
[*10/15/2021 17:24:34.3347] Capabilities: [70] Express (v2) Endpoint, MSI 00
[*10/15/2021 17:24:34.3347] DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <1us, L1 unlimited
[*10/15/2021 17:24:34.3347] ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
[*10/15/2021 17:24:34.3347] DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
[*10/15/2021 17:24:34.3347] RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
[*10/15/2021 17:24:34.3347] MaxPayload 128 bytes, MaxReadReq 512 bytes
[*10/15/2021 17:24:34.3347] DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
[*10/15/2021 17:24:34.3347] LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 unlimited
[*10/15/2021 17:24:34.3347] ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
[*10/15/2021 17:24:34.3347] LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
[*10/15/2021 17:24:34.3347] ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
[*10/15/2021 17:24:34.3347] LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
[*10/15/2021 17:24:34.3347] DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
[*10/15/2021 17:24:34.3347] DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
[*10/15/2021 17:24:34.3347] LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
[*10/15/2021 17:24:34.3347] Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
[*10/15/2021 17:24:34.3348] Compliance De-emphasis: -6dB
[*10/15/2021 17:24:34.3353] LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
[*10/15/2021 17:24:34.3353] EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
[*10/15/2021 17:24:34.3353] Capabilities: [b0] MSI-X: Enable- Count=32 Masked-
[*10/15/2021 17:24:34.3353] Vector table: BAR=2 offset=00001000
[*10/15/2021 17:24:34.3353] PBA: BAR=2 offset=00001800
[*10/15/2021 17:24:34.3353] Capabilities: [100 v2] Advanced Error Reporting
[*10/15/2021 17:24:34.3353] UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:24:34.3353] UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:24:34.3353] UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:24:34.3353] CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
[*10/15/2021 17:24:34.3353] CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
[*10/15/2021 17:24:34.3353] AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
[*10/15/2021 17:24:34.3353] Capabilities: [140 v1] Device Serial Number 00-00-00-00-00-00-00-00
[*10/15/2021 17:24:34.3353] Capabilities: [150 v1] Power Budgeting <?>
[*10/15/2021 17:24:34.3353] Capabilities: [160 v1] Latency Tolerance Reporting
[*10/15/2021 17:24:34.3353] Max snoop latency: 0ns
[*10/15/2021 17:24:34.3353] Max no snoop latency: 0ns
[*10/15/2021 17:24:34.3353] Kernel driver in use: wifi
[*10/15/2021 17:24:34.3475] wifi0 Link encap:Ethernet HWaddr B8:A3:77:83:AE:A0
[*10/15/2021 17:24:34.3475] BROADCAST MULTICAST MTU:1500 Metric:1
[*10/15/2021 17:24:34.3475] RX packets:0 errors:0 dropped:0 overruns:0 frame:0
[*10/15/2021 17:24:34.3475] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
[*10/15/2021 17:24:34.3475] collisions:0 txqueuelen:1000
[*10/15/2021 17:24:34.3475] RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
[*10/15/2021 17:24:34.3475] Interrupt:65 Memory:f8000000-f8200000
[*10/15/2021 17:24:34.3624] ifconfig: wifi1: error fetching interface information: Device not found
[*10/15/2021 17:24:34.3628] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v11 error No such device
[*10/15/2021 17:24:34.3628] DOT11_DRV[1]: Unable to read bssid from val for vap_id:11
[*10/15/2021 17:24:34.3629] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A4
[*10/15/2021 17:24:34.3680] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v12 error No such device
[*10/15/2021 17:24:34.3680] DOT11_DRV[1]: Unable to set bssid in val for vap_id:12 RC:-1
[*10/15/2021 17:24:34.3955] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v12 error No such device
[*10/15/2021 17:24:34.3956] DOT11_DRV[1]: Unable to read bssid from val for vap_id:12
[*10/15/2021 17:24:34.3957] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A3
[*10/15/2021 17:24:34.4015] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v13 error No such device
[*10/15/2021 17:24:34.4015] DOT11_DRV[1]: Unable to set bssid in val for vap_id:13 RC:-1
[*10/15/2021 17:24:34.4076] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v13 error No such device
[*10/15/2021 17:24:34.4182] DOT11_DRV[1]: Unable to read bssid from val for vap_id:13
[*10/15/2021 17:24:34.4183] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A2
[*10/15/2021 17:24:34.4229] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v14 error No such device
[*10/15/2021 17:24:34.4230] DOT11_DRV[1]: Unable to set bssid in val for vap_id:14 RC:-1
[*10/15/2021 17:24:34.4279] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v14 error No such device
[*10/15/2021 17:24:34.4280] DOT11_DRV[1]: Unable to read bssid from val for vap_id:14
***Output truncated 14794 bytes***
[*10/15/2021 17:24:35.4483] DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
[*10/15/2021 17:24:35.4483] LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
[*10/15/2021 17:24:35.4483] Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
[*10/15/2021 17:24:35.4483] Compliance De-emphasis: -6dB
[*10/15/2021 17:24:35.4488] LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
[*10/15/2021 17:24:35.4488] EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
[*10/15/2021 17:24:35.4489] Capabilities: [b0] MSI-X: Enable- Count=32 Masked-
[*10/15/2021 17:24:35.4489] Vector table: BAR=2 offset=00001000
[*10/15/2021 17:24:35.4489] PBA: BAR=2 offset=00001800
[*10/15/2021 17:24:35.4489] Capabilities: [100 v2] Advanced Error Reporting
***Output truncated 39628 bytes***
[*10/15/2021 17:24:51.5298] Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
[*10/15/2021 17:24:51.5298] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:24:51.5298] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:24:51.5298] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:24:51.5298] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:24:51.5298] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:24:51.5298] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:24:51.5298] 02:00.0 Ethernet controller: Marvell Technology Group Ltd. Device 2b40
[*10/15/2021 17:24:51.5298] Subsystem: Marvell Technology Group Ltd. Device 0000
[*10/15/2021 17:24:51.5298] Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
***Output truncated 44345 bytes***
[*10/15/2021 17:24:52.3080] UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:24:52.3080] CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
[*10/15/2021 17:24:52.3080] CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
[*10/15/2021 17:24:52.3080] AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
[*10/15/2021 17:24:52.3080] Capabilities: [140 v1] Device Serial Number 00-00-00-00-00-00-00-00
[*10/15/2021 17:24:52.3080] Capabilities: [150 v1] Power Budgeting <?>
[*10/15/2021 17:24:52.3080] Capabilities: [160 v1] Latency Tolerance Reporting
[*10/15/2021 17:24:52.3080] Max snoop latency: 0ns
[*10/15/2021 17:24:52.3081] Max no snoop latency: 0ns
[*10/15/2021 17:24:52.3081] Kernel driver in use: wifi
[*10/15/2021 17:24:52.3199] wifi0 Link encap:Ethernet HWaddr B8:A3:77:83:AE:A0
[*10/15/2021 17:24:52.3199] BROADCAST MULTICAST MTU:1500 Metric:1
[*10/15/2021 17:24:52.3199] RX packets:6 errors:0 dropped:0 overruns:0 frame:0
[*10/15/2021 17:24:52.3199] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
[*10/15/2021 17:24:52.3199] collisions:0 txqueuelen:1000
[*10/15/2021 17:24:52.3199] RX bytes:1827 (1.7 KiB) TX bytes:0 (0.0 B)
[*10/15/2021 17:24:52.3199] Interrupt:65 Memory:f8000000-f8200000
[*10/15/2021 17:24:52.3337] ifconfig: wifi1: error fetching interface information: Device not found
[*10/15/2021 17:24:52.3340] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v6 error No such device
[*10/15/2021 17:24:52.3341] DOT11_DRV[1]: Unable to read bssid from val for vap_id:6
[*10/15/2021 17:24:52.3341] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A9
[*10/15/2021 17:24:52.3387] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v7 error No such device
[*10/15/2021 17:24:52.3387] DOT11_DRV[1]: Unable to set bssid in val for vap_id:7 RC:-1
[*10/15/2021 17:24:52.3429] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v7 error No such device
[*10/15/2021 17:24:52.3429] DOT11_DRV[1]: Unable to read bssid from val for vap_id:7
[*10/15/2021 17:24:52.3430] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A8
[*10/15/2021 17:24:52.3475] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v8 error No such device
[*10/15/2021 17:24:52.3475] DOT11_DRV[1]: Unable to set bssid in val for vap_id:8 RC:-1
[*10/15/2021 17:24:52.3516] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v8 error No such device
[*10/15/2021 17:24:52.3517] DOT11_DRV[1]: Unable to read bssid from val for vap_id:8
[*10/15/2021 17:24:52.3517] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A7
[*10/15/2021 17:24:52.3560] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v9 error No such device
[*10/15/2021 17:24:52.3561] DOT11_DRV[1]: Unable to set bssid in val for vap_id:9 RC:-1
[*10/15/2021 17:24:52.3625] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v9 error No such device
[*10/15/2021 17:24:52.3626] DOT11_DRV[1]: Unable to read bssid from val for vap_id:9
[*10/15/2021 17:24:52.3626] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A6
[*10/15/2021 17:24:52.3689] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v10 error No such device
[*10/15/2021 17:24:52.3689] DOT11_DRV[1]: Unable to set bssid in val for vap_id:10 RC:-1
