Asalam
abdulsalamsadik
Community Member
I have 2504 wireless controller with  9 pcs 17021-E-K9, i need to add another 6 outdoor AP's which model will be compatible with the available one and insure data streaming
Scott Fella
Well it also depends on the code you are running. Fist make sure you reference this:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
I would say look at the IW3702 or if you will need mesh, then the 1550 or 1570.  You can reference the data sheets for more info also.
-Scott
-Scott
