Autonomous AP and Bridge
stephen.bel0001
Need help to find some Autonomous AP and Bridge Basic Configuration Templates and guides
2 Accepted Solutions
Here you go : https://supportforums.cisco.com/document/61936/autonomous-ap-and-bridge-basic-configuration-template
Rasika Nayanajith
Here is a very basic config for a autonomous AP to advertise single SSID
conf t
hostname <AP_HOSTNAME>
dot11 ssid <SSID_NAME>
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii <SSID_PASSWORD>
interface Dot11Radio0
 encryption mode ciphers aes-ccm
 ssid <SSID_NAME>
 no shutdown
interface Dot11Radio1
 channel width 40-above
 ssid <SSID_NAME>
 no shutdown
interface BVI1
 ip address dhcp
end
write memory
Below should give some guidance if you want to set up a wireless bridge.
http://mrncciew.com/2013/11/09/wireless-bridge-with-eap-fast/
http://mrncciew.com/2013/06/13/wgb-with-psk/
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
conf t
   authentication open
   guest-mode
 ssid <SSID_NAME>
 no shutdown
 ssid <SSID_NAME>
 no shutdown
interface BVI1
 ip address dhcp
end
write memory
Rasika
