Architecture issue with 2106 controller
MouhatNicolas
Community Member
I have a 2106 controller. I want to connect two LWAPP 1131 directly on the two POE ports. I also want to connect a port on a Firewall in order to administrate the controller through the firewall.
The issue is that the management interface must be accessible for the AP and for a PC through the firewall. But the management interface can be assign to only one port.
Any idee?
ankbhasi
Hi Friend,
Management ip address should be reachable by APs and not interface. So you can map your management interface to port 1 and connect you APs to port 7 & 8 and they will join your controller.
If I am not able to understand your doubt please come back again with the same.
Ankur
*Pls rate all helpfull post