[*10/15/2021 17:24:52.3733] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v10 error No such device
[*10/15/2021 17:24:52.3733] DOT11_DRV[1]: Unable to read bssid from val for vap_id:10
[*10/15/2021 17:24:52.3734] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A5
[*10/15/2021 17:24:52.3778] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v11 error No such device
[*10/15/2021 17:24:52.3778] DOT11_DRV[1]: Unable to set bssid in val for vap_id:11 RC:-1
[*10/15/2021 17:24:52.4276] 00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:24:52.4276] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:52.4276] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:24:52.4276] Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
[*10/15/2021 17:24:52.4276] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:24:52.4276] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:24:52.4276] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:24:52.4276] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:24:52.4276] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:24:52.4276] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:24:52.4276] 00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:24:52.4276] Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:52.4276] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:24:52.4277] Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
[*10/15/2021 17:24:52.4277] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:24:52.4277] Memory behind bridge: f8000000-f82fffff
[*10/15/2021 17:24:52.4277] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:24:52.4277] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:24:52.4277] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:24:52.4277] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:24:52.4277] 00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:24:52.4277] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:52.4277] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:24:52.4277] Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
[*10/15/2021 17:24:52.4277] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:24:52.4278]
[*10/15/2021 17:24:52.4278] 02:00.0 Ethernet controller: Marvell Technology Group Ltd. Device 2b40
[*10/15/2021 17:24:52.4278] Subsystem: Marvell Technology Group Ltd. Device 0000
[*10/15/2021 17:24:52.4278] Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:24:52.4278] Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:24:52.4278] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:24:52.4278] Interrupt: pin A routed to IRQ 65
[*10/15/2021 17:24:52.4278] Region 0: Memory at f8000000 (64-bit, prefetchable) [size=2M]
[*10/15/2021 17:24:52.4278] Region 2: Memory at f8200000 (64-bit, prefetchable) [size=1M]
[*10/15/2021 17:24:52.4278] Capabilities: [40] Power Management version 3
[*10/15/2021 17:24:52.4278] Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold+)
[*10/15/2021 17:24:52.4278] Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
[*10/15/2021 17:24:52.4278] Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+
[*10/15/2021 17:24:52.4278] Address: 0000000000000000 Data: 0000
[*10/15/2021 17:24:52.4278] Masking: 00000000 Pending: 00000000
[*10/15/2021 17:24:52.4278] Capabilities: [70] Express (v2) Endpoint, MSI 00
[*10/15/2021 17:24:52.4278] DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <1us, L1 unlimited
[*10/15/2021 17:24:52.4278] ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
[*10/15/2021 17:24:52.4278] DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
[*10/15/2021 17:24:52.4278] RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
[*10/15/2021 17:24:52.4279] MaxPayload 128 bytes, MaxReadReq 512 bytes
[*10/15/2021 17:24:52.4279] DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
[*10/15/2021 17:24:52.4279] LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 unlimited
[*10/15/2021 17:24:52.4279] ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
[*10/15/2021 17:24:52.4279] LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
[*10/15/2021 17:24:52.4279] ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
[*10/15/2021 17:24:52.4279] LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
[*10/15/2021 17:24:52.4279] DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
[*10/15/2021 17:24:52.4279] DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
[*10/15/2021 17:24:52.4279] LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
[*10/15/2021 17:24:52.4279] Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
[*10/15/2021 17:24:52.4279] Compliance De-emphasis: -6dB
[*10/15/2021 17:24:52.4284] LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
[*10/15/2021 17:24:52.4284] EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
[*10/15/2021 17:24:52.4285] Capabilities: [b0] MSI-X: Enable- Count=32 Masked-
[*10/15/2021 17:24:52.4285] Vector table: BAR=2 offset=00001000
[*10/15/2021 17:24:52.4285] PBA: BAR=2 offset=00001800
[*10/15/2021 17:24:52.4285] Capabilities: [100 v2] Advanced Error Reporting
[*10/15/2021 17:24:52.4285] UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:24:52.4285] UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:24:52.4285] UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:24:52.4285] CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
[*10/15/2021 17:24:52.4285] CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
[*10/15/2021 17:24:52.4285] AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
[*10/15/2021 17:24:52.4285] Capabilities: [140 v1] Device Serial Number 00-00-00-00-00-00-00-00
[*10/15/2021 17:24:52.4285] Capabilities: [150 v1] Power Budgeting <?>
[*10/15/2021 17:24:52.4285] Capabilities: [160 v1] Latency Tolerance Reporting
[*10/15/2021 17:24:52.4285] Max snoop latency: 0ns
[*10/15/2021 17:24:52.4285] Max no snoop latency: 0ns
[*10/15/2021 17:24:52.4285] Kernel driver in use: wifi
[*10/15/2021 17:24:52.4412] wifi0 Link encap:Ethernet HWaddr B8:A3:77:83:AE:A0
[*10/15/2021 17:24:52.4412] BROADCAST MULTICAST MTU:1500 Metric:1
[*10/15/2021 17:24:52.4412] RX packets:6 errors:0 dropped:0 overruns:0 frame:0
[*10/15/2021 17:24:52.4412] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
[*10/15/2021 17:24:52.4413] collisions:0 txqueuelen:1000
[*10/15/2021 17:24:52.4413] RX bytes:1827 (1.7 KiB) TX bytes:0 (0.0 B)
[*10/15/2021 17:24:52.4413] Interrupt:65 Memory:f8000000-f8200000
[*10/15/2021 17:24:52.4559] ifconfig: wifi1: error fetching interface information: Device not found
[*10/15/2021 17:24:52.4563] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v11 error No such device
[*10/15/2021 17:24:52.4563] DOT11_DRV[1]: Unable to read bssid from val for vap_id:11
[*10/15/2021 17:24:52.4564] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A4
[*10/15/2021 17:24:52.4613] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v12 error No such device
[*10/15/2021 17:24:52.4613] DOT11_DRV[1]: Unable to set bssid in val for vap_id:12 RC:-1
[*10/15/2021 17:24:52.4659] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v12 error No such device
[*10/15/2021 17:24:52.4659] DOT11_DRV[1]: Unable to read bssid from val for vap_id:12
[*10/15/2021 17:24:52.4660] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A3
[*10/15/2021 17:24:52.4710] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v13 error No such device
[*10/15/2021 17:24:52.4710] DOT11_DRV[1]: Unable to set bssid in val for vap_id:13 RC:-1
[*10/15/2021 17:24:52.4757] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v13 error No such device
[*10/15/2021 17:24:52.4758] DOT11_DRV[1]: Unable to read bssid from val for vap_id:13
[*10/15/2021 17:24:52.4758] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A2
[*10/15/2021 17:24:52.4806] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v14 error No such device
[*10/15/2021 17:24:52.4807] DOT11_DRV[1]: Unable to set bssid in val for vap_id:14 RC:-1
[*10/15/2021 17:24:52.4952] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v14 error No such device
[*10/15/2021 17:24:52.4952] DOT11_DRV[1]: Unable to read bssid from val for vap_id:14
[*10/15/2021 17:24:52.4953] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A1
[*10/15/2021 17:24:52.5004] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v15 error No such device
[*10/15/2021 17:24:52.5005] DOT11_DRV[1]: Unable to set bssid in val for vap_id:15 RC:-1
[*10/15/2021 17:24:52.5050] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v15 error No such device
[*10/15/2021 17:24:52.5051] DOT11_DRV[1]: Unable to read bssid from val for vap_id:15
[*10/15/2021 17:24:52.5052] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A0
[*10/15/2021 17:24:52.5187] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:24:52.5191] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver:ifconfig mon1 down failed
[*10/15/2021 17:24:52.5191] DOT11_DRV[1]: Stopped Radio 1
***Output truncated 1056 bytes***
[*10/15/2021 17:24:52.6520] apr1v6 no private ioctls.
[*10/15/2021 17:24:52.6521]
[*10/15/2021 17:24:52.6648] apr1v7 no private ioctls.
[*10/15/2021 17:24:52.6649]
[*10/15/2021 17:24:52.6774] apr1v8 no private ioctls.
[*10/15/2021 17:24:52.6890] apr1v9 no private ioctls.
[*10/15/2021 17:24:52.7009] apr1v10 no private ioctls.
[*10/15/2021 17:24:52.7122] apr1v11 no private ioctls.
[*10/15/2021 17:24:52.7123]
[*10/15/2021 17:24:52.7234] apr1v12 no private ioctls.
[*10/15/2021 17:24:52.7347] apr1v13 no private ioctls.
[*10/15/2021 17:24:52.7460] apr1v14 no private ioctls.
[*10/15/2021 17:24:52.7461]
[*10/15/2021 17:24:52.7575] apr1v15 no private ioctls.
[*10/15/2021 17:24:52.7685] apr1v0 no private ioctls.
