API - Block a device from an SSID
CiscoUser14
Community Member
I need help with blocking a device from a specific SSID using API.
There is an option to do so in the Meraki UI by selecting the client:
It does the work just fine. I am looking to find a way to do the same using an API request.
checking client policy by
/networks/[networkId]/clients/[client_mac]/policy
Before changing:
"mac": "__MAC___",
"type": "Normal"
After changing
"mac": "__MAC___",
"type": "Different policies by SSID",
"ssids": {
"0": {
"type": "Normal",
"name": "SSID_Name0"
"1": {
"type": "Normal",
"name": "SSID_Name1"
"3": {
"type": "Blocked",
"name": "SSID_Name3"
I know I can send a request with device policy being whitelisted/blocked/normal/group, but I aim for "Different policies by SSID" or any other way to achieve it, if anyone knows.
Thanks in advance
CiscoUser14
Community Member
Thanks for trying to help, found the way.
PUT request to
api.meraki.com/api/v0/networks/{{NetworkId}}/clients/{{ClientMac}}/policy?timespan=86400&devicePolicy=Different policies by SSID
with the body
blocked_msg=&access=custom&custom_policy%5B0%5D=-1&custom_policy%5B1%5D=-1&custom_policy%5B3%5D=1&ids%5B%5D=DEVICE_ID
(when parsed it looks like this:)
Will get the result of the client having 'Normal' policy towards ssids with ID 0 and 1
'Blocked' for ssid with ID 3
hody.crouch
Level 7
Level 7
The API does not appear to support setting different group policies for a client by SSID. I'm not aware of any workaround.
CiscoUser14
Community Member
PUT request to
with the body
Would love to use this myself! I'm not following the url you're using for the request. As far as I know you can't put spaces in the url, so how were you able to accomplish adding "devicePolicy=Different policies by SSID" to the end of the put request?
Gal_Tfilin
Community Member
I tried @CiscoUser14 's solution and could not make it work.
However, I managed to find the documentation of that functionality under the following API:
https://developer.cisco.com/meraki/api/#!provision-network-clients
under schema definition.
You should set Per connection policy and list the SSIDs you would like to change the device's policy for them
Here is an example for a request's body that would block device for specific SSIDs:
"mac": "aa:aa:aa:aa:aa:aa",
"devicePolicy": "Per connection",
"timespan": 2592000,
"policiesBySsid": {
"9": {
"devicePolicy": "Blocked"
Sending this body in a post request to /networks/{networkId}/clients/provision will block any device with MAC aa:aa:aa:aa:aa:aa from connecting to SSID on index 9(you can get that using GET /networks/{networkId}/ssids)
