AP1602E - basic configuration guide ..
francisco.carbajal
Community Member
I bought a new  1602E ap  .. so it comes with no documentation and the only doc that i foudn in the net  it was this:
http://www.sws.cz/prod_img/cisco/ap1600getstart.pdf
but  I need the  started guide to the basic configuration ..
My concern is  because   the AP will be used for a  producction enviroment and    the  point will  be
what will be the  best  radio configuration  with  open with non security  .. ? 2.4 or 5ghz ..
is any one know about it  I appretitate your support
thnks  in advanced
regards
Abha Jha
do you have AIR-CAP or AIR-SAP
as AIR-CAP is controller based AP where you need the WLC to get the AP configured. Simply you have to connect the AP with POE.
AIR-SAP is standalone and below is the doc to configure it:-
http://www.cisco.com/en/US/docs/wireless/access_point/15_2_4_JA/configuration/guide/scg15.2.4_book.html
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080c0b93c.shtml
2.4 GHZ or 5GHZ depends on what type of clients you want to connect ? If you have clients with A radio/ N radio then you need 5 GHZ and if your client is having G radio/N radio you can go for 2.4 GHZ.
Abha Jha
thanks it is
AIR-SAP
I will chek the documents  ..  thnks  //
