APs' Telnet interface
ED CARMODY
Level 5
Level 5
Here's a silly one, but it's been bugging me for a while:
How do you gracefully exit out of a telnet session to an AP? i've been killing the connection via my emulator, but if I'm into the AP through a router, I have to re-establish the connection with the router.
The manuals don't give any consideration to closing out the telnet session.
Any help is appreciated.
kagodfrey
Level 6
Level 6
You need to enter the close command in the command line mode by prefixing it with a colon. You can view this and other commands by accessing the help.
:CLOSE Close the telnet session if the connection is open
Kev
