03-24-2014 06:52 AM - edited 07-05-2021 12:31 AM
Hi All,
will Apple AirPlay work just putting the below configuration under the L3 vlan interface
appletalk cable-range 10602-10602 10602.1 appletalk zone LGA1180 appletalk domain-group 1
please suggest.
Thanks in Advance.
Solved! Go to Solution.
03-26-2014 10:16 PM
Yes this is the way you configure interface for Apple talk.
http://www.cisco.com/c/en/us/td/docs/ios/at/configuration/guide/12_4t/atk_12_4t_book/config_appletalk.html#wp1051815
Log in to Community
