AP2802I
I received shipment of AIR-AP2802I from Cisco and on shipping box label , Prod.# shows AIR-AP2802I-B-K9C and on same label Base P/N shows AIR-AP2802I-B-KC. So what do I have, the AP with Mobility Express or Lifghyweight version?
Scott Fella
For any of these access points, you can convert them to whatever you need.  Here is a Mobility Express guide that can walk you through it.
Cisco Mobility Express Deployment Guide–Release 8.3.102.0 - Deploying Cisco Mobility Express Solution [Cisco 5500 Series Wireless Controllers] - Cisco
-Scott
Thank You. Much Appreciated.
No worries.... there are times where what was shipped is not what was expected.  So the conversion process is required and typically if the ap is out of the box, there are commands to change it without much work.
-Scott
