Assigning wlan controller ip from dhcp
blackswans
Is it possible to give the wlan controller ip to the lightweight AP from the dhcp?
Thanks.
Leo Laohoo
For 1602 AP which one should we use?
option 43 ascii "192.168.10.5,192.168.10.20"
OR
option 43 hex
Thanks.
option 43 hex
Option 43 is always in HEX.
If it is IOS DHCP server, you can use either ascii or hex. (you can test it out using both methods)
If it is MS-DHCP server you have to use Hex
Rasika
**** Pls rate all useful responses ****
