AP1562e
steve00077
Community Member
I have a quantity of 5 APs to install and I had to factory reset the AP because it does not advertise its SSID when it boots up.
My questions are as follows:-
1. Since I can get into the console port, is there a default config file I can use to manually configure these APs?
2. Is there a Gui that I can use to do the same? If yes, what is the procedure and login info?
3. If I wanted to use the WLCs, what model should I consider to purchase?
Thank you
Steve Johnson
Mark Elsen
 - As far as the last question is concerned you need a controller which is compatible with the particular ap-model :
           https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
 Once a controller is used, the AP's are configured by  the controller settings for SSID/WLAN/etc.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Sandeep Choudhary
cisco AP 1562 comes with two diff kind of software images .
Cisco Mobility Express   - These APs are able to chose the controller among themselves and work without hardware WLC
Lightweight AP Software  - If you have this image on APs then you will need a seperate WLC to manage, configure these APs
Dont forget to rate helpful posts
Leo Laohoo
The only way is to get onto a ladder and console into the APs -- no other way.
Thanks for your reply. I have the AP in front of me on my desk and I had to factory reset one. I can get in the Console port and access the command line but I need help on how to configure it. Just the basic config is what I need.
Do you have access to these instructions?
Thank you
Steve Johnson