***Output truncated 51999 bytes***
[*10/15/2021 17:25:10.7739] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:25:10.7739] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:25:10.7739] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:25:10.7739] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:25:10.7739] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:25:10.7739] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:25:10.7739] 02:00.0 Ethernet controller: Marvell Technology Group Ltd. Device 2b40
[*10/15/2021 17:25:10.7739] Subsystem: Marvell Technology Group Ltd. Device 0000
[*10/15/2021 17:25:10.7739] Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
***Output truncated 42875 bytes***
[*10/15/2021 17:25:11.5254] ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
[*10/15/2021 17:25:11.5254] LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
[*10/15/2021 17:25:11.5254] DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
[*10/15/2021 17:25:11.5254] DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
[*10/15/2021 17:25:11.5254] LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
[*10/15/2021 17:25:11.5254] Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
[*10/15/2021 17:25:11.5254] Compliance De-emphasis: -6dB
[*10/15/2021 17:25:11.5259] LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
[*10/15/2021 17:25:11.5259] EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
[*10/15/2021 17:25:11.5259] Capabilities: [b0] MSI-X: Enable- Count=32 Masked-
***Output truncated 989 bytes***
[*10/15/2021 17:25:11.5260] Capabilities: [150 v1] Power Budgeting <?>
[*10/15/2021 17:25:11.5260] Capabilities: [160 v1] Latency Tolerance Reporting
[*10/15/2021 17:25:11.5260] Max snoop latency: 0ns
[*10/15/2021 17:25:11.5260] Max no snoop latency: 0ns
[*10/15/2021 17:25:11.5260] Kernel driver in use: wifi
[*10/15/2021 17:25:11.5365] wifi0 Link encap:Ethernet HWaddr B8:A3:77:83:AE:A0
[*10/15/2021 17:25:11.5365] BROADCAST MULTICAST MTU:1500 Metric:1
[*10/15/2021 17:25:11.5365] RX packets:2 errors:0 dropped:0 overruns:0 frame:0
[*10/15/2021 17:25:11.5365] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
[*10/15/2021 17:25:11.5365] collisions:0 txqueuelen:1000
[*10/15/2021 17:25:11.5365] RX bytes:188 (188.0 B) TX bytes:0 (0.0 B)
[*10/15/2021 17:25:11.5365] Interrupt:65 Memory:f8000000-f8200000
[*10/15/2021 17:25:11.5498] ifconfig: wifi1: error fetching interface information: Device not found
[*10/15/2021 17:25:11.5502] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v6 error No such device
[*10/15/2021 17:25:11.5502] DOT11_DRV[1]: Unable to read bssid from val for vap_id:6
[*10/15/2021 17:25:11.5503] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A9
[*10/15/2021 17:25:11.5545] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v7 error No such device
[*10/15/2021 17:25:11.5545] DOT11_DRV[1]: Unable to set bssid in val for vap_id:7 RC:-1
[*10/15/2021 17:25:11.5589] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v7 error No such device
[*10/15/2021 17:25:11.5589] DOT11_DRV[1]: Unable to read bssid from val for vap_id:7
[*10/15/2021 17:25:11.5590] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A8
[*10/15/2021 17:25:11.5630] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v8 error No such device
[*10/15/2021 17:25:11.5631] DOT11_DRV[1]: Unable to set bssid in val for vap_id:8 RC:-1
[*10/15/2021 17:25:11.5671] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v8 error No such device
[*10/15/2021 17:25:11.5672] DOT11_DRV[1]: Unable to read bssid from val for vap_id:8
[*10/15/2021 17:25:11.5672] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A7
[*10/15/2021 17:25:11.5713] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v9 error No such device
[*10/15/2021 17:25:11.5714] DOT11_DRV[1]: Unable to set bssid in val for vap_id:9 RC:-1
[*10/15/2021 17:25:11.5754] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v9 error No such device
[*10/15/2021 17:25:11.5754] DOT11_DRV[1]: Unable to read bssid from val for vap_id:9
[*10/15/2021 17:25:11.5755] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A6
[*10/15/2021 17:25:11.5797] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v10 error No such device
[*10/15/2021 17:25:11.5798] DOT11_DRV[1]: Unable to set bssid in val for vap_id:10 RC:-1
[*10/15/2021 17:25:11.5838] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v10 error No such device
[*10/15/2021 17:25:11.5838] DOT11_DRV[1]: Unable to read bssid from val for vap_id:10
[*10/15/2021 17:25:11.5839] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A5
[*10/15/2021 17:25:11.5881] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v11 error No such device
[*10/15/2021 17:25:11.5881] DOT11_DRV[1]: Unable to set bssid in val for vap_id:11 RC:-1
[*10/15/2021 17:25:11.6363] 00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:25:11.6364] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:11.6364] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:25:11.6364] Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
[*10/15/2021 17:25:11.6364] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:25:11.6364] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:25:11.6364] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:25:11.6364] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:25:11.6364] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:25:11.6364] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:25:11.6364] 00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:25:11.6364] Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:11.6364] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:25:11.6365] Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
[*10/15/2021 17:25:11.6365] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:25:11.6365] Memory behind bridge: f8000000-f82fffff
[*10/15/2021 17:25:11.6365] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:25:11.6365] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:25:11.6365] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:25:11.6365] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:25:11.6365] 00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:25:11.6365] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:11.6365] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:25:11.6365] Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
[*10/15/2021 17:25:11.6365] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:25:11.6365] 02:00.0 Ethernet controller: Marvell Technology Group Ltd. Device 2b40
[*10/15/2021 17:25:11.6366] Subsystem: Marvell Technology Group Ltd. Device 0000
[*10/15/2021 17:25:11.6366] Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:11.6366] Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:25:11.6366] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:25:11.6366] Interrupt: pin A routed to IRQ 65
[*10/15/2021 17:25:11.6366] Region 0: Memory at f8000000 (64-bit, prefetchable) [size=2M]
[*10/15/2021 17:25:11.6366] Region 2: Memory at f8200000 (64-bit, prefetchable) [size=1M]
[*10/15/2021 17:25:11.6366] Capabilities: [40] Power Management version 3
[*10/15/2021 17:25:11.6366] Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold+)
[*10/15/2021 17:25:11.6366] Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
[*10/15/2021 17:25:11.6366] Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+
[*10/15/2021 17:25:11.6366] Address: 0000000000000000 Data: 0000
[*10/15/2021 17:25:11.6366] Masking: 00000000 Pending: 00000000
[*10/15/2021 17:25:11.6366] Capabilities: [70] Express (v2) Endpoint, MSI 00
[*10/15/2021 17:25:11.6366] DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <1us, L1 unlimited
[*10/15/2021 17:25:11.6366] ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
[*10/15/2021 17:25:11.6366] DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
[*10/15/2021 17:25:11.6366] RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
[*10/15/2021 17:25:11.6366] MaxPayload 128 bytes, MaxReadReq 512 bytes
[*10/15/2021 17:25:11.6366] DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
[*10/15/2021 17:25:11.6366] LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 unlimited
[*10/15/2021 17:25:11.6367] ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
[*10/15/2021 17:25:11.6367] LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
[*10/15/2021 17:25:11.6367] ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
[*10/15/2021 17:25:11.6367] LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
[*10/15/2021 17:25:11.6367] DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
[*10/15/2021 17:25:11.6367] DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
[*10/15/2021 17:25:11.6367] LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
[*10/15/2021 17:25:11.6367] Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
[*10/15/2021 17:25:11.6367] Compliance De-emphasis: -6dB
[*10/15/2021 17:25:11.6372] LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
[*10/15/2021 17:25:11.6372] EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
[*10/15/2021 17:25:11.6372] Capabilities: [b0] MSI-X: Enable- Count=32 Masked-
[*10/15/2021 17:25:11.6372] Vector table: BAR=2 offset=00001000
[*10/15/2021 17:25:11.6372] PBA: BAR=2 offset=00001800
[*10/15/2021 17:25:11.6372] Capabilities: [100 v2] Advanced Error Reporting
[*10/15/2021 17:25:11.6372] UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:25:11.6372] UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:25:11.6372] UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:25:11.6372] CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
[*10/15/2021 17:25:11.6372] CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
[*10/15/2021 17:25:11.6372] AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
[*10/15/2021 17:25:11.6372] Capabilities: [140 v1] Device Serial Number 00-00-00-00-00-00-00-00
[*10/15/2021 17:25:11.6373] Capabilities: [150 v1] Power Budgeting <?>
[*10/15/2021 17:25:11.6373] Capabilities: [160 v1] Latency Tolerance Reporting
[*10/15/2021 17:25:11.6373] Max snoop latency: 0ns
[*10/15/2021 17:25:11.6373] Max no snoop latency: 0ns
[*10/15/2021 17:25:11.6373] Kernel driver in use: wifi
[*10/15/2021 17:25:11.6456] wifi0 Link encap:Ethernet HWaddr B8:A3:77:83:AE:A0
[*10/15/2021 17:25:11.6456] BROADCAST MULTICAST MTU:1500 Metric:1
[*10/15/2021 17:25:11.6456] RX packets:2 errors:0 dropped:0 overruns:0 frame:0
[*10/15/2021 17:25:11.6456] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
[*10/15/2021 17:25:11.6456] collisions:0 txqueuelen:1000
[*10/15/2021 17:25:11.6456] RX bytes:188 (188.0 B) TX bytes:0 (0.0 B)
[*10/15/2021 17:25:11.6456] Interrupt:65 Memory:f8000000-f8200000
[*10/15/2021 17:25:11.6592] ifconfig: wifi1: error fetching interface information: Device not found
[*10/15/2021 17:25:11.6595] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v11 error No such device
[*10/15/2021 17:25:11.6596] DOT11_DRV[1]: Unable to read bssid from val for vap_id:11
[*10/15/2021 17:25:11.6596] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A4
[*10/15/2021 17:25:11.6639] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v12 error No such device
[*10/15/2021 17:25:11.6639] DOT11_DRV[1]: Unable to set bssid in val for vap_id:12 RC:-1
[*10/15/2021 17:25:11.6681] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v12 error No such device
[*10/15/2021 17:25:11.6681] DOT11_DRV[1]: Unable to read bssid from val for vap_id:12
[*10/15/2021 17:25:11.6682] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A3
[*10/15/2021 17:25:11.6722] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v13 error No such device
[*10/15/2021 17:25:11.6723] DOT11_DRV[1]: Unable to set bssid in val for vap_id:13 RC:-1
[*10/15/2021 17:25:11.6763] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v13 error No such device
[*10/15/2021 17:25:11.6763] DOT11_DRV[1]: Unable to read bssid from val for vap_id:13
[*10/15/2021 17:25:11.6764] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A2
[*10/15/2021 17:25:11.6808] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v14 error No such device
[*10/15/2021 17:25:11.6809] DOT11_DRV[1]: Unable to set bssid in val for vap_id:14 RC:-1
***Output truncated 51387 bytes***
[*10/15/2021 17:25:21.8765] DOT11_TXP[0]:Domain configured: 1 class:E
[*10/15/2021 17:25:22.0457] DOT11_TXP[1]:Domain configured: 40 class:M
[*10/15/2021 17:25:22.5259] DOT11_TXP[2]:Domain configured: 1 class:E
[*10/15/2021 17:25:22.6672] DOT11_TXP[0]:Domain configured: 40 class:M
[*10/15/2021 17:25:25.1689]
[*10/15/2021 17:25:25.1689] Total STA List Count 0
[*10/15/2021 17:25:25.1689] | NO| MAC|STATE|
[*10/15/2021 17:25:25.1689] -----------------------------
[*10/15/2021 17:25:25.2093] DOT11_TXP[2]:Domain configured: 40 class:M
[*10/15/2021 17:25:25.2383]
[*10/15/2021 17:25:25.2383] Total STA-ID List Count 0
[*10/15/2021 17:25:25.2383] | NO| MAC|STA-ID|
