Auto RF
ppellettiere
Level 3
Level 3
We just setup auto RF on all of our 12 controllers. My question is, is the controller group leader the only controller
that will display the "Last Group Updates" times? or should I see it on all the controllers?
jeff.kish
Level 11
Level 11
You should see it on all controllers. Each controller has its own timer for running the Auto RF checks.
As an aside, I highly recommend that you disable the automatic updates. Running them manually once a week or so is usually best, unless you have a constantly changing or challenging environment. Client can occasionally be disconnected by the automatic updates, which occur every 10 minutes by default.
jeff.kish
Level 11
Level 11
I wonder why I only see it on the lead controller? Any ideas?
Hello.
We have the same problem: 6 controllers running 4.2.207 and only one (controller group leader) shows actualizations. Any body knows what is the reason?
Thanks in advance.
