ASA 9.1 policy based routing
I would need to route default route from a specific network to a specific ip using pbr. For example I already have a default to 10.1.1.1 .. then I would need another default to 10.1.1.2 applied in ingress on a specific interface (gi0/1) for traffic coming from 192.168.1.0/24 for example, which is the network configured on interface gi0/1 of my firewall.
abwahid
Level 4
Level 4
There is no actual PBR feature on the ASA's, but if your nat statements are specific to the source and specific to the outgoing interface you will be able to have policy routing via NAT, Go through the below link for alternative solution.
https://supportforums.cisco.com/discussion/11718141/asa-policy-based-routing-alternative
