Authentication types and roaming
joemarr_brodart
Level 2
Level 2
What is the appropriate authentication type for continuously connected apps?
I recently implemented a wireless solution using 1240AGs, 4425 controllers and WLC.
I?m testing intermec CK31 handhelds connected to an oracle telnet based WMS.
I have WPA2+AES and PEAP authentication enabled.
When the handhelds roam from one AP to the next, it appears to be re-authenticating. This causes the connection and IP to drop and re-establish just slow enough to cause problems with maintaining a session the oracle WMS.
I can see the units re-authenticating in the ACS logs.
Any help or discussion would be appreciated.
scottmac
Level 11
Level 11
EAP-Fast or LEAP are probably your best shot.
Good Luck
Scott
