authenticating users using tacacs
lucky.sibanyoni
I'd like to know on how can i set up the intergration between the controllers and the tacacs server.
i have created a group in ACS as per the controller doc and also added the tacacs server on the controller under: Security Tab, then Tacacs, and i've used port 49, and also the key is the same as the one i've put on the ACS server.
Can someone provide me with the step by step guide on how to do this:
Thanks a lot
0 Replies 0
