Autonomous 1142N & Web Authentication
marioderosa2008
Hi all,
is it possible to have an autonomous 1142N access point use Web Authentication to utilise guest services on the Cisco ISE? Or is a controller needed for this?
The problem is that we have a controller but it only hosts Local Mode AP's. I understand that we cannot add any Flex Mode AP's to this as it will break the Pre-Posture & Post-Posture ACL config that we have on the Cisco ISE.
This questions is 50% wireless & 50% security, so I am posting here in the hope that someone can answer with experience on Wireless & Cisco ISE..
thanks
Mario De Rosa
Scott Fella
Autonomous access point is NOT supported with ISE. So you need to ask in the security forum if the latest version of ISE supports what you want.
-Scott
