Aruba 501 Wireless Bridge über WLC 4402 mit Air Lap1242
Is it impossible to use Aruba 501 Wireless Bridge with the WLC 4402 and AIr Lap 1242 Accesspoints?
I have the hole WLan build with the Air 1242 AP's but now i want  a WLan Bridge vor the local Lan on a hall carn to connect with the Wlan.
I give the Aruba bridge a fix IP in the same area of the AP's and the PC on the carn but there is no connection.
Sorry my English is verry bad....
with kind regards
Ralf Burek
marce1000
   >....Is it impossible to use Aruba 501 Wireless Bridge with the WLC 4402 and AIr Lap 1242 Accesspoints?
                        Forget it , to be 'honesty summarizing....'
 M.
Not possible.
Suggest having a survey done and replacing all the APs. You could look at some other vendors if you need to keep costs down, as the WLC and Cisco APs are past every end of life date
*****Help out other by using the rating system and marking answered questions as "Answered"*****
