AP350 Access Point Steady Red on Infrastructure status light
tschmier
We have a AP350 access point that is getting a steady red light on the infrastructure status light. We have a clean connection on both the switch and ethernet port on the AP. While connected via serial port the boot process does not display any errors. Any help would be appreciated. The version of the firmware is 12.03T.
Tim Schmier
sbilgi
Level 5
Level 5
Try upgrading the firmware version and see if the issue is getting solved.
