Authentication method
paltel
Level 5
Level 5
I have Windows XP client with PEAP and smart card or other certificate IEEE 802.1x authentication method, and 350 Cisco aironet bridge. I have ACS ver 3.0 and i want to use RADIUS.
please help
Many Thanks
alinn
The minimum software release version needed to support PEAP on the ACS server is 3.2.1.
Hope this helps.
Aaron
what about MD5 or LEAP, i think LEAP need Cisco Adapter at the client side?
You do not need Cisco adapter for LEAP. All you need is CCX v1, v2, or v3 compliant adapters.
Please go to the following URL for CCX compliant adapters:
http://www.cisco.com/en/US/partners/pr46/pr147/partners_pgm_partners_0900aecd800a7907.html
