APs capwap is not stable..and How to ping the AP from controller
Erfan7
1. I have Ten(10) 2602i and 2702i APs on one site, all APs are intermittent, both models are mixed mode(Flex and local), I have enable link latency on all APs and Max is between 250 and 200, I have got debug logs of APs from controller and one log is common (*osapiBsnTimer: Mar 25 23:02:13.036: [SA] Same gateway prevails), please anybody has information about this log message, what is the reason for this message, I have searched a lot for this log message but couldn't find a concrete answer, btw all things are normal (domain, country code, MIC), Primary and secondary controllers are on same code(8.5.151.0), one more thing is common whenever APs capwap restart, most of time they start redownloading the code.
2. My 2nd question is about ping, when I ping the AP IP from controller CLI or GUI it only pings for 3 packets, how can set the repeat count when I use command on WLC Ping x.x.x.x VLAN XX 100 1500 it still pings for 3 packets or show me incorrect interface.
8 Replies 8
Mark Elsen
 - I wouldn't get too much involved with the pings, for controller have a config sanity check with : https://cway.cisco.com/tools/WirelessAnalyzer/ also use recommended software release wherever possible : https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
under config boot, which image you see active ?
what is redundancy you have N+1 or SSO? what is your WLC ?
WLC is 8510, infect when APs started flapping, I migrated all APs to 3rd controller that has 8.0.120.21 code, APs were still intermittent, then I reverted all to 1st and 2nd controllers that have 8.5.151.0 code, but now when they flap they 1st download the old code 120.21 and then latest code 151.0. , I have SSO redundancy..
please can you share the output form one AP
AP# Show running-config
Dear MHM, Here is the O/P
dot11 ssid XXXXX
dot11 pause-time 100
dot11 syslog
dot11 flex native-vlan-lvl 0
dot11 flex clear 0
eap profile lwapp_eap_profile
 method fast
no ipv6 cef
crypto pki trustpoint cisco-m2-root-cert
 revocation-check none
crypto pki trustpoint Cisco_IOS_M2_MIC_cert
crypto pki trustpoint airespace-old-root-cert
 rsakeypair Cisco_IOS_MIC_Keys
crypto pki trustpoint airespace-new-root-cert
crypto pki trustpoint airespace-device-root-cert
crypto pki trustpoint cisco-root-cert
crypto pki trustpoint Cisco_IOS_MIC_cert
 match certificate ciscomic allow expired-certificate
crypto pki trustpoint virtual_wlc_trust_point
 revocation-check crl
 match certificate vwlcssc allow expired-certificate
crypto pki certificate map ciscomic 10
 issuer-name co cn = cisco manufacturing ca, o = cisco systems
crypto pki certificate map vwlcssc 1
 subject-name co o = cisco virtual wireless lan controller
crypto pki certificate chain cisco-m2-root-cert
 certificate ca 01
  30820313 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXxxxxx
        quit
crypto pki certificate chain Cisco_IOS_M2_MIC_cert
 certificate ca 02
  30820465 3082034D XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        quit
crypto pki certificate chain airespace-old-root-cert
 certificate ca 00
  30820406 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        quit
crypto pki certificate chain airespace-new-root-cert
 certificate ca 00
  3082045A XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        quit
crypto pki certificate chain airespace-device-root-cert
 certificate ca 03
  3082047F XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        quit
crypto pki certificate chain cisco-root-cert
 certificate ca 5FF87B282XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        quit
crypto pki certificate chain Cisco_IOS_MIC_cert
 certificate 263D02A70000002F45A1 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        quit
 certificate ca 6A6967B3000000000003 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        quit
crypto pki certificate chain virtual_wlc_trust_point
username admin secret XXXXXXXXXXXXXXXXXXXXXXX.
lldp run
bridge irb
interface Dot11Radio0
 no ip route-cache
 antenna gain 0
 stbc
 ampdu transmit priority 1
 ampdu transmit priority 2
 ampdu transmit priority 3
 mbssid
 speed  11.0 6.0 basic-9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23.
