AP2802E - Custom channel/power not allowed
guybrush8
We have a WLC running 8.2.151.0 with 2802E APs. We need to configure custom channel/power but it is not allowed. If Radio Role Assignment is set to Auto, channel/power assignment method is disabled. When we change Radio Role Assigment to Manual, Global assignment method radio button becomes blue, however Custom button stays disabled.
I found out a bug on 8.2.124.8 version: CSCuz66684     Barbados:  channel / power should not allow to change when xor band auto, but this bug is not yet publicly available.
Should be channel and power assignment customizable? Do you think that this bug could be related to our issue?
Thank you in advance
biaacer2
Under Radio Role Assignment, Select "Manual"
Then click Apply.
Now you will be able to choose Global or Custom.
So, the secret is to click apply after selecting manual, which is not the most logical thing, I know.
biaacer2
Then click Apply.
You are right. Thank you for your help!
Thank you! SOLVED
