assigning IP address in ROMMON have issue in C1600 AP
zayarnainghto0
I have issue booting the C1600 AP from image and so I try to upload new image via tftp in ROMMON but when i assign IP via set command the AP dont get the IP that I assign and cannot ping from My IP.
please check the log below:
The system is unable to boot automatically because there
are no bootable files.
C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
Compiled Fri 30-Nov-12 15:48 by aselvara
ap: set
0=0
AP_IMAGE_RCV=flash:/ap1g2-rcvk9w8-mx/ap1g2-rcvk9w8-mx
AP_MD5_LAST_SUCCESSFUL_TIME=06:24:56 UTC Jul 31 2023
DEFAULT_ROUTER=192.168.200.254
ENABLE_BREAK=yes
IOS_STATIC_CONTROLLER_IP_ADDR=192.168.200.190
IOS_STATIC_DEFAULT_GATEWAY=192.168.200.254
IOS_STATIC_HOSTNAME=AP5
IP_ADDR=192.168.200.69
MANUAL_BOOT=no
NETMASK=255.255.254.0
RELOAD_REASON=41
TERMLINES=0
Mark Elsen
       >...the AP dont get the IP that I assign
 - What IP address are you trying to assign ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Rich R
Do you mean that the IP was lost after you assigned it for example after reboot? Did you "sync" to save your settings?
Did you get an error message?
Did you initialise the LAN interface with ether_init?
And then tftp_init before trying to TFTP?
Take a look at https://community.cisco.com/t5/wireless-mobility-knowledge-base/access-point-rommon-recovery-ap-prompt-recovery-example/ta-p/3119495