 power local 7
 power client local
 packet retries 64 drop-packet
 station-role root
interface Dot11Radio0.18
 encapsulation dot1Q 18
 no ip route-cache
 bridge-group 2
 bridge-group 2 subscriber-loop-control
 bridge-group 2 spanning-disabled
 bridge-group 2 block-unknown-source
 no bridge-group 2 source-learning
 no bridge-group 2 unicast-flooding
interface Dot11Radio0.19
 encapsulation dot1Q 19
 no ip route-cache
 bridge-group 3
 bridge-group 3 subscriber-loop-control
 bridge-group 3 spanning-disabled
 bridge-group 3 block-unknown-source
 no bridge-group 3 source-learning
 no bridge-group 3 unicast-flooding
interface Dot11Radio0.20
 encapsulation dot1Q 20
 no ip route-cache
 bridge-group 4
 bridge-group 4 subscriber-loop-control
 bridge-group 4 spanning-disabled
 bridge-group 4 block-unknown-source
 no bridge-group 4 source-learning
 no bridge-group 4 unicast-flooding
interface Dot11Radio1
 no ip route-cache
 antenna gain 0
 peakdetect
 stbc
 mbssid
 speed  6.0 9.0 basic-12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23.
 power client local
 station-role root
interface Dot11Radio1.18
 no ip route-cache
 bridge-group 2
interface Dot11Radio1.19
 no ip route-cache
 bridge-group 3
interface Dot11Radio1.20
 no ip route-cache
 bridge-group 4
interface GigabitEthernet0
 no ip route-cache
 duplex auto
 speed auto
interface GigabitEthernet0.750
 encapsulation dot1Q 750 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 spanning-disabled
 no bridge-group 1 source-learning
interface BVI1
 mac-address bc16.65XX.XXXX
 ip address 172.19.XX.XX 255.255.XXXX
 no ip route-cache
 ipv6 address dhcp
 ipv6 address autoconfig
 ipv6 enable
interface BVI2
 mac-address f41f.c25b.XXXX
 no ip address
interface BVI3
 mac-address 0000.0c44.XXXX
 no ip address
interface BVI4
 no ip address
interface Virtual-WLAN0
 no ip route-cache
ip default-gateway 172.19.XX.XX
ip forward-protocol nd
no ip http server
no ip http secure-server
ip ssh version 2
logging trap emergencies
logging origin-id string AP:bc16.XXXX.XXXX
logging facility kern
logging host 172.19.XX.XX
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 route ip
bridge 3 route ip
bridge 4 route ip
parser view capwap-config-view
 secret 5 XXXXXXXXXXXXXXXXXXXX
 commands configure include all capwap
 commands exec include all enable
 commands exec include configure terminal
 commands exec include all show capwap
 commands exec include show running-config
parser view pnp-config-view
 secret 5 XXXXXXXXXXXXXXXXXXXXXXXXX
 commands configure include-exclusive capwap ap flexgroup
 commands configure include capwap ap
line con 0
line vty 0 4
 transport input ssh
line vty 5 15
 transport input ssh
capwap ap strict-daisy-rap disable
capwap ap pause-time 100
capwap ap flexgroup default-flex-group
capwap ap unencrypted_data_keep_alive enable
capwap ap hyperlocation disable
capwap ap halo-APflag disable
capwap ap dot1x-port-state 0
capwap ap ble-adv-power 0
end
Erfan7
Let me know about other information..logs etc
AdamF1
From the sounds of the downloading, it is  failing over to another controller and falling back. You stated your code is different on the controllers so it’s download and triggering a fall back due to the fall back being enabled globally on the controller. Aps lose connectivity to that controller and go to their secondary.
Erfan7
Adam I said just for experiment I migrated APs to the controller that is on old code, but APs were still restarting, then I reverted all to controllers(Primary/secondary) that have latest code.
