Autonomous AP - infrastructure ssid and infrastructure client
Augustgood
Hi all,
who can help  me to understand the use of this command  ?
dot11 ssid pippo
infrastructure ssid
and
interface d 0
Augustgood
Infrastructure-ssid instruct non root bridge and wgb to connect only to this ssid (configured on root ) unless explict option. This is the question.... How can a wgb connect to other ssid without this command ?? someone can show me the config .. What is the purpose of this commad...?
Infrastrucuture-client where need to be configured ? on the root or in the wgb is not clear this....
Rasika Nayanajith
Read this post, you will understand what above commands do
http://wirelessccie.blogspot.com.au/2010/09/workgroup-bridge-wgb-cli-commands.html
Rasika
*** Pls rate all useful responses ***
