09-27-2021 02:56 PM
Hi Please see the below screenshot, which is Radios 5 Hz Band in WLC9800/AP9130. Under Tx Power Level Assignment, We want to change the value 6. but why Assignment Method is grayed out? How can we change it? Thanks
09-28-2021 12:48 AM
which software version you are using on WLC ?
Did you try with another browser ?
09-28-2021 06:19 AM - edited 09-28-2021 07:45 AM
Thank you Sandeep for your reply. WLC ver is 17.3.4 joined with two kinds of AP: 9130 and 9117.
9117 can change its Assignment Method from Global to Custom, and then change value. but 9130 cannot because its grayed out. Does 9130 not support the function? I tried different browser, no difference is found. Thanks
09-28-2021 08:41 AM
Do you have FRA enabled?
09-28-2021 12:37 PM - edited 09-28-2021 01:56 PM
I checked it. I can see it disabled. but the FRA works for whole c9800. it means FRA works for all APs joined to the wlc. Why ap9117 can work with FRA disabled? or we can say ap9117 does not need FRA? Thanks
09-29-2021 05:15 AM
There are 2 5GHz interfaces in 9130, do you have both enabled?
09-29-2021 02:35 PM
Only one is enabled. Where can the second one be enabled? Thank you
09-30-2021 03:17 AM
I have checked in one of my controllers, I can edit the power levels in all of my 9130. If the AP regulatory domains are ok, I would suggest to reach out to TAC.