[*10/15/2021 17:25:25.2383] ------------------------------
[*10/15/2021 17:25:28.2993] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:25:28.3108] ifconfig: SIOCGIFFLAGS: No such device
***Output truncated 7327 bytes***
[*10/15/2021 17:25:28.3602] Capabilities: [140 v1] Device Serial Number 00-00-00-00-00-00-00-00
[*10/15/2021 17:25:28.3602] Capabilities: [150 v1] Power Budgeting <?>
[*10/15/2021 17:25:28.3602] Capabilities: [160 v1] Latency Tolerance Reporting
[*10/15/2021 17:25:28.3602] Max snoop latency: 0ns
[*10/15/2021 17:25:28.3602] Max no snoop latency: 0ns
[*10/15/2021 17:25:28.3602] Kernel driver in use: wifi
[*10/15/2021 17:25:28.3686] wifi0 Link encap:Ethernet HWaddr B8:A3:77:83:AE:A0
[*10/15/2021 17:25:28.3687] BROADCAST MULTICAST MTU:1500 Metric:1
[*10/15/2021 17:25:28.3687] RX packets:2 errors:0 dropped:0 overruns:0 frame:0
[*10/15/2021 17:25:28.3687] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
[*10/15/2021 17:25:28.3687] collisions:0 txqueuelen:1000
[*10/15/2021 17:25:28.3687] RX bytes:188 (188.0 B) TX bytes:0 (0.0 B)
***Output truncated 40189 bytes***
[*10/15/2021 17:25:29.1131] Capabilities: [160 v1] Latency Tolerance Reporting
[*10/15/2021 17:25:29.1131] Max snoop latency: 0ns
[*10/15/2021 17:25:29.1131] Max no snoop latency: 0ns
[*10/15/2021 17:25:29.1131] Kernel driver in use: wifi
[*10/15/2021 17:25:29.1217] wifi0 Link encap:Ethernet HWaddr B8:A3:77:83:AE:A0
[*10/15/2021 17:25:29.1217] BROADCAST MULTICAST MTU:1500 Metric:1
[*10/15/2021 17:25:29.1217] RX packets:2 errors:0 dropped:0 overruns:0 frame:0
[*10/15/2021 17:25:29.1217] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
[*10/15/2021 17:25:29.1217] collisions:0 txqueuelen:1000
[*10/15/2021 17:25:29.1217] RX bytes:188 (188.0 B) TX bytes:0 (0.0 B)
[*10/15/2021 17:25:29.1218] Interrupt:65 Memory:f8000000-f8200000
[*10/15/2021 17:25:29.1358] ifconfig: wifi1: error fetching interface information: Device not found
[*10/15/2021 17:25:29.1362] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v6 error No such device
[*10/15/2021 17:25:29.1362] DOT11_DRV[1]: Unable to read bssid from val for vap_id:6
[*10/15/2021 17:25:29.1363] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A9
[*10/15/2021 17:25:29.1410] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v7 error No such device
[*10/15/2021 17:25:29.1410] DOT11_DRV[1]: Unable to set bssid in val for vap_id:7 RC:-1
[*10/15/2021 17:25:29.1452] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v7 error No such device
[*10/15/2021 17:25:29.1452] DOT11_DRV[1]: Unable to read bssid from val for vap_id:7
[*10/15/2021 17:25:29.1453] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A8
[*10/15/2021 17:25:29.1495] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v8 error No such device
[*10/15/2021 17:25:29.1496] DOT11_DRV[1]: Unable to set bssid in val for vap_id:8 RC:-1
[*10/15/2021 17:25:29.1537] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v8 error No such device
[*10/15/2021 17:25:29.1537] DOT11_DRV[1]: Unable to read bssid from val for vap_id:8
[*10/15/2021 17:25:29.1538] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A7
[*10/15/2021 17:25:29.1580] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v9 error No such device
[*10/15/2021 17:25:29.1581] DOT11_DRV[1]: Unable to set bssid in val for vap_id:9 RC:-1
[*10/15/2021 17:25:29.1621] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v9 error No such device
[*10/15/2021 17:25:29.1621] DOT11_DRV[1]: Unable to read bssid from val for vap_id:9
[*10/15/2021 17:25:29.1622] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A6
[*10/15/2021 17:25:29.1662] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v10 error No such device
[*10/15/2021 17:25:29.1663] DOT11_DRV[1]: Unable to set bssid in val for vap_id:10 RC:-1
[*10/15/2021 17:25:29.1722] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v10 error No such device
[*10/15/2021 17:25:29.1722] DOT11_DRV[1]: Unable to read bssid from val for vap_id:10
[*10/15/2021 17:25:29.1723] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A5
[*10/15/2021 17:25:29.1764] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v11 error No such device
[*10/15/2021 17:25:29.1765] DOT11_DRV[1]: Unable to set bssid in val for vap_id:11 RC:-1
[*10/15/2021 17:25:29.2269] 00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:25:29.2269] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:29.2269] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:25:29.2269] Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
[*10/15/2021 17:25:29.2269] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:25:29.2269] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:25:29.2269] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:25:29.2269] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:25:29.2269] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:25:29.2269] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:25:29.2269] 00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:25:29.2269] Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:29.2269] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:25:29.2270] Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
[*10/15/2021 17:25:29.2270] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:25:29.2270] Memory behind bridge: f8000000-f82fffff
[*10/15/2021 17:25:29.2270] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:25:29.2270] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:25:29.2270] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:25:29.2270] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:25:29.2270] 00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:25:29.2270] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:29.2270] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:25:29.2270] Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
[*10/15/2021 17:25:29.2270] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:25:29.2271] 02:00.0 Ethernet controller: Marvell Technology Group Ltd. Device 2b40
[*10/15/2021 17:25:29.2271] Subsystem: Marvell Technology Group Ltd. Device 0000
[*10/15/2021 17:25:29.2271] Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:29.2271] Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:25:29.2271] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:25:29.2271] Interrupt: pin A routed to IRQ 65
[*10/15/2021 17:25:29.2271] Region 0: Memory at f8000000 (64-bit, prefetchable) [size=2M]
[*10/15/2021 17:25:29.2271] Region 2: Memory at f8200000 (64-bit, prefetchable) [size=1M]
[*10/15/2021 17:25:29.2271] Capabilities: [40] Power Management version 3
[*10/15/2021 17:25:29.2271] Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold+)
[*10/15/2021 17:25:29.2271] Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
[*10/15/2021 17:25:29.2271] Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+
[*10/15/2021 17:25:29.2271] Address: 0000000000000000 Data: 0000
[*10/15/2021 17:25:29.2271] Masking: 00000000 Pending: 00000000
[*10/15/2021 17:25:29.2271] Capabilities: [70] Express (v2) Endpoint, MSI 00
[*10/15/2021 17:25:29.2271] DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <1us, L1 unlimited
[*10/15/2021 17:25:29.2271] ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
[*10/15/2021 17:25:29.2271] DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
[*10/15/2021 17:25:29.2271] RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
[*10/15/2021 17:25:29.2271] MaxPayload 128 bytes, MaxReadReq 512 bytes
[*10/15/2021 17:25:29.2271] DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
[*10/15/2021 17:25:29.2272] LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 unlimited
[*10/15/2021 17:25:29.2272] ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
[*10/15/2021 17:25:29.2272] LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
[*10/15/2021 17:25:29.2272] ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
[*10/15/2021 17:25:29.2272] LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
[*10/15/2021 17:25:29.2272] DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
[*10/15/2021 17:25:29.2272] DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
[*10/15/2021 17:25:29.2272] LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
[*10/15/2021 17:25:29.2272] Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
[*10/15/2021 17:25:29.2272] Compliance De-emphasis: -6dB
[*10/15/2021 17:25:29.2277] LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
[*10/15/2021 17:25:29.2277] EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
[*10/15/2021 17:25:29.2277] Capabilities: [b0] MSI-X: Enable- Count=32 Masked-
[*10/15/2021 17:25:29.2277] Vector table: BAR=2 offset=00001000
[*10/15/2021 17:25:29.2277] PBA: BAR=2 offset=00001800
[*10/15/2021 17:25:29.2277] Capabilities: [100 v2] Advanced Error Reporting
[*10/15/2021 17:25:29.2277] UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:25:29.2277] UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:25:29.2277] UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:25:29.2277] CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
[*10/15/2021 17:25:29.2277] CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
[*10/15/2021 17:25:29.2277] AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
[*10/15/2021 17:25:29.2277] Capabilities: [140 v1] Device Serial Number 00-00-00-00-00-00-00-00
[*10/15/2021 17:25:29.2277] Capabilities: [150 v1] Power Budgeting <?>
[*10/15/2021 17:25:29.2277] Capabilities: [160 v1] Latency Tolerance Reporting
[*10/15/2021 17:25:29.2277] Max snoop latency: 0ns
[*10/15/2021 17:25:29.2278] Max no snoop latency: 0ns
[*10/15/2021 17:25:29.2278] Kernel driver in use: wifi
[*10/15/2021 17:25:29.2363] wifi0 Link encap:Ethernet HWaddr B8:A3:77:83:AE:A0
[*10/15/2021 17:25:29.2363] BROADCAST MULTICAST MTU:1500 Metric:1
[*10/15/2021 17:25:29.2363] RX packets:2 errors:0 dropped:0 overruns:0 frame:0
[*10/15/2021 17:25:29.2363] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
[*10/15/2021 17:25:29.2363] collisions:0 txqueuelen:1000
[*10/15/2021 17:25:29.2363] RX bytes:188 (188.0 B) TX bytes:0 (0.0 B)
[*10/15/2021 17:25:29.2363] Interrupt:65 Memory:f8000000-f8200000
[*10/15/2021 17:25:29.2503] ifconfig: wifi1: error fetching interface information: Device not found
[*10/15/2021 17:25:29.2506] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v11 error No such device
[*10/15/2021 17:25:29.2506] DOT11_DRV[1]: Unable to read bssid from val for vap_id:11
[*10/15/2021 17:25:29.2507] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A4
[*10/15/2021 17:25:29.2549] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v12 error No such device
[*10/15/2021 17:25:29.2549] DOT11_DRV[1]: Unable to set bssid in val for vap_id:12 RC:-1
[*10/15/2021 17:25:29.2591] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v12 error No such device
[*10/15/2021 17:25:29.2591] DOT11_DRV[1]: Unable to read bssid from val for vap_id:12
[*10/15/2021 17:25:29.2592] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A3
[*10/15/2021 17:25:29.2633] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v13 error No such device
[*10/15/2021 17:25:29.2633] DOT11_DRV[1]: Unable to set bssid in val for vap_id:13 RC:-1
[*10/15/2021 17:25:29.2674] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v13 error No such device
[*10/15/2021 17:25:29.2674] DOT11_DRV[1]: Unable to read bssid from val for vap_id:13
[*10/15/2021 17:25:29.2675] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A2
[*10/15/2021 17:25:29.2716] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v14 error No such device
[*10/15/2021 17:25:29.2716] DOT11_DRV[1]: Unable to set bssid in val for vap_id:14 RC:-1
[*10/15/2021 17:25:29.2857] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v14 error No such device
[*10/15/2021 17:25:29.2857] DOT11_DRV[1]: Unable to read bssid from val for vap_id:14
[*10/15/2021 17:25:29.2858] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A1
[*10/15/2021 17:25:29.2904] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_BSSID failed for apr1v15 error No such device
[*10/15/2021 17:25:29.2905] DOT11_DRV[1]: Unable to set bssid in val for vap_id:15 RC:-1
[*10/15/2021 17:25:29.2946] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_GET_BSSID failed for apr1v15 error No such device
[*10/15/2021 17:25:29.2947] DOT11_DRV[1]: Unable to read bssid from val for vap_id:15
[*10/15/2021 17:25:29.2947] DOT11_DRV[1]: ERROR: Radio BSSID Addr: 00:00:00:00:00:00 does not match with driver BSSID Addr: B8:A3:77:83:AE:A0
[*10/15/2021 17:25:29.3060] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:25:29.3063] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver:ifconfig mon1 down failed
[*10/15/2021 17:25:29.3064] DOT11_DRV[1]: Stopped Radio 1
[*10/15/2021 17:25:29.3177] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:25:29.3286] wifi1 no private ioctls.
