APs and Controllers clock synchronization
Rosa Ladeira
Level 7
Level 7
I have telneted to 2 APs joined to the same controller.
sh logging command shows each AP has a differente time which is different from controller time.
The difference is about 2 hours.
controller is syncronized with system's ntp.
date is correct for controller and APs.
How can I set AP clock?
Rasika Nayanajith
AP always in UTC time zone & you cannot set it any further.
Leave it as it is.
Rasika
**** Pls rate all useful responses ****
