AP1702i does not join WLC5520
kuweb
Hello I have a problem to join a 1702i AP to the 5520 controller. I have attached the debug capwap and the console output of the AP.
On the Controller runs the newest SW Release 8.3.102
Has anyone an idea whats the problem?
Thanks for your help
5 Replies 5
Leo Laohoo
Unknown AP type. Using Controller Version!!!
CSCuy50490
Hi Leo
I saw this bug, and I installed the newest (fixed) version 8.3.102. But it doesn't work
which country did you configure on WLC ?
Make sure the time is set properly on the WLC and also make sure the country code for the APs are set on the WLC.
Hi Sandeep
On the controller I configured CH - Switzerland and the AP is AIR-CAP1702I-E-K9 that should be o.k.
yes regulatory domain is ok.
Did you set the time correctly ? also try to reboot WLC!!!
if still fail then use any other software...