[*10/15/2021 17:25:29.3400] wifi1 no private ioctls.
[*10/15/2021 17:25:29.3509] Error for wireless request "Set Frequency" (8B04) :
[*10/15/2021 17:25:29.3510] SET failed on device wifi1 ; No such device.
[*10/15/2021 17:25:29.3512] DOT11_DRV[1]: DOT11_DRV[1]: set_channel Channel set to 100
[*10/15/2021 17:25:29.3621] apr1v0 no private ioctls.
[*10/15/2021 17:25:29.3731] apr1v1 no private ioctls.
[*10/15/2021 17:25:29.3840] apr1v2 no private ioctls.
[*10/15/2021 17:25:29.3950] apr1v3 no private ioctls.
[*10/15/2021 17:25:29.4060] apr1v4 no private ioctls.
[*10/15/2021 17:25:29.4171] apr1v5 no private ioctls.
[*10/15/2021 17:25:29.4282] apr1v6 no private ioctls.
[*10/15/2021 17:25:29.4283]
[*10/15/2021 17:25:29.4395] apr1v7 no private ioctls.
[*10/15/2021 17:25:29.4396]
[*10/15/2021 17:25:29.4505] apr1v8 no private ioctls.
[*10/15/2021 17:25:29.4616] apr1v9 no private ioctls.
[*10/15/2021 17:25:29.4727] apr1v10 no private ioctls.
[*10/15/2021 17:25:29.4837] apr1v11 no private ioctls.
[*10/15/2021 17:25:29.4947] apr1v12 no private ioctls.
[*10/15/2021 17:25:29.5058] apr1v13 no private ioctls.
[*10/15/2021 17:25:29.5167] apr1v14 no private ioctls.
[*10/15/2021 17:25:29.5168]
[*10/15/2021 17:25:29.5277] apr1v15 no private ioctls.
[*10/15/2021 17:25:29.5278]
[*10/15/2021 17:25:29.5392] apr1v0 no private ioctls.
[*10/15/2021 17:25:29.5502] apr1v0 no private ioctls.
[*10/15/2021 17:25:29.5612] apr1v1 no private ioctls.
[*10/15/2021 17:25:29.5721] apr1v1 no private ioctls.
[*10/15/2021 17:25:29.5831] apr1v2 no private ioctls.
[*10/15/2021 17:25:29.5942] apr1v2 no private ioctls.
[*10/15/2021 17:25:29.6052] apr1v3 no private ioctls.
[*10/15/2021 17:25:29.6163] apr1v3 no private ioctls.
[*10/15/2021 17:25:29.6274] apr1v4 no private ioctls.
[*10/15/2021 17:25:29.6386] apr1v4 no private ioctls.
[*10/15/2021 17:25:29.6387]
[*10/15/2021 17:25:29.6497] apr1v5 no private ioctls.
[*10/15/2021 17:25:29.6607] apr1v5 no private ioctls.
[*10/15/2021 17:25:29.6716] apr1v6 no private ioctls.
[*10/15/2021 17:25:29.6826] apr1v6 no private ioctls.
[*10/15/2021 17:25:29.6937] apr1v7 no private ioctls.
[*10/15/2021 17:25:29.7048] apr1v7 no private ioctls.
[*10/15/2021 17:25:29.7159] apr1v8 no private ioctls.
[*10/15/2021 17:25:29.7269] apr1v8 no private ioctls.
[*10/15/2021 17:25:29.7381] apr1v9 no private ioctls.
[*10/15/2021 17:25:29.7496] apr1v9 no private ioctls.
[*10/15/2021 17:25:29.7665] apr1v10 no private ioctls.
[*10/15/2021 17:25:29.7776] apr1v10 no private ioctls.
[*10/15/2021 17:25:29.7887] apr1v11 no private ioctls.
[*10/15/2021 17:25:29.7999] apr1v11 no private ioctls.
[*10/15/2021 17:25:29.8109] apr1v12 no private ioctls.
[*10/15/2021 17:25:29.8142] systemd[1]: capwapd.service failed.
[*10/15/2021 17:25:29.8223] apr1v12 no private ioctls.
[*10/15/2021 17:25:29.8224]
[*10/15/2021 17:25:29.8333] apr1v13 no private ioctls.
[*10/15/2021 17:25:29.8444] apr1v13 no private ioctls.
[*10/15/2021 17:25:29.8554] apr1v14 no private ioctls.
[*10/15/2021 17:25:29.8663] apr1v14 no private ioctls.
[*10/15/2021 17:25:29.8773] apr1v15 no private ioctls.
[*10/15/2021 17:25:29.8883] apr1v15 no private ioctls.
[*10/15/2021 17:25:29.8927] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_param ioctl WL_IOCTL_WL_PARAM failed for wifi1 error -1
[*10/15/2021 17:25:29.9035] apr1v0 no private ioctls.
[*10/15/2021 17:25:29.9151] apr1v0 no private ioctls.
[*10/15/2021 17:25:29.9260] apr1v1 no private ioctls.
[*10/15/2021 17:25:29.9261]
[*10/15/2021 17:25:29.9371] apr1v1 no private ioctls.
[*10/15/2021 17:25:29.9484] apr1v2 no private ioctls.
[*10/15/2021 17:25:29.9594] apr1v2 no private ioctls.
[*10/15/2021 17:25:29.9703] apr1v3 no private ioctls.
[*10/15/2021 17:25:29.9704]
[*10/15/2021 17:25:29.9815] apr1v3 no private ioctls.
[*10/15/2021 17:25:29.9925] apr1v4 no private ioctls.
[*10/15/2021 17:25:30.0035] apr1v4 no private ioctls.
[*10/15/2021 17:25:30.0146] apr1v5 no private ioctls.
[*10/15/2021 17:25:30.0256] apr1v5 no private ioctls.
[*10/15/2021 17:25:30.0367] apr1v6 no private ioctls.
[*10/15/2021 17:25:30.0477] apr1v6 no private ioctls.
[*10/15/2021 17:25:30.0478]
[*10/15/2021 17:25:30.0588] apr1v7 no private ioctls.
[*10/15/2021 17:25:30.0589]
[*10/15/2021 17:25:30.0698] apr1v7 no private ioctls.
[*10/15/2021 17:25:30.0808] apr1v8 no private ioctls.
[*10/15/2021 17:25:30.0918] apr1v8 no private ioctls.
[*10/15/2021 17:25:30.1027] apr1v9 no private ioctls.
[*10/15/2021 17:25:30.1138] apr1v9 no private ioctls.
[*10/15/2021 17:25:30.1247] apr1v10 no private ioctls.
[*10/15/2021 17:25:30.1358] apr1v10 no private ioctls.
[*10/15/2021 17:25:30.1471] apr1v11 no private ioctls.
[*10/15/2021 17:25:30.1581] apr1v11 no private ioctls.
[*10/15/2021 17:25:30.1691] apr1v12 no private ioctls.
[*10/15/2021 17:25:30.1815] apr1v12 no private ioctls.
[*10/15/2021 17:25:30.1932] apr1v13 no private ioctls.
[*10/15/2021 17:25:30.2042] apr1v13 no private ioctls.
[*10/15/2021 17:25:30.2153] apr1v14 no private ioctls.
[*10/15/2021 17:25:30.2263] apr1v14 no private ioctls.
[*10/15/2021 17:25:30.2373] apr1v15 no private ioctls.
[*10/15/2021 17:25:30.2485] apr1v15 no private ioctls.
[*10/15/2021 17:25:30.2961] 00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:25:30.2962] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:30.2962] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:25:30.2962] Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
[*10/15/2021 17:25:30.2962] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:25:30.2962] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:25:30.2962] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:25:30.2962] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:25:30.2962] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:25:30.2962] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:25:30.2962] 00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:25:30.2962] Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:30.2962] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:25:30.2962] Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
[*10/15/2021 17:25:30.2962] Memory behind bridge: f8000000-f82fffff
[*10/15/2021 17:25:30.2963] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:25:30.2963] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:25:30.2963] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:25:30.2963] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:25:30.2963] 00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:25:30.2963] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:30.2963] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:25:30.2963] Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
[*10/15/2021 17:25:30.2963] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:25:30.2963] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:25:30.2963] 02:00.0 Ethernet controller: Marvell Technology Group Ltd. Device 2b40
[*10/15/2021 17:25:30.2963] Subsystem: Marvell Technology Group Ltd. Device 0000
[*10/15/2021 17:25:30.2963] Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:30.2963] Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:25:30.2963] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:25:30.2964] Interrupt: pin A routed to IRQ 65
[*10/15/2021 17:25:30.2964] Region 0: Memory at f8000000 (64-bit, prefetchable) [size=2M]
[*10/15/2021 17:25:30.2964] Region 2: Memory at f8200000 (64-bit, prefetchable) [size=1M]
[*10/15/2021 17:25:30.2964] Capabilities: [40] Power Management version 3
[*10/15/2021 17:25:30.2964] Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold+)
[*10/15/2021 17:25:30.2964] Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
[*10/15/2021 17:25:30.2964] Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+
[*10/15/2021 17:25:30.2964] Address: 0000000000000000 Data: 0000
[*10/15/2021 17:25:30.2964] Masking: 00000000 Pending: 00000000
[*10/15/2021 17:25:30.2964] Capabilities: [70] Express (v2) Endpoint, MSI 00
[*10/15/2021 17:25:30.2964] DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <1us, L1 unlimited
[*10/15/2021 17:25:30.2964] ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
Stopping DHCPv6 client...
