Authentication Issues with Radius
ccie_ma
Community Member
I can see loads of authentication issues for the SSID which is configured for Radius authentication.
A lot of same clients that report failed aunthentication later report successful authentication. Anyone else experiencing this ?
Mariam
Typically yes, but with successfully association at the cell edge, the multi-packet EAP-exchange with larger payload has a quite high likelihood to also fail.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
5 Replies 5
Philip D'Ath
Meraki Community All-Star
No. What does your RADIUS server log report for the failed authentication attempts?
Thanks for your response. I do not have access to Radius server log. But will propose this to the team who owns it. So in a typical environment we expect to see 0% authentication issues and 0% DHCP issues unlike association issues which can be present just because the client tried to connect two APs at the same time and then chose one ?
The authentication issues should have a quite small number but are not typically 0%. The authentication exchange could fail because of roaming away, packet loss, or other problems while authenticating.
Thanks @Karsten Iwen for your response. If the client roams away, I expect it to log the error in Association stage not in any of the subsequent stages. Is that not right ?
