Are WLC 3504 and 5508 interoperable
pkemp
Frequent Visitor
Frequent Visitor
I want to use the 3504 as a guest anchor with a 5508, since the 2504 is now EOS. Is the 3504 interoperable with the 5508? Will that work?
Peter
Scott Fella
It really comes down to the code. Here is a link to the Mobility between code versions.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-149658
-Scott
Scott Fella
-Scott
Ric Beeching
Level 11
Level 11
Yep just check the feature matrix out:
https://www.cisco.com/c/en/us/products/wireless/wireless-lan-controller/product-comparison.html
Ric
Please rate helpful / correct posts