[*10/15/2021 17:25:30.2964] DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
[*10/15/2021 17:25:30.2964] RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
[*10/15/2021 17:25:30.2964] MaxPayload 128 bytes, MaxReadReq 512 bytes
[*10/15/2021 17:25:30.2964] DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
[*10/15/2021 17:25:30.2965] LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 unlimited
[*10/15/2021 17:25:30.2965] ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
[*10/15/2021 17:25:30.2965] LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
[*10/15/2021 17:25:30.2965] ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
[*10/15/2021 17:25:30.2965] LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
[*10/15/2021 17:25:30.2965] DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
[*10/15/2021 17:25:30.2965] DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
[*10/15/2021 17:25:30.2965] LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
[*10/15/2021 17:25:30.2965] Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
[*10/15/2021 17:25:30.2965] Compliance De-emphasis: -6dB
[*10/15/2021 17:25:30.2970] LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
[*10/15/2021 17:25:30.2970] EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
[*10/15/2021 17:25:30.2970] Capabilities: [b0] MSI-X: Enable- Count=32 Masked-
[*10/15/2021 17:25:30.2970] Vector table: BAR=2 offset=00001000
[*10/15/2021 17:25:30.2970] PBA: BAR=2 offset=00001800
[*10/15/2021 17:25:30.2970] Capabilities: [100 v2] Advanced Error Reporting
[*10/15/2021 17:25:30.2970] UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:25:30.2970] UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:25:30.2970] UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:25:30.2971] CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
[*10/15/2021 17:25:30.2971] CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
[*10/15/2021 17:25:30.2971] AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
[*10/15/2021 17:25:30.2971] Capabilities: [140 v1] Device Serial Number 00-00-00-00-00-00-00-00
[*10/15/2021 17:25:30.2971] Capabilities: [150 v1] Power Budgeting <?>
[*10/15/2021 17:25:30.2971] Capabilities: [160 v1] Latency Tolerance Reporting
[*10/15/2021 17:25:30.2971] Max snoop latency: 0ns
[*10/15/2021 17:25:30.2971] Max no snoop latency: 0ns
[*10/15/2021 17:25:30.2971] Kernel driver in use: wifi
[ OK [*10/15/2021 17:25:30.3055] wifi0 Link encap:Ethernet HWaddr B8:A3:77:83:AE:A0
[*10/15/2021 17:25:30.3055] BROADCAST MULTICAST MTU:1500 Metric:1
[*10/15/2021 17:25:30.3055] RX packets:2 errors:0 dropped:0 overruns:0 frame:0
[*10/15/2021 17:25:30.3055] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
[*10/15/2021 17:25:30.3055] collisions:0 txqueuelen:1000
[*10/15/2021 17:25:30.3056] RX bytes:188 (188.0 B) TX bytes:0 (0.0 B)
[*10/15/2021 17:25:30.3056] Interrupt:65 Memory:f8000000-f8200000
[*10/15/2021 17:25:30.3188] ifconfig: wifi1: error fetching interface information: Device not found
[*10/15/2021 17:25:30.3191] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_param ioctl WL_IOCTL_WL_PARAM failed for wifi1 error -1
[*10/15/2021 17:25:30.3233] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_param ioctl WL_IOCTL_WL_PARAM failed for apr1v0 error No such device
] Stopped target Multi-User System.
[*10/15/2021 17:25:30.3275] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_param ioctl WL_IOCTL_WL_PARAM failed for apr1v1 error No such device
[*10/15/2021 17:25:30.3315] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_param ioctl WL_IOCTL_WL_PARAM failed for apr1v2 error No such device
[*10/15/2021 17:25:30.3356] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_param ioctl WL_IOCTL_WL_PARAM failed for apr1v3 error No such device
[*10/15/2021 17:25:30.3398] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_param ioctl WL_IOCTL_WL_PARAM failed for apr1v4 error No such device
[*10/15/2021 17:25:30.3444] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_param ioctl WL_IOCTL_WL_PARAM failed for apr1v5 error No such device
[*10/15/2021 17:25:30.3487] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_param ioctl WL_IOCTL_WL_PARAM failed for apr1v6 error No such device
[*10/15/2021 17:25:30.3529] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_param ioctl WL_IOCTL_WL_PARAM failed for apr1v7 error No such device
[*10/15/2021 17:25:30.3571] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_param ioctl WL_IOCTL_WL_PARAM failed for apr1v8 error No such device
[*10/15/2021 17:25:30.4053] 00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:25:30.4053] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:30.4053] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:25:30.4054] Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
[*10/15/2021 17:25:30.4054] I/O behind bridge: 0000f000-00000fff
[*10/15/2021 17:25:30.4054] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:25:30.4054] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:25:30.4054] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:25:30.4054] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:25:30.4054] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:25:30.4054] 00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:25:30.4054] Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:30.4054] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:25:30.4054] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:25:30.4054] Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
[*10/15/2021 17:25:30.4054] Memory behind bridge: f8000000-f82fffff
[*10/15/2021 17:25:30.4055] 00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6920 (rev 08) (prog-if 00 [Normal decode])
[*10/15/2021 17:25:30.4055] Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:30.4055] Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:25:30.4055] Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
[*10/15/2021 17:25:30.4055] I/O behind bridge: 0000f000-00000fff
Stopping DNSmasq for host...
[*10/15/2021 17:25:30.4055] Memory behind bridge: fff00000-000fffff
[*10/15/2021 17:25:30.4055] Prefetchable memory behind bridge: 00000000-000fffff
[*10/15/2021 17:25:30.4055] Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
[*10/15/2021 17:25:30.4055] BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
[*10/15/2021 17:25:30.4055] PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
[*10/15/2021 17:25:30.4055] 02:00.0 Ethernet controller: Marvell Technology Group Ltd. Device 2b40
[*10/15/2021 17:25:30.4055] Subsystem: Marvell Technology Group Ltd. Device 0000
[*10/15/2021 17:25:30.4055] Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
[*10/15/2021 17:25:30.4055] Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
[*10/15/2021 17:25:30.4055] Latency: 0, Cache Line Size: 64 bytes
[*10/15/2021 17:25:30.4055] Interrupt: pin A routed to IRQ 65
[*10/15/2021 17:25:30.4055] Region 0: Memory at f8000000 (64-bit, prefetchable) [size=2M]
[*10/15/2021 17:25:30.4055] Region 2: Memory at f8200000 (64-bit, prefetchable) [size=1M]
[*10/15/2021 17:25:30.4055] Capabilities: [40] Power Management version 3
[*10/15/2021 17:25:30.4055] Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold+)
[*10/15/2021 17:25:30.4056] Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
[*10/15/2021 17:25:30.4056] Capabilities: [50] MSI: Enable- Count=1/32 Maskable+ 64bit+
[*10/15/2021 17:25:30.4056] Address: 0000000000000000 Data: 0000
[*10/15/2021 17:25:30.4056] Masking: 00000000 Pending: 00000000
[*10/15/2021 17:25:30.4056] Capabilities: [70] Express (v2) Endpoint, MSI 00
[*10/15/2021 17:25:30.4056] DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <1us, L1 unlimited
[*10/15/2021 17:25:30.4056] ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
[*10/15/2021 17:25:30.4056] DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
[*10/15/2021 17:25:30.4056] RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
[*10/15/2021 17:25:30.4056] MaxPayload 128 bytes, MaxReadReq 512 bytes
[*10/15/2021 17:25:30.4056] DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
[*10/15/2021 17:25:30.4056] LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 unlimited
[*10/15/2021 17:25:30.4056] ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
[*10/15/2021 17:25:30.4056] LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
[*10/15/2021 17:25:30.4056] ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
[*10/15/2021 17:25:30.4056] LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
[*10/15/2021 17:25:30.4056] DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
Stopping capwapd...
Stopping Marvell Forwarding daemon...
Stopping Fast CGI daemon...
[ OK ] Stopped target Timers.
[*10/15/2021 17:25:30.4056] DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
[*10/15/2021 17:25:30.4056] LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
[*10/15/2021 17:25:30.4056] Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
[*10/15/2021 17:25:30.4057] Compliance De-emphasis: -6dB
[*10/15/2021 17:25:30.4062] LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
[*10/15/2021 17:25:30.4062] EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
[*10/15/2021 17:25:30.4062] Capabilities: [b0] MSI-X: Enable- Count=32 Masked-
[*10/15/2021 17:25:30.4062] Vector table: BAR=2 offset=00001000
[*10/15/2021 17:25:30.4062] PBA: BAR=2 offset=00001800
[*10/15/2021 17:25:30.4062] Capabilities: [100 v2] Advanced Error Reporting
[*10/15/2021 17:25:30.4062] UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:25:30.4062] UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:25:30.4062] UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
[*10/15/2021 17:25:30.4062] CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
[*10/15/2021 17:25:30.4062] CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
[*10/15/2021 17:25:30.4062] AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
[*10/15/2021 17:25:30.4062] Capabilities: [140 v1] Device Serial Number 00-00-00-00-00-00-00-00
[*10/15/2021 17:25:30.4062] Capabilities: [150 v1] Power Budgeting <?>
[*10/15/2021 17:25:30.4062] Capabilities: [160 v1] Latency Tolerance Reporting
[*10/15/2021 17:25:30.4062] Max snoop latency: 0ns
[*10/15/2021 17:25:30.4062] Max no snoop latency: 0ns
[*10/15/2021 17:25:30.4062] Kernel driver in use: wifi
[*10/15/2021 17:25:30.4148] wifi0 Link encap:Ethernet HWaddr B8:A3:77:83:AE:A0
[*10/15/2021 17:25:30.4148] BROADCAST MULTICAST MTU:1500 Metric:1
[*10/15/2021 17:25:30.4148] RX packets:2 errors:0 dropped:0 overruns:0 frame:0
[*10/15/2021 17:25:30.4148] TX pack[10/15/2021 17:26:18.9100] reboot: Restarting system
BootROM - 1.78
Booting from SPI flash, Secure mode
BootROM: RSA Public key verification PASSED
BootROM: CSK block signature verification PASSED
BootROM: Boot header signature verification PASSED
BootROM: Box ID verification PASSED
BootROM: JTAG is disabled
General initialization - Version: 1.0.0
Detected Device ID 6920
Master bootloder version 1.24
High speed PHY - Version: 2.0
BoardId = 0x23board SerDes lanes topology details:
| Lane # | Speed| Type |
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
:** Link is Gen1, check the EP capability
PCIe, Idx 1: Link upgraded to Gen2 based on client cpabilities
PCIe, Idx 2: detected no link
High speed PHY - Ended Successfully
DDR4 Training Sequence - Ver TIP-0.23.(Sublib 0.8)0
DDR4 Training Sequence - Switching XBAR Window to FastPath Window
DDR4 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
BootROM: Boot image signature verification PASSED
____ _
/ ___|(_) ___ ___ ___
| | | |/ __| / __|/ _ \
| |___ | |\__ \| (__| (_) |
\____||_||___/ \___|\___/
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
** LOADER **
U-Boot 2013.01-gf899470 (Aug 16 2018 - 15:50:45) SDK version: 2015_T2.0p10
Board: Milos
SoC: MV88F6920 Rev A1
running 2 CPUs
CPU: ARM Cortex A9 MPCore (Rev 1) LE
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DDR4 32 Bit Width,FastPath Memory Access, DLB Enabled, ECC Disabled
DRAM: 1 GiB
RST I2C0
NAND: 256 MiB
SF: Detected MX25L3205D with page size 64 KiB, total 4 MiB
PCI-e 1 (IF 0 - bus 0) Root Complex Interface, Detected Link X1, GEN 2.0
PCI-e 1: Detected No Link.
Map: Code: 0x3fed9000:0x3ffad5c4
BSS: 0x3ffef080
Stack: 0x3f9c8f20
Heap: 0x3f9c9000:0x3fed9000
U-Boot Environment: 0x00100000:0x00110000 (SPI)
Board configuration:
| port | Interface | PHY address |
| egiga1 | SGMII | 0x01 |
SFP not detected, enable RJ45
Net: , egiga1 [PRIME]
Hit ESC key to stop autoboot: 0
Creating 1 MTD partitions on "nand0":
0x000000200000-0x000010000000 : "mtd=2"
UBI: attaching mtd1 to ubi0
UBIFS: mounted UBI device 0, volume 1, name "part2"
Loading file 'part2/part.bin' to addr 0x02000000 with size 6335021 (0x0060aa2d)...
Done
Checking image signing.
Image signing verification success, continue to run...
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Barbados Firmware Image
Created: 2020-10-30 23:30:20 UTC
Image Type: ARM Linux Multi-File Image (uncompressed)
Data Size: 6334013 Bytes = 6 MiB
Load Address: 00008000
Entry Point: 00008000
Contents:
Image 0: 4203272 Bytes = 4 MiB
Image 1: 2114585 Bytes = 2 MiB
Image 2: 16137 Bytes = 15.8 KiB
Verifying Checksum ... OK
## Loading init Ramdisk from multi component Legacy Image at 02000000 ...
## Flattened Device Tree from multi component Image at 02000000
Booting using the fdt at 0x02606774
Loading Multi-File Image ... OK
OK
reserving fdt memory region: addr=0 size=4000
Loading Device Tree to 01ff9000, end 01ffff08 ... OK
Starting Device Tree update ('fdt_skip_update' = no)
Limit DDR size at 3GB due to power of 2 requirement of Address decoding
Updating device tree successful
Starting kernel ...
[01/01/1970 00:00:00.0000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
[01/01/1970 00:00:00.0000] Memory: 1025836K/1048576K available (5743K kernel code, 407K rwdata, 2480K rodata, 359K init, 478K bss, 22740K reserved)
[01/01/1970 00:00:00.1200] CPU1: Booted secondary processor
[01/01/1970 00:00:01.4200] buginf tty flushing thread started, ttyport=be890400
[01/01/1970 00:00:01.5500] m25p80 spi1.0: found mx25l3206, expected n25q032
[01/01/1970 00:00:03.8400] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:05.9300] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:08.0200] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:10.1100] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:12.2000] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:14.2900] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:16.3800] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:18.4700] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[*08/21/2019 15:03:57.5008] buginf() enabled.
[*08/21/2019 15:03:57.5104] Made it into bootsh: Oct 30 2020 16:21:13 T-a9e4eaf8ccf0cad1ba59eaa8794b7332dbca2d5a-ga9e4eaf8-aut
[*08/21/2019 15:04:05.1826] bootsh mini ramfs booted /bootpart/part2/ramfs_data_cisco.cpio.lzma
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
[*08/21/2019 15:04:27.0106] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*08/21/2019 15:04:27.0136] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*08/21/2019 15:04:27.0503] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*08/21/2019 15:04:27.0532] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[ OK ] Created slice -.slice.
[ OK ] Created slice system.slice.
[ OK ] Reached target Slices.
Starting Cisco UBIFS reformat/mount...
[ OK ] Reached target Cisco File Systems (Pre).
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Reached target Timers.
[ OK ] Listening on udev Control Socket.
Starting udev Kernel Device Manager...
Starting udev Coldplug all Devices...
[ OK ] Listening on Delayed Shutdown Socket.
[ OK ] Reached target Sockets.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Cisco UBIFS reformat/mount.
Starting Cisco early mount...
[ OK ] Started Cisco early mount.
[ OK ] Reached target Local File Systems (Pre).
Starting Cisco fips check...
Starting Cisco seed generation...
Starting Cisco platform file generation...
Starting Cisco system time setup...
[ OK ] Started Cisco seed generation.
[*08/14/2021 23:59:59.0692] Last reload time: Oct 15 17:23:27 2021
[*10/15/2021 17:23:27.0081] Setting system time Fri Oct 15 17:23:27 UTC 2021
[ OK ] Started Cisco system time setup.
[ OK ] Started Cisco fips check.
[ OK ] Started Cisco platform file generation.
Starting Cisco btldr service...
[*10/15/2021 17:23:27.9403] GCM-128 POST passed
[*10/15/2021 17:23:27.9403] GCM-256 POST passed
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Cisco btldr service.
[ OK ] Reached target Local File Systems.
Starting Cisco act2 check...
Starting Cisco S10 boot service...
[10/15/2021 17:23:29.7600] audit: audit_lost=1 audit_rate_limit=0 audit_backlog_limit=64
[10/15/2021 17:23:29.7600] audit: printk limit exceeded
Starting Security Auditing Service...
[*10/15/2021 17:23:29.7715] parameter passed without an option given
[*10/15/2021 17:23:30.0656] 43
Starting Cisco pkg install service...
[ OK ] Started Cisco system time saving.
Starting Cisco system time saving...
[*10/15/2021 17:23:30.2568] Active version: 17.3.2.32
[*10/15/2021 17:23:30.2595] Backup version: 8.10.130.0
[ OK ] Started Security Auditing Service.
[10/15/2021 17:23:30.9000] PCI: enabling device 0000:00:02.0 (0140 -> 0143)
[10/15/2021 17:23:30.9800] PCI: enabling device 0000:02:00.0 (0140 -> 0142)
[10/15/2021 17:23:31.9000] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ OK ] Started Cisco pkg install service.
[ OK ] Started Cisco S10 boot service.
Starting Cisco nolan service...
Starting Cisco watchdog...
[*10/15/2021 17:23:30.5740]
[*10/15/2021 17:23:30.5740] led pattern module start
[*10/15/2021 17:23:30.6945] device wired0 entered promiscuous mode
[*10/15/2021 17:23:31.0659] wifi0: Initializing TX ring
[*10/15/2021 17:23:31.0703] wifi0: Initializing RX ring
[*10/15/2021 17:23:31.0751] wifi0: prepare firmware downloading
[*10/15/2021 17:23:31.8706] wifi0: Firmware downloading
[*10/15/2021 17:23:33.2890] 0;
[*10/15/2021 17:23:33.7844]
[*10/15/2021 17:23:33.7844] Authenticating ACT2 ID:AP1560
[*10/15/2021 17:23:33.7844] Authenticating SN:FOC25296NZE
[*10/15/2021 17:23:33.7850]
[*10/15/2021 17:23:33.7850] (ACT2Boot) Hardware is Cisco (c) authentic
[*10/15/2021 17:23:33.7851]
[*10/15/2021 17:23:33.7927] Seeding /dev/urandom from ACT2
[*10/15/2021 17:23:33.8363] 0;<30>systemd[1]: Started Cisco pkg install service.
[*10/15/2021 17:23:34.3204]
[*10/15/2021 17:23:34.3204] Firmware download complete
[*10/15/2021 17:23:34.4589] Reading ACT2 SUDI certificates
[*10/15/2021 17:23:34.5104] wifi0: Getting HW specs. Retrying for 3
[*10/15/2021 17:23:34.5106] Mac_Init
[*10/15/2021 17:23:34.5110] Preparing to set HW specs
[*10/15/2021 17:23:34.5113] FIPS enc aes-ccmp Verified
[*10/15/2021 17:23:34.5114] FIPS dec aes-ccmp Verified
[*10/15/2021 17:23:34.5115] FIPS enc aes-ccmp-256 Verified
[*10/15/2021 17:23:34.5116] FIPS dec aes-ccmp-256 Verified
[*10/15/2021 17:23:34.5117] FIPS enc aes-gcmp Verified
[*10/15/2021 17:23:34.5118] FIPS dec aes-gcmp Verified
[*10/15/2021 17:23:34.5119] FIPS enc aes-gcmp-256 Verified
[*10/15/2021 17:23:34.5120] FIPS dec aes-gcmp-256 Verified
[*10/15/2021 17:23:35.1096] wifi1 no private ioctls.
[*10/15/2021 17:23:35.1148] wifi1 no private ioctls.
[*10/15/2021 17:23:35.1198] wifi1 no private ioctls.
[*10/15/2021 17:23:35.1250] Error for wireless request "Set Frequency" (8B04) :
[*10/15/2021 17:23:35.1250] SET failed on device wifi1 ; No such device.
[*10/15/2021 17:23:35.1303] Error for wireless request "Set ESSID" (8B1A) :
[*10/15/2021 17:23:35.1303] SET failed on device apr1v0 ; No such device.
[*10/15/2021 17:23:35.1406] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.1512] apr1v0 no private ioctls.
[*10/15/2021 17:23:35.1562] apr1v0 no private ioctls.
[*10/15/2021 17:23:35.1563]
[*10/15/2021 17:23:35.1616] apr1v0 no private ioctls.
[*10/15/2021 17:23:35.1678] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.1731] apr1v0 no private ioctls.
[*10/15/2021 17:23:35.1782] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.1782] SET failed on device apr1v0 ; No such device.
[*10/15/2021 17:23:35.1844] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.1912] apr1v1 no private ioctls.
[*10/15/2021 17:23:35.1963] apr1v1 no private ioctls.
[*10/15/2021 17:23:35.2016] apr1v1 no private ioctls.
[*10/15/2021 17:23:35.2017]
[*10/15/2021 17:23:35.2077] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.2131] apr1v1 no private ioctls.
[*10/15/2021 17:23:35.2181] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.2181] SET failed on device apr1v1 ; No such device.
[*10/15/2021 17:23:35.2245] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.2312] apr1v2 no private ioctls.
[*10/15/2021 17:23:35.2371] apr1v2 no private ioctls.
[*10/15/2021 17:23:35.2425] apr1v2 no private ioctls.
[*10/15/2021 17:23:35.2489] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.2542] apr1v2 no private ioctls.
[*10/15/2021 17:23:35.2593] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.2594] SET failed on device apr1v2 ; No such device.
[*10/15/2021 17:23:35.2655] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.2723] apr1v3 no private ioctls.
[*10/15/2021 17:23:35.2774] apr1v3 no private ioctls.
[*10/15/2021 17:23:35.2827] apr1v3 no private ioctls.
[*10/15/2021 17:23:35.2887] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.2940] apr1v3 no private ioctls.
[*10/15/2021 17:23:35.3033] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.3034] SET failed on device apr1v3 ; No such device.
[*10/15/2021 17:23:35.3093] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.3222] apr1v4 no private ioctls.
[*10/15/2021 17:23:35.3273] apr1v4 no private ioctls.
[*10/15/2021 17:23:35.3323] apr1v4 no private ioctls.
[*10/15/2021 17:23:35.3382] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.3436] apr1v4 no private ioctls.
[*10/15/2021 17:23:35.3485] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.3486] SET failed on device apr1v4 ; No such device.
[*10/15/2021 17:23:35.3546] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.3638] apr1v5 no private ioctls.
[*10/15/2021 17:23:35.3688] apr1v5 no private ioctls.
[*10/15/2021 17:23:35.3738] apr1v5 no private ioctls.
[*10/15/2021 17:23:35.3798] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.3852] apr1v5 no private ioctls.
[*10/15/2021 17:23:35.3903] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.3903] SET failed on device apr1v5 ; No such device.
[*10/15/2021 17:23:35.3964] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.4031] apr1v6 no private ioctls.
[*10/15/2021 17:23:35.4082] apr1v6 no private ioctls.
[*10/15/2021 17:23:35.4133] apr1v6 no private ioctls.
[*10/15/2021 17:23:35.4193] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.4247] apr1v6 no private ioctls.
[*10/15/2021 17:23:35.4298] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.4299] SET failed on device apr1v6 ; No such device.
[*10/15/2021 17:23:35.4360] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.4428] apr1v7 no private ioctls.
[*10/15/2021 17:23:35.4479] apr1v7 no private ioctls.
[*10/15/2021 17:23:35.4480]
[*10/15/2021 17:23:35.4530] apr1v7 no private ioctls.
[*10/15/2021 17:23:35.4592] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.4647] apr1v7 no private ioctls.
[*10/15/2021 17:23:35.4648]
[*10/15/2021 17:23:35.4698] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.4698] SET failed on device apr1v7 ; No such device.
[*10/15/2021 17:23:35.4760] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.4827] apr1v8 no private ioctls.
[*10/15/2021 17:23:35.4878] apr1v8 no private ioctls.
[*10/15/2021 17:23:35.4930] apr1v8 no private ioctls.
[*10/15/2021 17:23:35.4992] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.5046] apr1v8 no private ioctls.
[*10/15/2021 17:23:35.5102] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.5102] SET failed on device apr1v8 ; No such device.
[*10/15/2021 17:23:35.5168] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.5235] apr1v9 no private ioctls.
[*10/15/2021 17:23:35.5285] apr1v9 no private ioctls.
[*10/15/2021 17:23:35.5337] apr1v9 no private ioctls.
[*10/15/2021 17:23:35.5397] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.5454] apr1v9 no private ioctls.
[*10/15/2021 17:23:35.5504] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.5505] SET failed on device apr1v9 ; No such device.
[*10/15/2021 17:23:35.5565] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.5632] apr1v10 no private ioctls.
[*10/15/2021 17:23:35.5721] apr1v10 no private ioctls.
[*10/15/2021 17:23:35.5771] apr1v10 no private ioctls.
[*10/15/2021 17:23:35.5831] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.5883] apr1v10 no private ioctls.
[*10/15/2021 17:23:35.5933] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.5933] SET failed on device apr1v10 ; No such device.
[*10/15/2021 17:23:35.5993] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.6059] apr1v11 no private ioctls.
[*10/15/2021 17:23:35.6060]
[*10/15/2021 17:23:35.6110] apr1v11 no private ioctls.
[*10/15/2021 17:23:35.6160] apr1v11 no private ioctls.
[*10/15/2021 17:23:35.6221] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.6274] apr1v11 no private ioctls.
[*10/15/2021 17:23:35.6323] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.6324] SET failed on device apr1v11 ; No such device.
[*10/15/2021 17:23:35.6383] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.6450] apr1v12 no private ioctls.
[*10/15/2021 17:23:35.6451]
[*10/15/2021 17:23:35.6501] apr1v12 no private ioctls.
[*10/15/2021 17:23:35.6553] apr1v12 no private ioctls.
[*10/15/2021 17:23:35.6614] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.6668] apr1v12 no private ioctls.
[*10/15/2021 17:23:35.6719] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.6720] SET failed on device apr1v12 ; No such device.
[*10/15/2021 17:23:35.6780] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.6847] apr1v13 no private ioctls.
[*10/15/2021 17:23:35.6898] apr1v13 no private ioctls.
[*10/15/2021 17:23:35.6949] apr1v13 no private ioctls.
[*10/15/2021 17:23:35.7010] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.7064] apr1v13 no private ioctls.
[*10/15/2021 17:23:35.7114] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.7115] SET failed on device apr1v13 ; No such device.
[*10/15/2021 17:23:35.7177] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.7243] apr1v14 no private ioctls.
[*10/15/2021 17:23:35.7244]
[*10/15/2021 17:23:35.7295] apr1v14 no private ioctls.
[*10/15/2021 17:23:35.7346] apr1v14 no private ioctls.
[*10/15/2021 17:23:35.7410] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.7462] apr1v14 no private ioctls.
[*10/15/2021 17:23:35.7514] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.7514] SET failed on device apr1v14 ; No such device.
[*10/15/2021 17:23:35.7574] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.7642] apr1v15 no private ioctls.
[*10/15/2021 17:23:35.7643]
[*10/15/2021 17:23:35.7693] apr1v15 no private ioctls.
[*10/15/2021 17:23:35.7745] apr1v15 no private ioctls.
[*10/15/2021 17:23:35.7807] ifconfig: SIOCSIFHWADDR: No such device
[*10/15/2021 17:23:35.7860] apr1v15 no private ioctls.
[*10/15/2021 17:23:35.7911] Error for wireless request "Commit changes" (8B00) :
[*10/15/2021 17:23:35.7911] SET failed on device apr1v15 ; No such device.
[*10/15/2021 17:23:35.7973] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:35.8034] ifconfig: SIOCGIFFLAGS: No such device
[*10/15/2021 17:23:36.0149] Last reload reason : 23: Systemd critical process crash
Starting Cisco nss service...
[*10/15/2021 17:23:49.6845] Initializing NSS Firmware
[ OK ] Started Cisco act2 check.
[ OK ] Started Cisco nolan service.
[ OK ] Started Cisco watchdog.
[ OK ] Started Cisco pre-PoE negotiation.
Starting Cisco pre-PoE negotiation...
Rich R
Please don't paste long logs into threads - just attach them as text (.txt) files (which you seem to have done anyway)?
Suggest to open a TAC case and they might need RMA.
We suspect there may be quality issues with 1562 at the moment - we've had to RMA a whole lot of them recently because they were dead on arrival or failed very soon after install (not even powering on).  We've asked TAC to do EFA (Engineering Failure Analysis) on 4 of them but that process can take up to 6 months so we don't expect any results for some time.
DonZalo
I suspect I'm having same issue. Did you have some feedback from TAC?
Thank you in advance
What exactly is your problem @DonZalo ?
A much more likely reason for a 1562 not joining is that it is in mesh (bridge) mode and you've forgotten to add the MAC address to the WLC.  You either add the MAC address to the WLC or change the AP to local mode to resolve that.
The EFA on our failed 1562's concluded it was a variety of different component failures so no single systemic fault to blame.
Thank you for your fast response, @Rich R
AP is not registering at WLC. I have  checked (with a packet capture) that option 43 is properly sent by DHCP server (i have another APs working properly) but I cannot see AP trying to reach WLC. It gets IP settings from DHCP server but seems not looking for WLC. AP just reboots in a continuous loop
I also added MAC to WLC using command "username 0123456789abc mac". AP will be cabled (root)
What do the AP console logs show?
You also need to configure the authorization (not just the MAC username) as per https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/215100-join-mesh-aps-to-catalyst-9800-wireless.html#toc-hId-259376220 did you do that?
Attach the boot-up process of the AP.
DonZalo
Thank you, @Rich R. Authorization and authentication is configured. I have more AP1562 devices working
Thank you, @Leo Laohoo. I attach log
**Edit: Removed thousands of lines and attached file
Oops - you missed the note above about attaching logs in a text file instead of pasting thousands of lines into the thread but anyway ...
Active version: 8.10.130.0
Note that you are running the Mobility Express software on that AP so you will need to convert the AP to CAPWAP mode before you do anything else!
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-2/b_Mobility_Express_Deployment_guide/b_Mobility_Express_Deployment_guide_chapter_01100.html#task_CD04E8319602439D973B7D7ACE23111D
Remember that must be done from the AP's CLI not the ME AireOS CLI so from the ME CLI connect to the AP CLI using the "apciscoshell" command.
Then upgrade the AP to 8.10.196.0 (15.3.3-JK11) https://software.cisco.com/download/home/286290657/type/286288051/release/15.3.3-JK11 or the version matching your WLC code version (which should be updated as per the TAC recommended link below) and do a factory default reset on the AP.  Then try again and attach the logs here in a .txt file.
ps I suspect that it will probably just work when you convert it to CAPWAP mode so you may not even need to default and upgrade.
DonZalo
Thank you, @Rich R
I attach log file after changing to CAPWAP mode. I see these messages not seeming to be normal:
Critical process has crashed repeatedly, This will result in reboot of system
systemd[1]: wcpd.service failed.
@DonZalo wrote:
[01/01/1970 00:00:03.8200] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:05.9100] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:08.0000] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:10.0900] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:12.1800] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:14.2700] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:16.3600] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
[01/01/1970 00:00:18.4500] i2c i2c-3: mv64xxx: I2C bus locked, block: 1, time_left: 0
I do not believe I've ever seen an error message before and based on CSCwh78779, I'd say it is time to get the AP RMAed.
DonZalo
Thank you, Leo
